#254321 - 15/04/2005 16:12
Empeg won't turn on after boot up
Loc: BATON [censored] ROUGE
I dont know if it actually finishes booting up. The last thing it showed during boot up is "loading visuals" and then it seems to go into the standby mode as usual only the blinking standby light doesn't illuminate and i am unable to turn the empeg on. I just formated the hard drive and reloaded my songs by the way, because when trying to add a second hard drive i plugged the wrong one up accidently formatted the original hard drive. SMART move huh? Anyway i just my empeg to work as it once did...HELP!!!
#254322 - 15/04/2005 16:49
Re: Empeg won't turn on after boot up
[Re: nahbrah]
Can you get in via the serial console?
#254323 - 15/04/2005 18:08
[Re: Mataglap]
yeah...well, i guess. I just used emplode and loaded more songs on it.
#254324 - 15/04/2005 18:36
[Re: nahbrah]
I just used the hyperterminal and turned the empeg on by entering play. The buttons are fully functional and everything works as it should. But once it is turned off it can only be turned back on by the hyperterminal.
#254325 - 15/04/2005 18:55
[Re: nahbrah]
Alright, I'm just shooting in the dark here, but it seems like it's more likely config rather than something broken. Reinstalling the empeg software (v2 or v3alpha8 if you need ogg vorbis) will clean up almost everything that might be wrong =except= for bad entries in config.ini. If you've been playing games with the visuals, there might be a bad visual in there, like lavatory_floor in the v3alphas.
Installing hijack can't hurt, and makes it much easier to install different versions of the empleg software using the upgrader program.
--Nathan
#254326 - 15/04/2005 19:13
[Re: Mataglap]
i just reinstalled v2.00 and hijack. But nothing new. Where do i get v3alpha8 so i can try to see if it will help?
#254327 - 15/04/2005 20:18
[Re: nahbrah]
Forget the alpha for now - it will probably not help. If it's really have "upgraded" it successfully, it should just work (tm) unless there's a hardware problem or something else.
Instead get a boot log as detailed here and post it, so we can maybe see what's happening. That would be a good start at least.
Edit: Missed the bit about the buttons working after "waking" it up in emplode... Very strange.
Edited by Shonky (15/04/2005 20:20)
#254328 - 15/04/2005 20:51
[Re: nahbrah]
Also please give us a copy of your config.ini
And yeah, don't mess with v3a8 just yet.
--Nathan
#254329 - 15/04/2005 23:47
[Re: Mataglap]
Okay i'll wait on that...heres the boot log atleast i think this is the boot log. What is "config.ini" though? Thanks for the help!!
empeg-pump v0.03 (19980601) Press Ctrl-A to enter pump...VFS: Mounted root (ext2 filesystem) readonly. change_root: old root has d_count=1 Trying to unmount old root ... okay Freeing unused kernel memory: 4k initDrive(s) appear to be already built. Skippi ng. Press return to continue anyway - anything else to start a shell.
