#247459 - 25/01/2005 21:43 Does linux 'dd' copy boot blocks?
TigerJimmy
Hey you guys,
If I use dd with disk devices like:
dd if=/dev/hda of=/dev/hdb
this will copy the boot blocks and everything, right?
Thanks,
Jim
#247460 - 25/01/2005 21:56 Re: Does linux 'dd' copy boot blocks? [Re: TigerJimmy]
It will copy everything. The new drive must be equal or greater size however.
#247461 - 25/01/2005 23:21 Re: Does linux 'dd' copy boot blocks? [Re: TigerJimmy]
Yup.
But so would a simpler "cp /dev/hda /dev/hdb" or a "cat /dev/hda >/dev/hdb".
#247462 - 25/01/2005 23:36 Re: Does linux 'dd' copy boot blocks? [Re: mlord]
TigerJimmy
Really? Cool. Why is it simpler, though? Which is fastest?
Thanks,
Jim
#247463 - 26/01/2005 00:24 Re: Does linux 'dd' copy boot blocks? [Re: TigerJimmy]
I think they're all comparable in speed, since Linux is so good at optimizing streaming disk read/write operations.
"cat" is probably the slowest of the three, due to pipe buffering defaults. But cp and dd should be equal with default parameters. One might be able to tweak out a slightly faster time with dd using an appropriate bs=nnn parameter.
#247464 - 26/01/2005 04:45 Re: Does linux 'dd' copy boot blocks? [Re: mlord]
TigerJimmy
Cool. Thanks you guys.
Mark, a while back you mentioned you increased the disk throughput on your little biscuit-tin server by tweaking, mostly a custom kernel. Did the custom kernel have weird IO stuff in it, or was it a kernel with all of the unneeded stuff stripped out? Just curious how that performance increase was achieved.
Thanks again you guys. I'm off to make a current backup of my mp3 collection.
Jim
#247465 - 26/01/2005 21:59 Re: Does linux 'dd' copy boot blocks? [Re: TigerJimmy]
I think I merely fixed an efficiency bug in the IDE driver (placed there after I passed it on to others). My 80GB drive understands LBA48 commands, which have nearly double the setup overhead (microseconds) of the older LBA28 commands. The IDE driver, by default, tries to use LBA48 exclusively whenever a drive claims to support it.. EVEN WHEN NOT NEEDED!!!
Duh.. So I just hacked it to not do LBA48 when not needed, which is nearly 100% of the time on my 80GB drive (all of which falls into the LBA28 addressible space).
A small win, not much difference, but it saves some CPU horsepower for other things, and removes 3-5 microseconds from each disk I/O operation.
Edited by mlord (27/01/2005 00:32)
#247466 - 26/01/2005 22:24 Re: Does linux 'dd' copy boot blocks? [Re: mlord]
schofiel
Listen!
The sound of a true craftsman in action...
#247467 - 27/01/2005 03:15 Re: Does linux 'dd' copy boot blocks? [Re: schofiel]
TigerJimmy
No kidding. I am not worthy...
Thanks again, Mark.
