#245573 - 06/01/2005 16:00
HD Upgrade Can't Communicate With Player
I have just installed a new Seagate 100 GB HD and for starters I really don't know how to save the hyperterminal profile as an .ht file on the hard disk. I was able to see the text scroll down the hyperterminal screen and the last line of text reads as this: Kernel panic: VFS: Unable to mount root fs on 03:05 and this is as far as I can get. My keyboard commands do not work even after unplugging the player and pluging it in again. Once the commands work should my next move to get the Disk Builder utility upgrade?
#245574 - 06/01/2005 16:04
Re: HD Upgrade Can't Communicate With Player
[Re: Gallagher419]
Are you aware of the Drive Upgrade guide? If not, go read that first.
If so, is the new one the only drive? If so, you'll definitely have to run the disk builder. It'required before you can install any software or music.
If it's a secondary drive, did you set the jumper(s) correctly? Check the old drive, too.
#245575 - 06/01/2005 16:34
I was going step by step with the Drive Upgrade section and it is the only HD. Actually on a whim I unplugged the player ran the disk builder plugged the player in and started hyper all over again and it is currently doing a disk stress-testing loop.
#245576 - 06/01/2005 16:43
[Re: Gallagher419]
The stress test is an infinite loop. Reboot the player, and capture and post the boot to a file with hyperterminal. The player should work at this point, but it would not hurt to see the boot results.
#245577 - 06/01/2005 16:59
[Re: pgrzelak]
Paul thanks I did just that and I upgraded the player software and I now see "end of playlist" on the screen so it looks like it worked. Now I'm going to put some music on it and hopefully I did everything correctly!
#245578 - 06/01/2005 17:18
[Re: Gallagher419]
It sounds like everything worked well. It was probably a brand new hard drive - the builder would have asked for a keystroke if it had been already been "built". Try putting a test track or two on. If that works, you are ok. If you run into trouble you might need to rerun the builder a second time (known bug / glitch).
#245579 - 06/01/2005 17:25
[Re: pgrzelak]
My only problem now is I have upgraded Emplode with the USB drivers and it constanly shuts down. It loads and shuts right down.
#245580 - 06/01/2005 17:38
[Re: Gallagher419]
The player is up and running? Emplode is shutting down immediately on loading? Crashing?
Ok... Hmmm... You ran the builder code. Did you run the upgrade file afterward to load the player? Your last message gave that impression (end of playlist). If so, do you have the developer version and can you take a boot log of the player? I just want to eliminate that as a problem.
The version of emplode and the player software need to match, but if emplode is crashing immediately, that implies a different kind of problem (bad drivers, possibly need to reinstall emplode).
#245581 - 06/01/2005 17:47
[Re: Gallagher419]
I would uninstall emplode and then re-install with 2.10 which matches the player firmware 2.0 Final. BEFORE trying to use USB to connect with the player, first re-blow 2.0 onto the player with the upgrader over serial. THEN install the USB driver for XP (make sure you use the right one) using the instructions in the README. Without starting up emplode, plug in the player to USB and then power it up. Let it be recognised. When it's recognised, go check the hardware list in the system applet on the control panel to see if it's functioning properly. Finally, start up emplode. While it is starting up the initial search, clcik on OPTIONS. Configure it for serial and USB only initially, even if you want to later connect over ethernet.
#245582 - 06/01/2005 20:39
[Re: Gallagher419]
Can someone tell me how to wipe the new hard drive clean I think I may have done something wrong and I would like to start over from the beginning.
#245583 - 06/01/2005 20:45
[Re: Gallagher419]
The "Builder" image will do that for you.
#245584 - 06/01/2005 20:51
[Re: SE_Sport_Driver]
OK, when I run Emplode all that comes up is the select player window and the flashlight never stops. I must have done something wrong. On the player all I see right now is "drivers wanted and a V W symbol. When I unplug the player and plug it back in it says Rio and goes right to the V W symbol. Can someone help a DUMBASS out? I don't know what I did but I'm P.O. at myself!!!!
#245585 - 06/01/2005 20:56
[Re: Gallagher419]
Get a boot log and post it here. Start up hyperterminal, click Transfer->Capture Text and enter a filename you can find later. Then apply power to the empeg. After it's done, click Transfer->Capture Text->Stop. Then post that file here.
Tony, you may want to add how to capture a boot log to the FAQ.
#245586 - 06/01/2005 20:59
Quote: Tony, you may want to add how to capture a boot log to the FAQ.
Yeah, I think it says you copy and paste, but that XP version of hyperterminal screws up copy and paste, so I'll put in the capture thing.
#245587 - 06/01/2005 21:08
I may sound stupid on here but can you tell me how to do a boot log so I can post it. To all those who are helping THANK YOU!!!!!!
#245588 - 06/01/2005 21:12
[Re: Gallagher419]
You need to turn the capture option of hyperterminal on (menu option "Transfer" and "capture text") saving this to a local file. You then need to attach this file to your posting.
I suspect that you may need to rerun the builder, reinstall the player software and perhaps wipe out the boot animation. Not a difficult thing, step by step...