warning: can't open /etc/mtab: No such file or directory Making first drive... mke2fs 1.14, 9-Jan-1999 for EXT2 FS 0.5b, 95/08/09 ext2fs_check_if_mount: No such file or directory while determ hda4 is mounted. Linux ext2 filesystem format Filesystem label= 76096 inodes, 9737280 blocks 0 blocks (0.00%) reserved for the super user First data block=1 Block size=1024 (log=0) Fragment size=1024 (log=0) 1189 block groups 8192 blocks per group, 8192 fragments per group 64 inodes per group Superblock backups stored on blocks: 8193, 24577, 40961, 57345, 73729, 204801, 221185, 401409, 663553, 1024001, 1990657, 2809857, 5120001, 5971969,
Writing inode tables: done Writing superblocks and filesystem done
real 0m41.828s user 0m0.250s sys 0m1.710s hdstress.cpp 189 ( 30): Poll result=0 on fd=5 hdstress.cpp 189 ( 30): Poll result=0 on fd=5 Stressing /dev/hda: Spinning down. hdstress.cpp 189 ( 30): Poll result=0 on fd=5 Stressing /dev/hda: Spinning up. hdstress.cpp 189 ( 30): Poll result=0 on fd=5 hdstress.cpp 189 ( 30): Poll result=0 on fd=5 Speed checking /dev/hda3 hdstress.cpp 189 ( 30): Poll result=0 on fd=5 Read/write of 8Mb took 3.78 seconds hdstress.cpp 189 ( 30): Poll Stressing /dev/hda: Spinning down. hdstress.cpp 189 ( 30): Poll result=0 on fd=5 Stressing /dev/hda: Spinning up. hdstress.cpp 189 ( 30): Poll result=0 on fd=5 hdstress.cpp 189 ( 30): Poll result=0 on fd=5 Stressing /dev/hda: Spinning down. hdstress.cpp 189 ( 30): Poll result=0 on fd=5 Stressing /dev/hda: Spinning up. hdstress.cpp 189 ( 30): Poll result=0 on fd=5 hdstress.cpp 189 ( 30): Poll result=0 on fd=5 Drive length is 19640880 blocks, seek testing hdstress.cpp 189 ( 30): Poll res Seek test complete: 40.98 seconds. hdstress.cpp 189 ( 30): Poll result=0 on fd=5 Stressing /dev/hda: Spinning down. hdstress.cpp 189 ( 30): Poll result=0 on fd=5 Stressing /dev/hda: Spinning up. hdstress.cpp 189 ( 30): Poll result=0 on fd=5 hdstress.cpp 189 ( 30): Poll result=0 on fd=5 Stressing /dev/hda: Spinning down. hdstress.cpp 189 ( 30): Poll result=0 on fd=5 Stressing /dev/hda: Spinning up. hdstress.cpp 189 ( 30): Poll result=0 on fd=5 hdstress.cpp 189 ( 30): Poll result=0 on fd Speed checking /dev/hda3 hdstress.cpp 189 ( 30): Poll result=0 on fd=5 Read/write of 8Mb took 3.21 seconds hdstress.cpp 189 ( 30): Poll result=0 on fd=5 Stressing /dev/hda: Spinning down. hdstress.cpp 189 ( 30): Poll result=0 on fd=5 Stressing /dev/hda: Spinning up. hdstress.cpp 189 ( 30): Poll result=0 on fd=5 hdstress.cpp 189 ( 30): Poll result=0 on fd=5 Stressing /dev/hda: Spinning down. hdstress.cpp 189 ( 30): Poll result=0 on fd=5 Stressing /dev/hda: Spinning up. hdstress.cpp 189 ( 30): Poll result=0 on fd=5 hdstress.cpp 189 ( 30): Poll result=0 on fd=5 Drive length is 19640880 blocks, seek testing hdstress.cpp 189 ( 30): Poll result=0 on fd=5 Seek test complete: 40.52 seconds. hdstress.cpp 189 ( 30): Poll result=0 on fd=5 Stressing /dev/hda: Spinning down. hdstress.cpp 189 ( 30): Poll result=0 on fd=5 Stressing /dev/hda: Spinning up. hdstress.cpp 189 ( 30): Poll result=0 on fd=5 hdstress.cpp 189 ( 30): Poll result=0 on fd=5 Stressing /dev/hda: hdstress.cpp 189 ( 30): Poll result=0 on fd=5 Stressing /dev/hda: Spinning up. hdstress.cpp 189 ( 30): Poll result=0 on fd=5 hdstress.cpp 189 ( 30): Poll result=0 on fd=5 Speed checking /dev/hda3 hdstress.cpp 189 ( 30): Poll result=0 on fd=5 Read/write of 8Mb took 3.36 seconds hdstress.cpp 189 ( 30): Poll result=0 on fd=5 Stressing /dev/hda: Spinning down. hdstress.cpp 189 ( 30): Poll result=0 on fd=5 Stressing /dev/hda: Spinning up. hdstress.cpp 189 ( 30): Poll result=0 on fd=5 hdstress.cpp 189 ( 30): Poll result=0 on fd=5 Stressing /dev/hda: Spinning down. hdstress.cpp 189 ( 30): Poll result=0 on fd=5 Stressing /dev/hda: Spinning up. hdstress.cpp 189 ( 30): Poll result=0 on fd=5 hdstress.cpp 189 ( 30): Poll result=0 on fd=5 Drive length is 19640880 blocks, seek testing
