#256839 - 24/05/2005 11:43 Mac Mini DVD authoring?
robricc
I am considering buying a base ($499) Mac Mini solely for DVD authoring. I recently bought a Neuros MPEG4 Recorder as an easy way to digitize my VHS collection of stuff recorded off television. I have various video input cards for PCs, but I find them all to be of poor quality. There’s almost always either a picture full of interference, volume level problem, or audio sync issue.
I would like to convert about 200 VHS tapes to DVDs using the MPEG4 encoder to capture the video. My DVD authoring software must be able to convert MPEG4 to the proper DVD MPEG2 format without me having to fire-up another program. I would assume iDVD fits this requirement?
If I bought the base-model Mac Mini without DVD writer, would I be able to author a DVD with iDVD and then burn it on my PC somehow?
I’m not against using an all-PC solution, but they all really suck. The Ulead stuff is cheap but buggy and I don’t recall if it converts on-the-fly. DVD Lab won’t convert video formats on-the-fly either. Are their any other easy choices for the PC?
#256840 - 24/05/2005 11:59 Re: Mac Mini DVD authoring? [Re: robricc]
mschrag
Loc: Richmond, VA
If you want to put up a sample, I'll be happy to grab it and try it out on iDVD to make sure it does what you want ...
#256841 - 24/05/2005 12:03 Re: Mac Mini DVD authoring? [Re: mschrag]
robricc
Cool, I will try and make something tonight and upload it somewhere.
#256842 - 24/05/2005 12:10 Re: Mac Mini DVD authoring? [Re: robricc]
Yeah. You can create the DVD image on the Mac with iDVD 5 and then transfer it over to your PC for burning.
#256843 - 24/05/2005 12:12 Re: Mac Mini DVD authoring? [Re: robricc]
You shouldn't have a problem, now that iLife 05 is out iDVD will make an ISO for you. I upgraded recently to 05 and burnt my first iDVD DVD with k3b on my linux box, worked a treat and seeing as you'd be buying now, you should get 05 anyway.
#256844 - 24/05/2005 12:13 Re: Mac Mini DVD authoring? [Re: tman]
Dammit, beat me to it!
#256845 - 24/05/2005 12:33 Re: Mac Mini DVD authoring? [Re: andym]
robricc
Will the Mac see my Windows shares natively, or will I have to install Samba? The last time I installed Samba (4-5 years ago), it was a pain to get it working.
#256846 - 24/05/2005 13:04 Re: Mac Mini DVD authoring? [Re: robricc]
It's built in now. Just go to the Network page and you should be able to browse the network and select your Windows machine. You can do it the other way around if you want and mount the Mac HD from your Windows machine by enabling Windows Sharing.
#256847 - 24/05/2005 13:36 Re: Mac Mini DVD authoring? [Re: robricc]
External USB2/Firewire drive enclosures could be handy for situations like this.. makes sharing the DVD burner easier, if that's of any help here.
#256848 - 24/05/2005 13:41 Re: Mac Mini DVD authoring? [Re: mlord]
robricc
That's a possibility. I have an empty enclosure already...
Looking at some reviews, it looks like I will be upgrading the memory to 1GB myself. 256MB is universally regarded as too little.
#256849 - 24/05/2005 13:58 Re: Mac Mini DVD authoring? [Re: tman]
eliceo
I thought I read somewhere that the mac end (Tiger) changed something made windows SMB shares act funny, But Samba worked fine.
#256850 - 24/05/2005 14:28 Re: Mac Mini DVD authoring? [Re: eliceo]
I'm using Tiger on my mini and I've not noticed anything particularly odd about it. Mounting the SMB share works okay apart from it disconnects sometimes when it's idle it seems which is a bit annoying.
