#248132 - 31/01/2005 05:19 FireWire Drive: Tell Windows it's removable?
Googling and MSKB searching isn't producing any results, I thought I'd give it a shot here...
I have a USB flash card reader that appears as a disk drive in Windows 2000. The flash reader shows up as a removable drive icon, and when I right-click on the icon there is an "eject" option, which flushes the write cache prior to pulling the card.
I have a firewire external hard disk that appears as a disk drive in Windows 2000. The firewire disk shows up as a regular disk icon, and I do not have the "eject" option when I right-click on it.
I'm able to eject the firewire drive if I dig into the control panel's add/remove hardware wizard. But it would be nice to have the convenient rightclick just like the flash reader has.
Anyone know how to tell Windows that the firewire drive is removable, so it will behave like the flash drive and allow me to right-click eject it?
I honestly don't expect anyone to have an answer, but this BBS has surprised me in the past, so...
#248133 - 31/01/2005 05:46 Re: FireWire Drive: Tell Windows it's removable? [Re: tfabris]
bonzi
Not really an answer, and risking to state the obvious, but my USB disk doesn't have an 'eject' option in context menu, either. However, I don't have to go to control panel, as 'safely remove hardware' icon sits in the tray, requiring only two clicks (icon itself and the particular USB peripheral) for safe removal. Firewire hardware doesn't provoke similar behavior?
#248134 - 31/01/2005 06:45 Re: FireWire Drive: Tell Windows it's removable? [Re: bonzi]
I could activate that stupid icon and its correspondingly stupid wizard that requires far too many clicks if I wanted to, yeah. But that's not the question I asked.
#248135 - 31/01/2005 08:26 Re: FireWire Drive: Tell Windows it's removable? [Re: tfabris]
It's a bit that gets set in the SCSI device description. Unless Microsoft have deliberately added an override to Windows, your best bet is to take the enclosure to bits to see whether there's a jumper on the firewire-to-IDE bridge board. If the same company use the same bridge board for ejectable devices such as CD-ROMs, this is quite likely.
#248136 - 31/01/2005 08:53 Re: FireWire Drive: Tell Windows it's removable? [Re: tfabris]
bonzi
If you left-click on it (or perhaps double-click), then the stupid wizard is not launched; you only get a list of drives and need just one additional click. But 'eject' in the context menu would be better...
#248137 - 31/01/2005 13:56 Re: FireWire Drive: Tell Windows it's removable? [Re: tfabris]
StigOE
I don't know what kind of firewire disk you have, but my WD firewire disk is easily removed by left-clicking on 'safely remove hardware'-icon and clicking on the corresponding drive-letter. No need for a lot of wizards. Getting a 'Eject' option would only save you one click anyway...
Stig
#248138 - 31/01/2005 14:49 Re: FireWire Drive: Tell Windows it's removable? [Re: tfabris]
You only have to click TWICE in the tray icon to eject anything. Click once with the LMB to pop up a small list (no windows) and then select the drive again with LMB. That's it. no windows or other confirmation alerts pop up (none that requre you to click beyond those two)
If you want an EJECT command on all removable drives, you'll have to switch to Mac OS X.
#248139 - 31/01/2005 15:28 Re: FireWire Drive: Tell Windows it's removable? [Re: peter]
Interesting! I'll have to look into this more. I'll google and see if anyone has shown examples of this elsewhere.
#248140 - 31/01/2005 21:21 Re: FireWire Drive: Tell Windows it's removable? [Re: hybrid8]
StigOE
That's not quite right if you're using Win2000, as you will get a messagebox with '<Something> can now safely be removed' (something like that), which you have to acknowledge. With XP your statement would be true. Allthough in this case it's still correct since, IIRC, Tony has hacked away the messagebox.
Stig
