Page 3 of 3 < 1 2 3
#249537 - 02/03/2005 05:03 Re: memory boards nearing actuality [Re: PaulWay]
I know, it was kind of a chip (cheap) shot, but I didn't think I could count on someone else doing it for me.
#249538 - 02/03/2005 08:57 Re: memory boards nearing actuality [Re: canuckInOR]
I can't believe I started this...
#249539 - 03/03/2005 05:07 Re: memory boards nearing actuality [Re: pgrzelak]
I was starting to feel guilty about the string of puns, but I'd wager a couple poker tokens that it was just the chipotle in the burrito I had for dinner.
#249540 - 03/03/2005 15:42 Re: memory boards nearing actuality [Re: canuckInOR]
Or maybe it was the Tostitos.
#249541 - 03/03/2005 15:54 Re: memory boards nearing actuality [Re: mlord]
Greetings!
I do not want this to be lost. Could someone with just a hex editor under windows be able to modify the correct point in the player binary to make this happen? And would the same offsets apply? I am running 2.01, and I did not see that pattern at the mentioned location.
#249542 - 03/03/2005 16:42 Re: memory boards nearing actuality [Re: pgrzelak]
Oh heck, I'll just write an empeg app to do it correctly for whatever unit it gets run on.
#249543 - 03/03/2005 17:23 Re: memory boards nearing actuality [Re: mlord]
Hahahahahaha! I knew it was just a matter of time...
#249544 - 03/03/2005 17:39 Re: memory boards nearing actuality [Re: peter]
And why does this all appear to be Big-Endian byte order? I though we were using little-endian mode in the Empeg?
We are. Why is it all appearing in 16-bit quantities? You should be changing the 32-bit, word-aligned, quantity 0x00007000 to 0x0000AC42 (not 0x000AC420).
Peter: Shouldn't that be 0x0000BC42 ???
EDIT: to answer my own question: NO! The 0x1000 difference is for the *other* dynamic data in that partition, stored in front of the sector-per-fid area.
Edited by mlord (04/03/2005 14:17)
Page 3 of 3 < 1 2 3
