#262203 - 05/08/2005 00:59
ID that socket type!
It's about 6mm in diameter. Anyone know what type of socket that is or where to source one?
Backstory:
I just purchased a used (barely) Flytec 4010 variometer (for paragliding), and would like to be able to get data off of it with the data port. But the PC cable didn't come with it, and I can't seem to find it online (at least not for less than US$65+).
I could easily make the cable myself for dirt cheap since Flytec is nice enough to provide the pinouts of the cable in the manual, but I have never seen the socket that Flytec uses.
So the question is... does anyone know what type of socket that is and/or where to source one? Or is it a Flytec proprietary jack?
Edited by loren (05/08/2005 01:00)
#262204 - 05/08/2005 02:44
Re: ID that socket type!
[Re: loren]
Mouser has an entire section of round connectors in their catalog. Link
#262205 - 05/08/2005 03:55
[Re: msaeger]
Yea... I've been paging through their annoying PDF catalog for a while now... still don't see anything like it. Thanks for the link though... still lookin.
#262206 - 05/08/2005 05:40
[Re: loren]
Reading through the tech specs I noticed it says :
Data port Four pin ultra-mini DIN interface port for connection to a PC or a computer printer.
It does look like a 4 pin DIN interface, but the DIN and mini-DIN circular 4-pin connectors I can find are all too large, and I can't find reference to ultra mini DIN anywhere. The sleuthing continues...
#262207 - 05/08/2005 14:16
[Re: loren]
Quote: I could easily make the cable myself for dirt cheap since Flytec is nice enough to provide the pinouts of the cable in the manual, but I have never seen the socket that Flytec uses.
When all else fails, use brute force. If I were in your shoes, since I have the pinouts, I'd cut up the casing and solder my own standard serial port there, making it all rugged with generous helpings of hot glue. That way, the only thing between it and the host PC is a single easily-replaceable serial cable. Dongles break and fray too easily.
Or you could just jerry rig it. If you only need it to pull data once in a while, and if the conneciton doesn't have to be rugged, then just use some bits of wire and get some of the female pins out of a radio shack serial port kit, and attach those to the appropriate pins.
#262208 - 05/08/2005 15:38
[Re: loren]
That is the kind of socket we have on our internal comm network (for the headsets/helmets). Other than that, I'm no help at all
#262209 - 05/08/2005 15:58
[Re: loren]
Loc: Triangle, VA
Not sure if this is what your looking for but they have some mini din connectors listed here
-D
#262210 - 05/08/2005 16:12
[Re: SonicSnoop]
Tony.... actually, that's a great idea. Just slap some pins on there. Probably end up doing just that!
Tim... That might be of help. If I know what that socket is usually used for I'll have a better idea of where to search
Darrell... Thanks for the link. Turns out it's definitely not DIN or mini-DIN. A buddy seems to think it was a pretty common connector back in the late 80's ... maybe an early DIN format or something.
#262211 - 05/08/2005 20:25
Loc: Seattle, WA, U.S.A.
Now I like where you are heading, but I would take this one step less far.
I have become a great fan of common 4-conductor trailer connectors like yo. If there was room, I would JB Weld one of those inside the case and then fab a custom trailer-to-DB9 serial cable. The are pretty rugged, stay together, and don't stick out much.
Quote: Or you could just jerry rig it.
OK, I was going to say "'jerry rig' or 'jury rig'?" but this interesting note suggests that neither may be the perfect fit! As a word-derivation Bitt I am a failure
Jim
#262212 - 06/08/2005 09:06
[Re: jimhogan]
Loc: Yorkshire UK
Quote: have become a great fan of common 4-conductor trailer connectors
Now why can't we stick with something nice and simple like that instead of the blighted 13 pin euroconnector. I think that the motto of European bureaucrats is "Change, but don't try to improve": Do a seen to be doing job.
#262213 - 06/08/2005 10:52
[Re: boxer]
Any time I am looking for a really odd connector, I wander over to Sphere Research. It is a Canadian based company / hobbiest that has supplied me with all kinds of nixie and assorted obscure / archaic stuff for a while now. You might want to drop them an email.
#262214 - 06/08/2005 12:27
Loc: Hants, UK
Another idea is to break apart a plug with the same pin diameter and then glue the sleeves into holes drilled a piece of plastic, then add the hot glue or whatever to form the plug body. Might be tricky to get the ground/sleeve connected properly but it might not be required.
Gareth
#262215 - 06/08/2005 13:30
[Re: loren]
Loc: Yorkshire UK
I'm not vaguely taking any responsibility for what may lead you astray, but I've recently spent an age looking for the din plug for the control socket of my Revox, involving googling and poring over endless DIN specs. all of which are like knitting fog. This "female plug" (A contradiction in terms, I feel) rings a slight bell: on a quick google, I came up with a J4D, but I'm not sure whether that's a din or a mini-din. However, when I googled that, I came up with these people, why not email them your photo and see if they can help?
#262217 - 10/08/2005 10:52
Loc: Newfoundland, Canada
Quote: Or you could just jerry rig it. If you only need it to pull data once in a while, and if the conneciton doesn't have to be rugged, then just use some bits of wire and get some of the female pins out of a radio shack serial port kit, and attach those to the appropriate pins.
To add to Tony's suggestion, once you have it all hooked up like this, give a little spray of wd40 or something in the port and then fill it with hot glue. once it hardens you should be able to pull out your new plug.
12 gig empeg Mark II, SN: 080000101 30 gig RioCar SN: 30103114 My blog
