Page 2 of 2 < 1 2
#246697 - 02/11/2005 20:39 Re: GPSApp users: MapsOnUs got good. [Re: tfabris]
Okay, there's a function in the old mapsonus parse routine that looks like this:
# create a route as a combination of 'shape' and 'turn' information
# make sure we discard duplicate records.
waypoints = []
for i in range(-1, len(coords)):
if route.has_key(i):
if len(waypoints) and waypoints[-1].coord == coords[i]:
del waypoints[-1]
waypoints.append(route[i])
else:
if waypoints[-1].coord != coords[i]:
waypoints.append(Wpoint(coords[i]))
return waypoints
The matching code in the new routine seems to be
h.segments[len(h.coords)-1] = h.destination
wpoints = []
for i in range(len(h.coords)):
wpoints.append(Wpoint(h.coords[i], h.segments.get(i)))
return wpoints
But I don't think a direct replacement will work because objects like "route" don't exist in the new code. Or am I reading that wrong?
#246698 - 02/11/2005 20:46 Re: GPSApp users: MapsOnUs got good. [Re: tfabris]
In the meantime, I'm working on a really complete "Strip" statement for the top of the script. Working OK so far, I have to throw a bunch of test cases at it next.
#246699 - 02/11/2005 21:01 Re: GPSApp users: MapsOnUs got good. [Re: tfabris]
The obvious thing to do would be to check on output to see if the line it's getting ready to print is the same as the last line it printed. You need to be careful about the descriptions, though.
#246700 - 02/11/2005 21:14 Re: GPSApp users: MapsOnUs got good. [Re: wfaulk]
I haven't even begun to test this. Not even run it through the interpreter to make sure the syntax is right.
268703-parse_google.py (483 downloads)
#246701 - 02/11/2005 21:46 Re: GPSApp users: MapsOnUs got good. [Re: wfaulk]
Naw, that one doesn't produce any file as output. Thanks for the stab at it. Perhaps you'll get a chance to run it through the interpreter soon?
#246702 - 02/11/2005 21:55 Re: GPSApp users: MapsOnUs got good. [Re: tfabris]
By the way, if anyone wants it, I've got a strip command that's working pretty well so far in my test cases. The line is:
discard="((Start|End)\sPoint|follow|Continue onto|Continue on|continue|Continue|bears?|Bear|bear|turn|TURN|Turn |Go |into the |Take the|Take |Merge into|into|to |Set by click|sharply|left at|right at|left|right|straight|onto|as road goes into|as it|Head\s(North|West|East|South)\son)\s?"
And you have to chage the comment mark here so that the strip command gets called:
self.desc = re.sub(discard, "", desc).strip()
#self.desc = desc.strip()
#246703 - 02/11/2005 22:00 Re: GPSApp users: MapsOnUs got good. [Re: tfabris]
jaharkes
Here is a version that removes duplicates from the route (and which doesn't do datum conversion).
268708-parse_google.py (475 downloads)
#246704 - 02/11/2005 22:00 Re: GPSApp users: MapsOnUs got good. [Re: tfabris]
Okay. A couple of syntax errors. Here it is again.
268709-parse_google.py (490 downloads)
#246705 - 02/11/2005 22:03 Re: GPSApp users: MapsOnUs got good. [Re: wfaulk]
WOOO! SIMULTANEOUSLY!!!
I love you guys, you rock. So much.
#246706 - 02/11/2005 22:15 Re: GPSApp users: MapsOnUs got good. [Re: tfabris]
Just tried Jan's version. Works great!
Didn't try yours, yet, Bitt, sorry. Grabbed the first one my mouse fell upon, and it works.
YAY, DIRECTIONS FOR GPSAPP WORK AGAIN!
REJOICE!
So, Jan, you can update your script with the modified character-stripping commands I posted earlier in the thread, and put it up at the GPSapp web site. And if you fix up the instructions to describe how to use it with Google instead of Mapsonus, then I'll edit the FAQ to remove the note about how mapsonus stopped working.
#246707 - 03/11/2005 00:01 Re: GPSApp users: MapsOnUs got good. [Re: tfabris]
jaharkes
Ok, ok, and... ok. Haven't actually updated the tarball or CVS, just included a description and link to the parse_google script on the gpsapp page.
#246708 - 03/11/2005 00:38 Re: GPSApp users: MapsOnUs got good. [Re: jaharkes]
Cool.
Thanks everyone, for all the help.
Now, that's one more year I can go without dropping the cash on a nav system.
#246709 - 03/11/2005 03:59 Re: GPSApp users: MapsOnUs got good. [Re: tfabris]
I just took an actual drive with some mapping data using this script, and it worked perfectly. The Google map data is very accurate, moreso than I was used to seeing with mapsonus.
Awesome.
#246710 - 13/01/2006 20:55 Re: GPSApp users: MapsOnUs got good. [Re: tfabris]
Did Google Maps just change the output format of their web page?
I just tried converting a couple sets of directions with Parse_google.py and got errors. Is anyone else besides me using Parse_google.py and do you get the same problem?
Page 2 of 2 < 1 2