empeg-car bootstrap v1.02 20001106 (hugo@empeg.com) If there is anyone present who wants to upgrade the flash, let them speak now, or forever hold their peace...it seems not. Let fly the Penguins of Lin
e000 v1.04 Copying kernel... Calling linux kernel... Uncompressing Linux..................................... done, booting the kerne l. Linux version 2.2.14-rmk5-np17-empeg49 (mac@aphex.internal.empeg.com) (gcc versi on 2.95.3 20010315 (release)) #130 Mon Oct 22 18:52:07 BST 2001 Processor: Intel StrongARM-1100 revision 11 NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp. empeg-car player (hardware revision 9, serial number 40103738) Command line: mem=16m Calibrating delay loop... 207.67 B Memory: 15024k/16M available (964k code, 20k reserved, 372k data, 4k init) Dentry hash table entries: 2048 (order 2, 16k) Buffer cache hash table entries: 16384 (order 4, 64k) Page cache hash table entries: 4096 (order 2, 16k) POSIX conformance testing by UNIFIX Linux NET4.0 for Linux 2.2 Based upon Swansea University Computer Society NET3.039 NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP TCP: Hash tables configured (ehash 16384 bhash 16384) IrDA (tm) Protocols for Linux-2.2 (Dag Brattli) Linux-IrDA: IrCOMM protocol ( revision:Tue May 18 03:11:39 1999 ) ircomm_tty: virtual tty driver for IrCOMM ( revision:Wed May 26 00:49:11 1999 ) Starting kswapd v 1.5 SA1100 serial driver version 4.27 with no serial options enabled ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UART ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UART Signature is 67706d65 'empg' Scheduling custom logo. empeg display initialised. empeg dsp audio initialised empeg dsp mixer initialised empeg dsp initialised empeg audio-in initialised, CS4231A revision a0 empeg remote control/panel button initialised. empeg usb initialised, PDIUSBD12 id 1012 empeg state support initialised 0089/88c1 (save to d0004580). empeg RDS driver initialised empeg power-pic driver initialised (first boot) RAM disk driver initialized: 16 RAM disks of 4096K size empeg single channel IDE Probing primary interface... hda: FUJITSU MHM2100AT, ATA DISK drive hda: FUJITSU MHM2100AT, ATA DISK drive hda: FUJITSU MHM2100AT, ATA DISK hda: FUJITSU MHM2100AT, ATA DISK drive hda: FUJITSU MHM2100AT, ATA DISK drive hda: FUJITSU MHM2100AT, ATA DISK drive ide0 at 0x000-0x007,0x038 on irq 6 hda: FUJITSU MHM2100AT, 9590MB w/2048kB Cache, CHS=19485/16/63 empeg-flash driver initialized smc chip id/revision 0x3349 smc9194.c:v0.12 03/06/96 by Erik Stahlman (erik@vt.edu)
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0e:9 a Partition check: hda: hda1 < hda5 hda6 > hda2 hda3 hda4 RAMDISK: ext2 filesystem found at block 0 RAMDISK: Loading 320 blocks [1 disk] into ram disk... done. EXT2-fs warning: checktime reached, running e2fsck is recommended VFS: Mounted root (ext2 filesystem). empeg-pump v0.03 (19980601) Press Ctrl-A to enter pump...VFS: Mounted root (ext2 filesystem) readonly. change_root: old root has d_count=1 Trying to unmount old root ... okay Freeing unused kernel memory: 4k init player.cpp : 385:empeg-car 2.00 2003/04/01. Prolux 4 empeg car - 2.1434 Mar 26 2003 Vcb: 0x4086d000 r player.cpp : 385:empeg Prolux 4 empeg car - 2.1434 Mar 26 2003 Vcb: 0x4086d000
r player.cpp : 385:empeg-car 2.00 2003/04/01. Prolux 4 empeg car - 2.1434 Mar 26 2003 Vcb: 0x4086d000
empeg-car bootstrap v1.02 20001106 (hugo@empeg.com) If there is anyone present who wants to upgrade the flash, let them speak now, or forever hold their peace...it seems not. Let fly the Penguins of Linux!
