#253528 - 05/04/2005 21:04 OMG I have tries everything I think!!! HELP!!!
PearlSC2
I have tries the Hyperterminal program to try to diagnose the problem, the list says everything is OK. Here is everything. How does it look... I still keep getting the hda: disk error multwrit_ or whatever how can I fix it so I can put some music on, I got some files on , but then it started giving me that error.
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v419 (hijack@rtr.ca) (gcc version
2.95.3 20010315 (release)) #2 Wed Mar 23 18:44:43 EST 2005
Processor: Intel StrongARM-1100 re
Checking for extra DRAM:
c1000000: wrote ffffffff, read e91ba9f0
empeg-car player (hardware revision 9, serial number 10101635) 16MB DRAM
Command line: mem=16m
Memory: 15008k/16M available (984k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004d00).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: TOSHIBA MK1017GAP, ATA DISK drive
hda: TOSHIBA MK1017GAP, 9590MB w/0kB Cache, CHS=19485/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:06:6
3
Partition check:
RAMDISK: Loading 320 blocks [1 di
empeg-pump v0.03 (19980601)
Mounting proc
Tried to mount /dev/hdc4
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To CompěStartin
g player
Timezone: PST8PDT
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
Vcb: 0x4086d
q
Restored terminal settings
Player exited normally: 0
Starting bash.
empeg:/empeg/bin# q
bash: q: command not found
empeg:/empeg/bin# e
bash: e: command not found
empeg:/empeg/bin# #!/bin/bash
bash: !/bin/bash: event not found
empeg:/empeg/bin#
0000 empeg-car (issue9) board test version 0.05 <hugo@empeg.com>
0100 ram test starting
0110 testing ic 1 (0-15mb, low word)
0120 testing ic 2 (0-15mb, high word)
01f0 ram test done
0200 ide detect
0210 command issued
0220 drive id TOSHIBA MK1017GAP
02f0 ide ok
0300 dsp/i2c test
03f0 dsp/i2c ok
0400 temperature detect
0410 temperature is 35
04f0 temperature ok
0500 usb detect
0510 usb rev 1012
05f0 usb ok
0600 ethernet detect
0610 ethernet rev 334b
06f0 ethernet ok
0700 cs4231 detect
0710 cs4231 rev a0
07f0 cs4231 ok
00f0 tests complete
#253529 - 05/04/2005 21:13 Re: OMG I have tries everything I think!!! HELP!!! [Re: PearlSC2]
PearlSC2
Here are ther errors
hda: disk error: write_intr
hda: disk error: irq timeout
hda: disk error: read_intr
Those are the only three so far. Can anybody shed some light on the situation, software issue maybe??
#253530 - 06/04/2005 01:09 Re: OMG I have tries everything I think!!! HELP!!! [Re: PearlSC2]
It is unlikely to be a software issue. It is definitely one of the problems listed here. Rememeber that the cable and the IDE header are not the only two problems listed there. There is a large extensive list of possible causes, including a bad disk drive. Make sure to check every single possible cause.
#253531 - 06/04/2005 01:20 Re: OMG I have tries everything I think!!! HELP!!! [Re: tfabris]
PearlSC2
What about the master/slave jumper, which piece is this?? Maybe that is loose?? Also, reading through all these things does not seem to ring a bell as far as the loose header/solder connectors or the copper, the cable is tight on every end and I have even tried switching it to the end cable to see if the problem persists, which it does. Are these errors related, or, I dunno, taking this thing apart and put back together and apart again I wish it would just go away, but since it doesn't take anymore music than roughly 4 cd's it leads me too think that it is a bad disk drive, cause the initial 4 cd's or so get loaded up without a hitch, it is not until I try a 5th cd that these messages appear. Other than that the unit works great.
Jay
Jay
Edited by PearlSC2 (06/04/2005 01:29)
#253532 - 06/04/2005 01:43 Re: OMG I have tries everything I think!!! HELP!!! [Re: PearlSC2]
This reminds me.. we really have to get a statically-linked copy of "smartctl" for running on the Empeg to diagnose HD issues accurately.
#253533 - 06/04/2005 12:58 Re: OMG I have tries everything I think!!! HELP!!! [Re: PearlSC2]
Have you tried erasing the hard disks completely, running the builder image to repartition and reformat the disks?
#253534 - 06/04/2005 20:05 Re: OMG I have tries everything I think!!! HELP!!! [Re: tfabris]
PearlSC2
No, but if I did I would need instruction to do so.
Jay
#253535 - 06/04/2005 21:38 Re: OMG I have tries everything I think!!! HELP!!! [Re: PearlSC2]
Instructions for using the builder image are in the disk upgrade guide, here. You can use the builder image without opening the player up.
Just remember you will get the "disk appears to be already built" message and you will have to press Enter in the terminal program to make it build the disk.
