#254736 - 21/04/2005 05:40 Problems formatting hardrive
m6400
Loc: Erie, PA
I'm attempting to format a 60GB Toshiba hardrive in my empeg (only drive). I'm using the most recent car builder and following the FAQ instructions but after it flashes, pumps, and restarts I get strange repeating error messages. I've included as an attachment the captured hyperterminal output. The large section of error code after the boot-up sequence just repeats.
This used to be part of a 2 drive set up. I took the older drive out because it was failing. I started by just reinstaling the software on this drive without formating but it woudn't synch properly (kept building database untill crashing). After I got this error message I tried installing the player software again anyways and now that gives me a (different) set of repeating error messages.
I'd post those error messages too, but I don't feel like flashing my player for the 20th time tonight. If it's important I'll do it and post it tomorrow.
Thanks in advance for any help.
254318-captured.TXT (222 downloads)
___________________
- Marcus -
#254737 - 22/04/2005 15:49 Re: Problems formatting hardrive [Re: m6400]
m6400
Loc: Erie, PA
Anybody?
Here is the readout from when I try to install the developer image.
I've replaced the cable and I have the jumpers set properly to be the only drive.
Come on, somebody has to at least have a guess at this, I'm going into sonic withdrawal here!
254443-captured2.TXT (183 downloads)
___________________
- Marcus -
#254738 - 22/04/2005 16:43 Re: Problems formatting hardrive [Re: m6400]
Mataglap
Pressed for time here, but this might help you out.
http://www.differentpla.net/node/view/199
#254739 - 22/04/2005 16:50 Re: Problems formatting hardrive [Re: Mataglap]
You shouldn't need to do a manual format if it's a 60GB drive. I've got a Toshiba MKsomethingorother 60GB and I just used the builder image. [edit]You may need to however if it's not a Mk2a since you have less memory.[/edit]
Edited by tman (22/04/2005 16:51)
#254740 - 22/04/2005 18:06 Re: Problems formatting hardrive [Re: tman]
m6400
Loc: Erie, PA
I have a Mk2a. The builder image is what I've been trying to use.
I installed this hardrive myself (as an addition to the original 10GB) the first time around without a problem, so I'd like to think I'm not a complete novice at this.
Mataglap, that looks like I've got to hook up the drive to my computer. I don't have the cables for that right now, but I'll keep it in mind if no one can come up with anything better.
___________________
- Marcus -
#254741 - 22/04/2005 18:19 Re: Problems formatting hardrive [Re: m6400]
I never implied that you're a complete novice just that you shouldn't need to do a manual format of the drive.
#254742 - 22/04/2005 19:41 Re: Problems formatting hardrive [Re: m6400]
Mataglap
If this is a second drive, you should be able to do it from a shell, I have both fdisk and mke2fs on my units. (Might need to install the tarball of additional stuff, but I know I didn't put those two programs on there myself.) In any case, you definately want to format the music partition according to Roger's webpage, it makes a =huge= difference in fscks.
--Nathan
#254743 - 22/04/2005 19:44 Re: Problems formatting hardrive [Re: Mataglap]
Mataglap
There's a real problem since there's segfaults going on. Maybe try the drive on the other position of the cable?
--Nathan
#254744 - 23/04/2005 15:22 Re: Problems formatting hardrive [Re: Mataglap]
m6400
Loc: Erie, PA
Nathan -
Solo drive. I'll try moving it to the second (middle) position on the cable.
Trevor -
No worries, I wasn't taking offence.
___________________
- Marcus -