e000 v1.04 Copying kernel... Calling linux kernel... Uncompressing Linux..................................... done, booting the kerne l. Linux version 2.2.17-rmk5-np17-empeg52-hijack-v422 (hijack@rtr.ca) (gcc version 2.95.3 20010315 (release)) #2 Mon Apr 4 22:44:52 EDT 2005 Processor: Intel StrongARM-1100 revision 11 Checking for extra DRAM: c1000000: wrote ffffffff, read e91ba9f0 NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp. empeg-car player (hardware revision 9, serial number 40103738) 16MB DRAM Command line: mem=16m Calibrating delay loop... 207.67 BogoMIPS Memory: 15008k/16M available (984k code, 20k reserved, 368k d Dentry hash table entries: 2048 (order 2, 16k) Buffer cache hash table entries: 16384 (order 4, 64k) Page cache hash table entries: 4096 (order 2, 16k) POSIX conformance testing by UNIFIX Linux NET4.0 for Linux 2.2 Based upon Swansea University Computer Society NET3.039 NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP TCP: Hash tables configured (ehash 16384 bhash 16384) IrDA (tm) Protocols for Linux-2.2 (Dag Brattli) Starting kswapd v 1.5 SA1100 serial driver version 4.27 with no serial options ena ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UART ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UART Signature is 67706d65 'empg' Found custom animation at offset 0x99b78 Tuner: loopback=0, ID=-1 Forced AC/Home mode Scheduling custom logo. empeg display initialised. empeg dsp audio initialised empeg dsp mixer initialised empeg dsp initialised empeg audio-in initialised, CS4231A revision a0 empeg remote control/panel button initialised. empeg usb initialised, PDIUSBD12 empeg state support initialised 0089/88c1 (save to d0004680). empeg RDS driver initialised empeg power-pic driver initialised (first boot) RAM disk driver initialized: 16 RAM disks of 4096K size empeg single channel IDE Probing primary interface... hda: FUJITSU MHM2100AT, ATA DISK drive hda: FUJITSU MHM2100AT, ATA DISK drive hda: FUJITSU MHM2100AT, ATA DISK drive hda: FUJITSU MHM2100AT, ATA DISK drive hda: FUJITSU MHM2100AT, ATA DISK drive hda: FUJITSU MHM2100AT, ATA DISK drive ide0 at 0x000-0x007,0x038 on irq 6 hda: FUJITSU MHM2100AT, 9590MB w/2048kB Cache, CHS=19485/16/63 empeg-flash driver initialized smc chip id/revision 0x3349 smc9194.c:v0.12 03/06/96 by Erik Stahlman (erik@vt.edu)
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0e:9 a Partition check: hda: hda1 < hda5 hda6 > hda2 hda3 hda4 RAMDISK: ext2 filesystem found at block 0 RAMDISK: Loading 320 blocks [1 disk] into ram disk... done. EXT2-fs warning: checktime reached, running e2fsck is recommended VFS: Mounted root (ext2 filesys empeg-pump v0.03 (19980601) Press Ctrl-A to enter pump...VFS: Mounted root (ext2 filesystem) readonly. change_root: old root has d_count=1 Trying to unmount old root ... okay Freeing unused kernel memory: 4k initTimezone: Atlantic/South_Georgia Hijack: intercepting config.ini
hijack: removed menu entry: "Serial Port Assignment" khttpd: listening on port 80 kftpd: listening on port 21 player.cpp : 385:empeg-car 2.00 2003/04/01. Prolux 4 empeg car - 2.1434 Mar 26 2003 Vcb: 0x4086d000
