#249246 - 13/02/2005 21:15 Loud hard drive, possibly faulty?
JonD
I just got a Fujitsu MHL2300AT drive to upgrade my empeg with, and then I read that that specific model has had some pretty bad luck. Anyway I installed the drive and everything went fine until I plugged it in, and when it spun up I couldn't believe how loud it was. Note that the empeg was completely open, but even when I put the top back on later, it was still loud. The stock 10gb Travelstar I had in mine was silent .
I have a sound clip here (wav file). When you hear the first click, that is the power cable being plugged in. Then the drive spins up. For reference, the background noise you hear in the first couple seconds is the noise of my nearby computer fans. So this drive is pretty damn loud. Is that at all normal? There is no way I'm leaving a drive this loud in my empeg.
This may or may not be helpful, but here is the bootup info:
 ˙If there is anyone present who wants to upgrade the flash, let them speak now,
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg51 (mac@aphex) (gcc version 2.95.3 20010315
(release)) #17 Wed Jul 24 18:23:20 BST 2002
empeg-car player (hardware revision 9, serial number 30102826)
Command line: mem=16m
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 20706d65 'emp '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005680).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: FUJITSU MHL2300AT, ATA DISK drive
hda: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0b:0
a
Partition check:
hda: [PTBL] [3648/255/63] hda1 < hda5 hda6 > hda2 hda3 hda4
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...hange_root: old root has d_count=1
Freeing player.cpp : 385:empeg-car 2.00-beta13 2002/07/24.
Vcb: 0x4086d000
edit: The following happened when the drive was being stress tested. It did spin up and down a few times, then went into a seek test, and after that, this kept repeating indefinately:
 Spindown failed (-1) errno=9 'Bad file descriptor'
hdstress.cpp 189 ( 29): Poll result=0 on fd=5
Stressing /dev/hda: Spinning down.
Edited by JonD (13/02/2005 21:26)
#249247 - 13/02/2005 21:41 Re: Loud hard drive, possibly faulty? [Re: JonD]
A couple of my older Travelstar drives (from laptops etc..) are as noisy as that one now. If your drive is new, TAKE IT BACK. Otherwise.. it's just getting old.
#249248 - 13/02/2005 21:46 Re: Loud hard drive, possibly faulty? [Re: JonD]
JonD
Well I bought it on eBay, but the description read "used and good working condition". I would have expected a bit different description based on the noise I'm hearing. I have emailed the seller and I'll see what he says.
*sigh* I was only trying to save some money (I got the drive for $49 shipped!).
#249249 - 14/02/2005 01:33 Re: Loud hard drive, possibly faulty? [Re: JonD]
Sounds both used and working to me!
#249250 - 20/02/2005 21:43 Re: Loud hard drive, possibly faulty? [Re: mlord]
JonD
what about it failing the stress test though?
