#257967 - 10/06/2005 14:39 Encoding and upgrade questions
belezeebub
I know I have asked this before, but things change so often I want to make sure it is still true.
Background
Infinity Kappa Perfect Speakers and Kappa Perfect Sub
PPI 6 channel Amp.
(External Crossover once I find one I like)
About 22k songs over 2300 Cd’s now (no downloaded music I own them all and I am converting my 8-tracks, cassettes and Records to CD’s a few at a time when I can find them for sale or order them online) (You wouldn’t believe how hard it was to find Pop Music by the “M” on Cd)
I am pulling out my Empeg this weakened and sending it off to Stuart Euans for some much needed TLC
Encoder replacement: $40
Dimmer fix: $15
Lighting kit: $44.99
Green Buttons: $39.99
32 MB of RAM (is 32 enough for the new file format I will choose?)
Smoke Len
This gives me some time to finish re-ripping all my songs I am looking for the best quality short of making them all wav files. I am currently running 3A8 (wish it booted up a bit faster but other then that no issues yet)
I am currently re-ripping all my Cd’s to wav files and will encode them once I figure out which format is the best quality.
I have to admit I am a bit confused I am using EAC to do the ripping, I had used Lame for MP3, but MP3’s while good just doesn’t cut the mustard for my stereo.
Lame has both a High Quality and a Voice setting (which is better)
Flacc is supported but roughly 4 times the size of a MP3 file, not a huge issue but an issue none the less (is it worth the space)
Vob and Obb (I know nothing about them)
MP3Pro (yet one more unknown format)
______________________________________ Do not meddle in the affairs of Network Administrators, for they are subtle and quick to anger. ______________________________________ Worlds Lamest Wb Site (mine) http://home.comcast.net/~jlipchitz/
#257968 - 10/06/2005 14:57 Re: Encoding and upgrade questions [Re: belezeebub]
That's FLAC (Free Lossless Audio Compression). I'm (slowly) re-ripping my CD collection, and I'm doing it to FLAC. Before I put the music on the empeg, however, I'm transcoding the tracks to MP3, using LAME's "--preset standard" switch.
This means that I'm OK with file size on the empeg, but I can always transcode the tracks again later.
On the other hand, it does mean that I need a lot of disk space at home (I have a Linux fileserver with plenty of disks, so this isn't a problem for me; it might be a problem for you).
And that's "Ogg Vorbis". It's another format that supposedly gives the same quality as MP3, but at lower bitrates. It's not widely supported (but is getting better). v3a8 on the empeg does support it, so you might want to go this route.
Like MP3, it's lossy, which means that if you change your mind later, you're not going to be able to transcode your files without losing some quality, so you'll have to rip your CDs again.
MP3Pro
This one's MP3, souped up. It (allegedly) uses about half the space of MP3, for the equivalent quality (putting it on a par with WMA9).
The empeg doesn't support it (and is unlikely to in future), so it's probably a non-starter for you.
#257969 - 10/06/2005 15:01 Re: Encoding and upgrade questions [Re: belezeebub]
Best quality for the size is FLAC since it's totally lossless. WAV is uncompressed and the same quality but there isn't any point if you can use FLAC since it's smaller.
I personally can't tell the difference between 256ish VBR and the original material. If it's that much of a problem then use FLAC or MP3 at 320kbps. EAC + LAME set to alt-preset-extreme for me.
It's Ogg Vorbis. Alledgely patent free etc... Higher quality output than than MP3. Tagging is more advanced as well. Not as compatible as MP3 however since most stuff doesn't support it.
Not supported on the empeg. It's sort of backwards compatible with the empeg but you'd end up with 1/2 the bitrate since the other half stores the extra bits that make it MP3Pro.
Most people advocate just ripping to FLAC and storing it as your archive. When the next best thing for lossy (or lossless for that matter) audio comes out then it's a relatively simple step to transcode everything to that new format instead of ripping again.
#257970 - 10/06/2005 17:06 Re: Encoding and upgrade questions [Re: belezeebub]
SE_Sport_Driver
My signature has a link for a quick guide to using the LAME settings mentioned by Roger.
#257971 - 10/06/2005 17:22 Re: Encoding and upgrade questions [Re: SE_Sport_Driver]
belezeebub
So can you explain or point me to someplace that explains
"-alt-preset standard, extreme, or insane"
#257972 - 10/06/2005 19:07 Re: Encoding and upgrade questions [Re: belezeebub]
From your command line, run "lame --alt-preset help".
