#251703 - 14/03/2005 21:17 FSCK Question???
bodybag
Loc: Southern California
One of my players keeps having trouble rebuilding it's databases & playlists. Someone here recommended I run e2fsck. I am currently running it and came to a point where this happened:
Pass 1: Checking inodes, blocks, and sizes
Deleted inode 258 has zero dtime. Fix? yes
Now what do I do? It appears that it has stopped waiting for me to answer the question? I typed "yes" and hit enter but nothing happened. Can someone lend a hand here.
Bodybag - So Cal
Not a Whiner any more!!!
#251704 - 14/03/2005 21:21 Re: FSCK Question??? [Re: bodybag]
It's probably just continuing to check. Can you hear the drive doing anything? It isn't going to be massive grinding, but if you can hear head movement at all, you should be okay. It'll take quite a while, especially on a large drive.
#251705 - 14/03/2005 21:26 Re: FSCK Question??? [Re: wfaulk]
bodybag
I can barely tell, but I think it's still chugging along. It's mounted in one of Mark's home docking stations, so that's making it pretty tough to hear though. I'll just wait it out and see what happens. Any idea how long it might take for dual 80gb drives. I guess it's really only doing one at a time based on the command I sent in HT.
Bodybag - So Cal
#251706 - 14/03/2005 21:38 Re: FSCK Question??? [Re: bodybag]
bodybag
Looks good so far. Got through the long pause and found some other issues to complain about and is now checking something else (ref count or group structure). thanks for your quick help!
Bodybag - So Cal
#251707 - 14/03/2005 21:43 Re: FSCK Question??? [Re: bodybag]
/me updates that FAQ entry to indicate that there may be long pauses.
#251708 - 14/03/2005 21:48 Re: FSCK Question??? [Re: tfabris]
bodybag
"mind-bogglingly"
Is that a word?
Bodybag - So Cal
#251709 - 14/03/2005 21:54 Re: FSCK Question??? [Re: bodybag]
It is if you're a fan of Douglas Adams.
#251710 - 14/03/2005 21:59 Re: FSCK Question??? [Re: tfabris]
bodybag
Shwoooooooooosh... right over my head... I guess I'll Google Douglas Adams and see what this meant. Thanks Tony for the FAQ, it's an awesome resource.
Bodybag - So Cal
#251711 - 14/03/2005 22:13 Re: FSCK Question??? [Re: bodybag]
Quite welcome.
I just meant that it's a phrase Douglas used in his writing. He'd often deliberately overload common words and phrases like that for humorous effect.
#251712 - 15/03/2005 12:36 Re: FSCK Question??? [Re: tfabris]
Ezekiel
Loc: NH USA
Now where did I put my Pan Galactic Gargle Blaster? It was here a minute ago; hey! where'd that mattress come from?
#251713 - 15/03/2005 14:14 Re: FSCK Question??? [Re: tfabris]
Might also be worth pointing out that the '-y' in the command line will answer yes to any questions, which is why it's displaying "yes" in the output.
