#259263 - 28/06/2005 16:10
Memory board installation manual online
Hi. Get it here. Any errors, omissions, requests, etc, let me know. pca
#259264 - 28/06/2005 17:29
Re: Memory board installation manual online
[Re: pca]
And excellent it is!
#259265 - 29/06/2005 20:14
[Re: pca]
Loc: Switzerland
I just successfully upgraded my MK2 player to 48MB. I'll do the full upgrade with the ra3 patch wire tomorrow. The manual is great, but you forgot to mention the necessary GND patch wire in the manual. Thanks to pca!
#259266 - 29/06/2005 20:48
[Re: alex25]
Quote: The manual is great
Thank you.
Quote: but you forgot to mention the necessary GND patch wire in the manual.
Actually, if you fit the link wires between the capacitors on the top and the bottom, it's not necessary (assuming you're referring to the gnd hole on the botom left of the memory board), hence it's not mentioned.
I could put in an explicit 'it is not necessary to connect to this pad' line.
#259267 - 30/06/2005 00:57
[Re: pca]
Loc: CA, USA
Yes, the manual is great, leaving nothing to ponder. I'm looking forward to performing an upgrade this weekend with a few beers. Thanks for the fun and the quality upgrade "kit."
#259268 - 30/06/2005 03:45
[Re: pca]
Loc: Switzerland
In Antwort auf:
In Antwort auf: but you forgot to mention the necessary GND patch wire in the manual.
But then you have to remove the following sentence after mounting the board: Also check that there IS continuity beteen the GND hole and a convenient ground point (such as the shield of the serial port connector)
Because at this point there is no continuity, that's why I though a seperate ground patch wire is neccessary.
#259269 - 30/06/2005 06:50
[Re: alex25]
OK, I've fixed that and re-uploaded the manual.
#259270 - 02/07/2005 14:28
[Re: alex25]
Loc: Switzerland
In the meantime I upgraded my player to 64MB and it seems to work great.  If someone wants me to do the memory upgrade on his player, I'll do it for you. I upgraded three players until now, two of them with the stack method. I'll also build tuner kits or add the illumination buttons. I'm located in Switzerland.
#259271 - 03/07/2005 06:00
[Re: pca]
Loc: 384400 km from the Moon
Two empeg units are upgraded now. With the first one I followed the manual as is. When I tested the unit, it didn't work (the memory test failed). The problem turned out to be incomplete solder joints in some daugher board holes. With the second unit I found a better solution that solves two problems: 1) Board alignment 2) Complete solder joints (first time - every time) The way to get it would be to melt some solder on just those pads that connect to daughter board. I created small semi-circlular balls on each of these pads. This way the board aligns naturally (of course I still have to hold it in place, but now it doesn't shift) and I don't have to do a lot of solder "mixing" inside the connection hole to make a perfect connection. Patrick, if you could put this tip into the manual, that'll be great.
#259272 - 03/07/2005 12:07
[Re: peakmop]
Clothspins (the spring style) work wonders for holding the two boards together, tight and in alignment. Cheers
#259273 - 03/07/2005 15:39
[Re: alex25]
Loc: Switzerland
I think you will get some work soon  Check you PM! bye
#259274 - 04/07/2005 21:56
Loc: CA, USA
I've successfully upgraded two mk2a units to 64MB. I've had some difficulty with a mk2 unit upgrade. Likely poor technique and a Grappa problem  A big thanks to Patrick for a fun 4th of July weekend!
-Sean
Edited by caseyse (04/07/2005 21:58)
#259275 - 08/07/2005 05:38
[Re: alex25]
Loc: Switzerland
Hi Alex25,
Thanks for the memory upgrade. It was a fast and perfect service.  . (typical Swiss quality)
I can recommand your professional soldering work to the Empeg community.
bye
#259276 - 28/12/2005 11:21
[Re: pca]
Loc: Virginia, USA
I have finally gotten time to install this memory board and I must say that it is a real professional quality kit.
I do, however have an issue. I have soldered everything into place and checked for proper continuity on the major test pads and everything seems to be working - although the memory doesn't show on boot.
I noticed the boot9.rom, but since I'm on a MK2A player, I assume that I don't need it (being that the instructions for it are under the MK2 player section).
Is there anything else I need to check for other than making sure that the pads are all soldered?
Brent RioCar MK][a 20GB+80GB '96 Saab 900s (Not any more) Still looking for a good way to install in a 2010 BMW 3 series with iDrive/NAV
#259277 - 28/12/2005 11:34
[Re: bbowman]
Got a recent version of Hijack installed? A log of the boot would be helpful to see what is going on.
#259278 - 28/12/2005 11:54
[Re: tman]
Loc: Virginia, USA
hmm, I just upgraded the hijack about 2 weeks ago via the JEmplode interface. Unfortunately, I just got to work, so I can't get back to it until this afternoon (Eastern USA time). I cannot tell you which version it's at.
#259279 - 28/12/2005 12:03
[Re: bbowman]
If it was the latest version as of 2 weeks ago then thats fine.
#259280 - 28/12/2005 17:59
[Re: bbowman]
Loc: Salt Lake City, UT
I had that problem at first, so I double checked all my solder connections, and had some that had not made a good connection. I would go over those again, to make sure they have contact with main board.
-Michael
#259281 - 25/05/2007 14:33
[Re: pca]
Loc: Triangle, VA
I was wondering if anyone had a copy of this? I have someone who will install it for me but am on a kinda tight schedual since he will be leaving our company in the next week. Thanks!
-D
#259282 - 08/12/2007 00:12
[Re: pca]
Might seem like a dumb question...but where can I get one of the memory expansion boards here in the USA? I can't seem to access the PCATS site as it requires a username and password.
#304813 - 08/12/2007 07:26
[Re: FieroSTi]
Send a private message to pca, don't know if Patrick still has any kits available though.
#304815 - 08/12/2007 13:46
[Re: FieroSTi]
Hi. I sold out of the final batch of memory boards long ago, and there won't be any more. There simply wasn't/isn't enough demand for them. Sorry. The pcats.co.uk site has been down for quite a while due to circumstances beyond my control. It's a long story  Pca
#304917 - 10/12/2007 03:37
[Re: pca]
Most unfortunate.
#304938 - 10/12/2007 15:51
[Re: FieroSTi]
That said, I think the people that used the stacked memory method had fewer problems in the long run. I had two like that (a mk2 and a mk2a) and they're both working well.
#305075 - 12/12/2007 07:19
[Re: JBjorgen]
That said, I think the people that used the stacked memory method had fewer problems in the long run. I had two like that (a mk2 and a mk2a) and they're both working well. Ok, one more quick question...where does one find the RAM chips?
#305081 - 12/12/2007 09:30
[Re: FieroSTi]
TiVo S1 memory chips were the same I believe.
#305095 - 12/12/2007 15:41
[Re: tman]
IIRC, I believe that Hugo also sent a load of them to Stu at Eutronix.