e000 v1.04 Copying kernel... Calling linux kernel... Uncompressing Linux..................................... done, booting the kerne l. Linux version 2.2.17-rmk5-np17-empeg52-hijack-v422 (hijack@rtr.ca) (gcc version 2.95.3 20010315 (release)) #2 Mon Apr 4 22:44:52 EDT 2005 Processor: Intel StrongARM-1100 revi Checking for extra DRAM: c1000000: wrote ffffffff, read e91ba9f0 NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp. empeg-car player (hardware revision 9, serial number 40103738) 16MB DRAM Command line: mem=16m Calibrating delay loop... 207.67 BogoMIPS Memory: 15008k/16M available (984k code, 20k reserved, 368k data, 4k init) Dentry hash table entries: 2048 (order 2, 16k) Buffer cache hash table entries: 16384 (order 4, 64k) Page cache hash table entries: 4096 (order 2, 16k) POSIX conformance testing by UNIFIX Linux NET4.0 for Linux 2.2 Based upon Swansea University Computer Society NET3.039 NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP TCP: Hash tables configured (ehash 16384 bhash 16384) IrDA (tm) Protocols for Linux-2.2 (Dag Brattli) Starting kswapd v 1.5 SA1100 serial driver version 4.27 with no serial options enabled ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UART ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UART Signature is 67706d65 'empg' Found custom animation at offset 0x99b78 Tuner: loopback=0, ID=-1 Forced AC/Home mode Scheduling custom logo. empeg display initialised. empeg dsp audio initialised empeg dsp mixer initialised empeg dsp initialised empeg audio-in initialised, CS4231A revision a0 empeg remote control/panel button initialised. empeg usb initialised, PDIUSBD12 id 1012 empeg state support initialised 0089/88c1 (save to d0004780). empeg RDS driver initialised empeg power-pic driver initialised RAM disk driver initialized: 16 RAM disks of 4096K size empeg single channel IDE Probing primary interface... hda: FUJITSU MHM2100AT, ATA DISK drive ide0 at 0x000-0x007,0x038 on irq 6 hda: FUJITSU MHM2100AT, 9590MB w/2048kB Cache, CHS=19485/16/63 empeg-flash driver initialized smc chip id/revision 0x3349 smc9194.c:v0.12 03/06/96 by Erik Stahlman (erik@vt.edu)
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0e:9 a Partition check: hda: hda1 < hda5 hda6 > hda2 hda3 hda4 RAMDISK: ext2 filesystem found at block 0 RAMDISK: Loading 320 blocks [1 disk] into ram disk... done. EXT2-fs warning: checktime reached, running e2fsck is recommended VFS: Mounted root (ext2 filesystem). empeg-pump v0.03 (19980601) Press Ctrl-A to enter pump...VFS: Mounted root (ext2 filesystem) readonly. change_root: old root has d_count=1 Trying to unmount old root ... okay Freeing unused kernel memory: 4k initTimezone: Atlantic/South_Georgia Hijack: intercepting config.ini
hijack: removed menu entry: "Serial khttpd: listening on port 80 kftpd: listening on port 21 player.cpp : 385:empeg-car 2.00 2003/04/01. Prolux 4 empeg car - 2.1434 Mar 26 2003 Vcb: 0x4086d000
e000 v1.04 Copying kernel... Calling linux kernel... Uncompressing Linux..................................... done, booting the kerne l. Linux version 2.2.17-rmk5-np17-empeg52-hijack-v422 (hijack@rtr.ca) (gcc versione0 at 0x000-0x007,0x038 on irq 6 hda: FUJITSU 2.95.3 20010315 (release)) #2 Mon Apr 4 22:44:52 EDT 2005 em Processor: Intel StrongARM-1100 revision 11 smc chip id/revision 0x3349 Checking for extra DRAM: smc9194.c:v0.12 03/06/ c1000000: wrote ffffffff, read e91ba9f0 NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp.AC 00:02:d7:28:0e:9 empeg-car player (hardware revision 9, serial number 40103738) 16MB DRAMa1 < hda5 hda6 > hda2 hda3 hda4 R Command line: mem=16mm found at block 0 Calibrating delay loop... 207.67 BogoMIPSDISK: Loading 320 blocks [1 disk] into ra Memory: 15008k/16M available (984k code, 20k reserved, 368k d change_root: old Based upon Swansea University Computer Society NET3.039rying to unmount old root ... okay NET4: Linux TCP/IP 1.0 for NET4.0el memory: 4k initempeg init 0.8 IP Protocols: ICMP, UDP, TCP I see TCP: Hash tables configured (ehash 16384 bhash 16384) Mounting