#245589 - 06/01/2005 21:15
[Re: Gallagher419]
This is what hyperterminal says;
empeg-car bootstrap v1.02 20001106 (hugo@empeg.com) If there is anyone present who wants to upgrade the flash, let them speak now, or forever hold their peace...it seems not. Let fly the Penguins of Linux!
e000 v1.04 Copying kernel... Calling linux kernel... Uncompressing Linux..................................... done, booting the kerne l. Linux version 2.2.14-rmk5-np17-empeg49 (mac@aphex.internal.empeg.com) (gcc versi on 2.95.3 20010315 (release)) #130 Mon Oct 22 18:52:07 BST 2001 Processor: Intel StrongARM-1 NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp. empeg-car player (hardware revision 9, serial number 30102798) Command line: mem=16m Calibrating delay loop... 207.67 BogoMIPS Memory: 15024k/16M available (964k code, 20k reserved, 372k data, 4k init) Dentry hash table entries: 2048 (order 2, 16k) Buffer cache hash table entries: 16384 (order 4, 64k) Page cache hash table entries: 4096 (order 2, 16k) POSIX conformance testing by UNIFIX Linux NET4.0 for Linux 2.2 Based upon Swansea Universit NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP TCP: Hash tables configured (ehash 16384 bhash 16384) IrDA (tm) Protocols for Linux-2.2 (Dag Brattli) Linux-IrDA: IrCOMM protocol ( revision:Tue May 18 03:11:39 1999 ) ircomm_tty: virtual tty driver for IrCOMM ( revision:Wed May 26 00:49:11 1999 ) Starting kswapd v 1.5 SA1100 serial driver version 4.27 with no serial options enabled ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UART ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UART Signature is 636f6972 'rioc' Scheduling custom logo. empeg display initialised. empeg dsp audio initialised empeg dsp mixer initialised empeg dsp initialised empeg audio-in initialised, CS4231A revision a0 empeg remote control/panel button initialised. empeg usb initialised, PDIUSBD12 id 1012 empeg state support initialised 0089/88c1 (save to d0004d80). empeg RDS driver initialised empeg power-pic driver initialised (first boot) RAM disk driver initialized: 16 RAM empeg single channel IDE Probing primary interface... hda: ST9100823A, ATA DISK drive hda: ST9100823A, ATA DISK drive hda: ST9100823A, ATA DISK drive hda: ST9100823A, ATA DISK drive hda: ST9100823A, ATA DISK drive hda: ST9100823A, ATA DISK drive ide0 at 0x000-0x007,0x038 on irq 6 hda: ST9100823A, 95396MB w/8192kB Cache, CHS=12161/255/63 empeg-flash driver initialized smc chip id/revision 0x3349 smc9194.c:v0.12 03/06/96 by Erik Stahlman (erik@vt.edu)
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0a:e e Partition check: hda: hda1 < hda5 hda6 > hda2 hda3 hda4 RAMDISK: ext2 filesystem found at block 0 RAMDISK: Loading 320 blocks [1 disk] into ram disk... done. VFS: Mounted root (ext2 filesystem). empeg-pump v0.03 (19980601) Press Ctrl-A to enter pump...VFS: Mounted root (ext2 filesystem) readonly. change_root: old root has d_count=1 Trying to unmount old root ... okay Freeing unused kernel memory: 4k initinit: error in lo
#245590 - 06/01/2005 21:28
[Re: Gallagher419]
I ran the builder image just before I ran hyperterminal and those were the results that you see above. What should my next move be?
#245591 - 06/01/2005 21:29
[Re: Gallagher419]
Did you reapply actual player software?
#245592 - 06/01/2005 21:45
Should I just install the player software without having to run hyperterminal again?
#245593 - 06/01/2005 22:26
[Re: Gallagher419]
You shouldn't need to run Hyperterminal again unless something else goes wrong. In fact, if you leave it running, it may interfere with the software upload process.
#245594 - 06/01/2005 22:26
[Re: Gallagher419]
Yes. I have just realised what you said earlier - you have gone to a 100M disk. The builder doesn't work correctly for this size disk. I recall the symptoms you are now describing happened to me twice this summer on 80G disks. What you have to do is install the developer version after the builder has run on the disk, then read the article by Roger Lipscombe on his home page (I forget where it is now - www.differentpla.net?). You then manually chop up the disk some more, then blow the normal 2.0 consumer final. This is complex. If you are already having trouble upgrading at the moment, you might not be able to handle this yourself without help, and a lot of patience on your part. You VERY definitely need to keep your cool while doing it.
#245595 - 06/01/2005 22:27
[Re: schofiel]
Oh. Duh. Good point.
#245596 - 06/01/2005 23:01
[Re: Gallagher419]
Ok I see then I'm not as dumb as I think! I'm in the process of downloading the developer version right now. If all else fails I will install the original 10GB HD then eventually send the player to Eutronix and have them take care of that pesky 100 for me. Thanks!
#245597 - 06/01/2005 23:52
[Re: Gallagher419]
One thing I don't understand is at one point I had the hard drive working correctly because I had an "end of playlist" message on the player. The problem didn't start until I started Emplode and tried to use the USB port and it kept shutting Emplode down. Now as a result of that I have a "Drivers Wanted" message. I don't understand why the player goes to that message every time it powers up. I'm thinking that if I would have used the serial port instead of the USB I might not be having this problem.
#245598 - 06/01/2005 23:53
[Re: schofiel]
Loc: East Coast, USA
Hm, that's what I thought. It brought to mind all the talk of "a new builder image."
But this happens for 80 gig disks also? I added an 80 gig along side a 30 gig, used the standard builder, old Emplode with 1.03 developer software. Everything seemed to work just fine.
Sure, I haven't filled the 80 gig so I don't know it's 100% good, but does the current builder not make a big enough partition or something? Will I see this as a problem eventually (even though Emplode reports the correct free space size)? Sorry for the thread hijack; can we consider it a "supplementary"?
#245599 - 06/01/2005 23:56
[Re: FireFox31]
I now have this message on the player Builder image Drive(s) appear to be already built
what is my next step?
#245601 - 07/01/2005 00:54
[Re: Gallagher419]
I managed to use the old builder this summer on my Mk2a with an 80gb drive, but I do remember so odd errors that seemed to work themselves out. Maybe we finally need to get on with that new builder!
#245602 - 07/01/2005 07:08
[Re: Gallagher419]
Read the FAQ?
