#244791 - 29/12/2004 02:35 Problems downloading from jemplode
frekin
I cannot seem to get any files to download from the latest version of jemplode. I just successfully added a new hard drive to my MkIIa. Afterward, I added the newest Hijack and tried everything out. I can connect via ftp (currently everything is set to the defaults), access the Charcoalgray interface, and download files properly using Rio emplode. Unfortunately, I would like to download all my playlists and files with the directory structure intact. When I attempt to download using jemplode, I always receive the following message:
Unable to get an input stream onto the requested FID.
It correctly creates the required directories,and fills them with files which have the correct names, but all the files have 0 length.
Can anyone help me troubleshoot this? Is there another program I can use to backup/sychronize all my playlists with another computer?
#244792 - 29/12/2004 02:54 Re: Problems downloading from jemplode [Re: frekin]
frekin
Ok...I solved the problem about 5 minutes after my post. It refuses to download if I have "Use Hijack when Possible" enabled in the Options window. Once I disabled that option, the downloads completed properly. If anyone has an explanation for this behavior, I would appreciate it.
One other question: can someone point me to a list of fields I can enter in the "Filename Format" box at the top of the options window? I currently have "{artist} - {album} - {track} - {title}{ext}", but I would like to put the track number in the filename. If possible, I would also like leading zeros before track numbers <10.
Thanks.
#244793 - 29/12/2004 04:40 Re: Problems downloading from jemplode [Re: frekin]
Your problem is the {track} part. It should be {tracknr:2} in order to be track number padded to two digits (leading zeroes on tracks <10).
#244794 - 29/12/2004 07:04 Re: Problems downloading from jemplode [Re: tfabris]
frekin
Thanks for the help.
#244795 - 31/12/2004 04:02 Re: Problems downloading from jemplode [Re: frekin]
jdandrea
Loc: New Jersey
I had the exact same problem today. As soon as I unchecked "Use Hijack When Possible" downloads worked just fine.
Now to figure out why I can't get Hijack to autoupdate via Emplode!
-- JD - SN# 040104008 (120GB Blue, Digital Out)