proc Mounting first music IrDA (tm) Protocols for Linux-2.2 (Dag Brattli) mount /dev/hda4 as reiserfs but got error 19 Starting kswapd v 1.5 SA1100 serial driver version 4.27 with no serial options ena Tried to mount /dev/hdc4 Press 'q' now to go into Found custom animation at offset 0x99b78 Tuner: loopback=0, ID=-1 player.cpp : 38 Forced AC/Home mode3/04/01. Scheduling custom logo. Prolu empeg display initialised.26 2003 empeg dsp audio initialised4086d000 hda empeg dsp mixer initialisedK drive empeg dsp initialised: FUJITSU MHM2100AT, empeg audio-in initialised, CS4231A revision a0 hda: FUJITSU MHM2100AT, ATA DISK drive empeg remote control/panel button initialised.0-0x007,0x038 on irq 6 empeg usb initialised, PDIUSBD12 SMC9194: SMC91C94(r:9) at 0x400800 empeg single channel IDE MAC 00:02:d7:28:0e:9 Probing primary interface... hda: FUJITSU MHM2100AT, ATA DISK drive: hda: hda1 < hda5 hd smc9194.c:v0.12 03/06/96 by Erik Stahlman (erik@vt.edu)
#254330 - 15/04/2005 23:56
[Re: nahbrah]
I also just installed the developer software instead of the consumer software. In case that changes things
#254331 - 16/04/2005 00:01
[Re: nahbrah]
Here is the diagnostic test
0100 ram test starting 0110 testing ic 1 (0-15mb, low word) 0120 testing ic 2 (0-15mb, high word) 01f0 ram test done 0200 ide detect 0210 command issued 0220 drive id FUJITSU MHM2100AT 02f0 ide ok 0300 dsp/i2c test 03f0 dsp/i2c ok 0400 temperature detect 0410 temperature is 40 04f0 temperature ok 0500 usb detect 0510 usb rev 1012 05f0 usb ok 0600 ethernet detect 0610 ethernet rev 334b 06f0 ethernet ok 0700 cs4231 detect 0710 cs4231 rev a0 07f0 cs4231 ok 00f0 tests complete
#254332 - 19/04/2005 16:06
[Re: nahbrah]
I actually just turned it on throught he hyperterminal and unplugged the power instead of turning it off, so it will come on without me having to hit any buttons. BUT, when doing this i realized the remote also will not work any more.
By the way was anyone able to make anything out of the logs i gave? Or were they even the right logs?
#254333 - 22/04/2005 09:56
[Re: nahbrah]
Everything looks pretty normal there. Can you get a copy of config.ini This describes how to get to it: http://www.riocar.org/modules.php?op=mod...mp;faqent=72#72
#254334 - 22/04/2005 22:51
[Re: Shonky]
I went to "Tools" , "Edit Config.ini" and then just copied and pasted what was on there already and got this.
[synchronise] seq_num=9 [wendy] flag_amount=0 [custom] wendy= [searches] amount=0 [VisualFavourites_AM] count=0 [VisualFavourites_AUX] count=0 [VisualFavourites_DSP] count=0 [VisualFavourites_FM] count=0 [display] play_count=1 visual_names=1 caching=0 [kenwood] disabled=0 [menu] quit=0 sort_playlist=1 [shuffle] deduplicate=1 [hush] hushpercent=20 [volumecap] enabled=0 [ramp] disabled=0 [controls] stalk_side=none [tuner] region=us [Options] Name=nahbrah [User Info] Email= Phone= Name= [Network] Gateway=0.0.0.0 Netmask=0.0.0.0 IPAddress=0.0.0.0 DHCP=1 [sense] muteaction=0 mute=-1 [power] off_timeout=60000 [aux] source= title= artist=
#254335 - 22/04/2005 23:34
[Re: nahbrah]
Well, that looks pretty normal. Huh.
I'm not sure that I can visualize exactly what's happening, because all of the output looks reasonable. You have a mlord dock, right? Can you slowly describe what happens when you apply power to the player when it's not in the dock? Do you have telnetd installed? Have you tried running EmpegFace to see what it shows?
--Nathan
#254336 - 22/04/2005 23:35
[Re: Mataglap]
What's your custom logo? I'm clutching at straws here, but have you tried different boot logos? Could a logo be corrupt?
