#244247 - 17/12/2004 11:45 End of Playlist?
michael_corleone
Hi,
Whenever i turn on my empeg, it always says "End of Playlist", it use to go back to the last song it was playing before. I connected the Serial cable to see if something was going on with the hdd's and i see this at the end:
cat: /drive0/var/tts/greetings.pcm: No such file or directory
hijack_exec("", "exec /drive0/var/ttsclock"), rc=0 (okay)
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
hda: read_intr: status=0x59
hda: read_intr: error=0x40
end_request: I/O error, dev 03:03 (hda), sector 0
Vcb: 0x4086d000
Can anyone tell me about this error?
thanks
#244248 - 17/12/2004 11:49 Re: End of Playlist? [Re: michael_corleone]
michael_corleone
I didn't know if i should post the whole thing, so here it is.
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v395 (mark@rtr.ca) (gcc version 2.
95.3 20010315 (release)) #2 Sun Jun 27 17:52:49 EDT 2004
Checking for extra DRAM:
c1000000: wrote ffffffff, read e91ba9f0
empeg-car player (hardware revision 9, serial number 30102524) 16MB DRAM
Command line: mem=16m
Memory: 15016k/16M available (980k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Found custom animation at offset 0x9877c
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004280).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: HTS548040M9AT00, ATA DISK drive
hdb: HTS548040M9AT00, ATA DISK drive
hda: HTS548040M9AT00, 38154MB w/7877kB Cache, CHS=4864/255/63
hdb: HTS548040M9AT00, 38154MB w/7877kB Cache, CHS=4864/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:09:d
c
Partition check:
Timezone: /usr/share/zoneinfo
empeg-pump v0.03 (19980601)
Mounting proc
Starting player
Timezone: /usr/share/zoneinfo/UTC
Saved AC volume was 90
Volume=90
hijack_exec("", "exec /drive0/var/setvol"), rc=0 (okay)
Volume=90
PlaYing sAMPle 115
hijack_exec("", "exec /drive0/var/randomsound"), rc=0 (okay)
Volume=90
PlaYing sAMPle 38
Using theme x with intro x
5 12 17 08 50
Volume=90
/drive0/var/tts/greetings.pcm /drive0/var/tts/morning.pcm /drive0/var/tts/todayi
s.pcm /drive0/var/tts/week5.pcm /drive0/var/tts/month12.pcm /drive0/var/tts/17th
.pcm /drive0/var/tts/xthetimeis.pcm /drive0/var/tts/x8.pcm /drive0/var/tts/x50.p
cm /drive0/var/tts/xam.pcm
Vcb: 0x4086d000
#244249 - 17/12/2004 12:03 Re: End of Playlist? [Re: michael_corleone]
mtempsch
Hi,
(/q]
Your tts installation seems corrupt - the file greetings.pcm vcan't be located...
q[]
Vcb: 0x4086d000
Looks like a hardware error - check the drive cable (crimping og contacts) and the soldering of the IDE header on the mainboard. You could also try a manual fsck in case it's a corrupted file system
(all well documented in the FAQ) Could also be the drive itself dying...
#244250 - 17/12/2004 13:34 Re: End of Playlist? [Re: michael_corleone]
schofiel
I would suspect a corrupted filesystem here: do a quick FAQ for what to do.
#244251 - 17/12/2004 14:28 Re: End of Playlist? [Re: schofiel]
michael_corleone
Thanks for the replys but it's weird when I Run the e2fsck Fix from the FAQ. this is what I get:
Starting bash.
empeg:/empeg/bin# ro
empeg:/empeg/bin# umount /dev/hda4
empeg:/empeg/bin# umount /dev/hdc4
empeg:/empeg/bin# swapon /swapfile
Adding Swap: 16028k swap-space (priority -1)
empeg:/empeg/bin# fsck -fay /
Parallelizing fsck version 1.19 (13-Jul-2000)
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
hda5 is mounted.
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
/dev/hda5: 1515/4096 files (0.5% non-contiguous), 9458/16384 blocks
empeg:/empeg/bin# fsck -fay /dev/hda4
hda4 is mounted.
etc........
Why does it say no such file or directory? or am i doing something wrong?
#244252 - 17/12/2004 15:37 Re: End of Playlist? [Re: michael_corleone]
No, that's normal because of the nonstandard way the empeg's Linux installation is.
While you my have a corrupted filesystem, I believe that the I/O errors are hardware errors and need to be corrected themselves. Could be the IDE header, the cable, or the hard drive. There's a FAQ on what to look for.
#244253 - 17/12/2004 15:44 Re: End of Playlist? [Re: michael_corleone]
The error is on /dev/hda3, not the one(s) you ran fsck on.
/dev/hda3 is where the player software saves a lot of settings, including the current running order (playlist) and per-track settings and stuff.
There is no fsck for /dev/hda3, but you could instead simply wipe it clean and hope that fixes the error.
Connect via serial port, hit control^C to break out of the player and get a shell (command) prompt. Then do this to wipe out /dev/hda3:
cat /dev/zero > /dev/hda3
#244254 - 17/12/2004 17:22 Re: End of Playlist? [Re: mlord]
michael_corleone
empeg:/empeg/bin# cat /dev/zero > /dev/hda3
cat: write error: No space left on device
empeg:/empeg/bin#
i should have 9 gig left
#244255 - 17/12/2004 17:46 Re: End of Playlist? [Re: michael_corleone]
That's expected. The command that Mark gave you simply reads the content of /dev/zero and writes it to /dev/hda3. Since /dev/zero is an infinitely-long sequence of zeros, it'll stop when /dev/hda3 is full, giving that error.
And /dev/hda3 is only 16Mb in size, so it'll fill up quite quickly.
#244256 - 17/12/2004 18:09 Re: End of Playlist? [Re: michael_corleone]
yeah, like Roger said, that message was expected, and good to see.
Now cycle the power and see if it works.
#244257 - 17/12/2004 20:01 Re: End of Playlist? [Re: mlord]
michael_corleone
Cool that problem is gone but i still get this error
Partition check:
should i ignore?
thanks for all your help
#244258 - 17/12/2004 20:47 Re: End of Playlist? [Re: michael_corleone]
That's just a useless "warning", not an error.
Ignore it.
#244259 - 18/12/2004 19:39 Re: End of Playlist? [Re: mlord]
mtempsch
an It just says that a certain time or number of mount operations has elapsed since last file systemcheck (fsck) was run on the partition. d can, IIRC, be turned off with Hijack. No worries, if something potentially truly bad happens (like forgetting to remount as read-only after having something mounted read-write) it wll stilll notice and complain. A synch will take care of the mattter, but it wlil ltake longer (with big drives potentially loooong) time as it wll then do an fsck at that time. Which is annoying as Murphy assures it will be the time whenyou just wanted to toss on a few new tracks or a few tag updates and be on your way...
#244260 - 01/02/2005 16:48 Re: End of Playlist? [Re: mtempsch]
chuckcheeze
i am having the same error as michael_corleone.
it turns out to be a hdd problem...bad sector. running hitachi DFT and erasing the disk. i hope it works.
#244261 - 06/02/2005 18:01 Re: End of Playlist? [Re: chuckcheeze]
Keep in mind to put the drive back in the empeg, you will need to run the "Builder" image. Search the FAQ for more on this, and if you have two drives, make sure the good one is disconnected.