#257973 - 10/06/2005 19:11 Re: Encoding and upgrade questions [Re: belezeebub]
Mataglap
There are no hard and fast simple answers to questions like this because the best answer is dependant on each person and their hearing.
Given how little you know about the different codecs and stuff (hydrogenaudio.org is a great forum to get started with the technical details, for example they have extensive threads about reccomended lame versions and settings, as well as encoding to audio transparency and ABX testing) you're probably best off just using mp3 and going back to 2.00 final.
Using Ogg Vorbis or FLAC isn't unreasonable, but will require a lot more of your time and effort to understand and keep up with. Just like ripping to FLAC and then transcoding according to what codec you prefer at any given time.
I would try out --alt-preset standard and if it doesn't sound good enough to you, step up to extreme, and if that doesn't sound good enough try insane. And if that doesn't sound good enough you either have incredible hearing perception (and no compressed audio format is going to be good enough) or you're victim to a placebo effect.
--Nathan
#257974 - 11/06/2005 00:10 Re: Encoding and upgrade questions [Re: belezeebub]
bonzi
If I were you I would recruit a friend to help me arrange a blind listening test, wav (or FLAC) against different compressed formats and options. As other people said, if you can reliably tell apart original from even "lame --alt-preset standard" mp3 (a bit over 200kb/s on average), you have really exceptional ears. When preparing files for the test, make sure they play with equal volume, otherwise the louder one will sound better.
#257975 - 12/06/2005 01:07 Re: Encoding and upgrade questions [Re: belezeebub]
...but MP3’s while good just doesn’t cut the mustard for my stereo.
I wonder... Have you tried a more or less blind comparison?
By that, I mean pick a track with a lot of dynamic range, full spectral balance, good clean recording. In other words, a good test track.
Rip and encode to MP3 at a high quality setting -- say 256 KBPS variable bit rate.
Now, set up a test playlist on your empeg. Put the high quality MP3 file in that playlist a half dozen times, and put the same track in the playlist as a WAV file half a dozen times.
Turn shuffle on, and listen to the test playlist without looking at the empeg screen, making notes about whether you think the currently playing track is WAV or MP3.
When you're done, go back and compare your notes to the actual shuffled playlist order and see whether you got them right. I'll be surprised if you can really, truly tell the difference between the high quality MP3s and a WAV files.
#257976 - 12/06/2005 02:50 Re: Encoding and upgrade questions [Re: tanstaafl.]
Mataglap
This is what is called ABX testing (as in A sample, B sample, and the X sample which is either the A or the B), and there is a great deal of info about it (and test results from a wide range of people) on hydrogenaudio.org. There are applications which will even track your results across multiple tests, providing sufficent scientific rigor to avoid all but the most determined troll or flamish conversations.
--Nathan
#257977 - 12/06/2005 11:01 Re: Encoding and upgrade questions [Re: Mataglap]
bonzi
Your link led me to this interesting article: a "voodoo audiophile" conducted a (not quite double) blind listening test of power cords (with predictable "hit ratio" of 49%). The artice is surprisingly honest, given the author's "bent" (he did try, in a rather charming way, to discredit the whole idea of objective testing and measurement). The most interesting part to me are quotes from other chap, a "skeptic", who essentially says "'high end' power cords and 'CD demagnetizers', of course, do nothing; but, if you feel you enjoy your systems more using them, by all means go for it!". There is a very thin line between a placebo provider and a fraud...
#257978 - 12/06/2005 15:28 Re: Encoding and upgrade questions [Re: bonzi]
Only had a quick skim through the article but it does seem to be done pretty well.
The people that claim the whole double blind testing method is flawed have some bizarre arguments. Like you need to break them in for a certain number of hours before they'll work to their full potential and unplugging/replugging loses the "magic".
I concede that interconnect cables may make a difference if the stock ones you're use a little more than rusty barbed wire with a badly oxidised plug on each end but super special power cords are just crap. That last 2 meters from the wall to your device is nothing compared to the kilometers of cable between you and the powerstation. I'll go get the power company to replace all the cable with super expensive oxygen free copper which has been drawn by hand under a full moon on the top of Everest by a Buddist Monk who only does this once every 50 years