#254337 - 23/04/2005 01:04
[Re: Mataglap]
Nothing in a custom logo could cause a boot up problem as far as I know.
#254338 - 23/04/2005 11:46
No, i don't have a dock, but when i apply power it boots up and goes to the standby screen. The standby light that should normally blink after boot up does not come on after boot up. The player cannot be turned on after boot up unless i use the hyperterminal.
#254339 - 23/04/2005 11:57
[Re: nahbrah]
Quote: The player cannot be turned on after boot up unless i use the hyperterminal.
How do you mean, use Hyperterminal? Do you mean that the player's running, and you have to give it the serial command to get it to start playing music? If you do this, does the screen come on properly?
I assume that there is no sound output until you do this? In fact, does the sound come out once you've done this?
All of this suggests to me that maybe the display panel is not working -- i.e. the buttons aren't responding. Can we try to chase this possibility down a little more?
#254340 - 23/04/2005 12:00
[Re: Roger]
no, i don t think its the buttons because after i enter play in the hyperterminal and the player is on the buttons are fully functional.
#254341 - 24/04/2005 15:05
[Re: nahbrah]
Quote: after i enter play
What do you mean "enter play"? Do you mean you type in the word "play" and press Enter? Or something else?
#254342 - 24/04/2005 21:58
[Re: Roger]
I got it from the list of Serial Port Commands by pushing the space bar and then pushing enter in the terminal it tells the empeg to "play"
#254343 - 25/04/2005 00:38
[Re: nahbrah]
And when you do this, the screen comes on?
#254344 - 25/04/2005 00:47
Yep, and everything works as it should EXCEPT the remote (the original Rio remote) will not work and the standby light that, if i remember correctly, should turn off when the player is on, stays lit.
#254345 - 25/04/2005 01:28
[Re: nahbrah]
If it were in a docking sled, I'd say that your problem was 12 volts applied to the amp remote wire. Otherwise, you're talking about a very strange hardware fault, and Rob or Stu needs to take a look at it.
#254346 - 25/04/2005 10:43
[Re: nahbrah]
Loc: Brooklyn
Try this temporary fix:
When the unit is booting up, press the keys rapidly, Especially at the part when the unit turns off. I have the same problem, and until I can spare the time to find the short that is keeping my screen dim, and keeping it occasionally from booting up past the first screen, this seems to help by keeping the voltage going.
It sounds ridiculous, but it worked for me.
#254347 - 26/04/2005 04:16
[Re: JeepBastard]
Whoa, I haven't read this forum in a while. "nahbrah" is my brother... thanks guys for helping him track this down, I was stumped.
Kyle... Stu, as Tony mentioned, is in Mandeville, so you might wanna talk to him and arrange a meet up. It's about as far as N.O. on the other side of the lake.
#254348 - 26/04/2005 16:30
[Re: loren]
This is true, i am his brother...while listening to the empeg last night a message popped up for the first time....."segfault error".....maybe this will help
#254349 - 26/04/2005 19:16
[Re: nahbrah]
"segfault error" occurs "normally" from time to time for me when running v3alpha software. But it should be pretty rare on a stock player running v2final.
#254350 - 13/11/2005 22:45
This player is now at my house, as is Kyle, and I'm trying to troubleshoot it. It does exactly as he stated... really strange stuff.
Summary:
As the empeg boots, the screen is normal other than a faint increase in brightness followed by a slow dimming before it blips out and goes black once the player is running. From there, black screen, no Stdby LED, no button controls. To get the display to wake up you have to start the player playing via hyperterminal, then it pops right up, though the stdby LED stays on. The display is VERY dim, and on forced DC mode, the dimmer settings have NO effect at all.
EDIT: I also just checked his config.ini and it is really stripped down... does this mean anything:
[synchronise]
seq_num=25
[wendy]
flag_amount=0
[custom]
wendy=
[searches]
amount=0
count=0
count=0
count=0
count=0
John... have you had any luck tracking this down?
Any other troubleshooting tips? What would cause a constant dim screen? I'm going to open it up and see if I find anything in the mean time.
EDIT 2: I'm also checking the fuse mentioned in thie FAQ entry
Edited by loren (13/11/2005 23:04)
