#240558 - 07/11/2004 11:20 tuner compatible software
jarob10
Loc: Stockport, UK
Can anyone confirm the most recent software release which has a fully operational tuner? I was gonna upgrade to 3.0 for this reason (following a planned memory upgrade), but I believe this version may have tuner operation issies.
#240559 - 07/11/2004 14:47 Re: tuner compatible software [Re: jarob10]
DeadFire
Version 3 of the car player software is still in the alpha stage. It has a ways to go. If you want to be able to make use of extra memory and not have to worry about your tuner functioning improperly, you should use v2.01. It's an update to 2.00 that allows for the detection of extra RAM installed onto the player.
#240560 - 07/11/2004 15:26 Re: tuner compatible software [Re: DeadFire]
robricc
The tuner seek function doesn't work in 2.0 and I don't think that issue was fixed in the 2.01 release. 2.0 beta 13 is the most stable release where the tuner works I think.
#240561 - 08/11/2004 02:08 Re: tuner compatible software [Re: robricc]
DeadFire
Oh, I didn't know that. I don't actually have a tuner myself. And if I did I don't think I'd force myself to listen to the garbage coming over the airwaves around here.
Anyhow, 2beta13 won't recognize the extra RAM, will it? I know Hijack will, but that means only Hijack will get to use it, right?
#240562 - 08/11/2004 08:05 Re: tuner compatible software [Re: robricc]
So install 2b13 and set up a bunch of presets, and then install 2.01. Or do what I do -- don't bother listening to the radio -- I only have the tuner installed for the stalk interface.
#240563 - 08/11/2004 11:37 Re: tuner compatible software [Re: Roger]
robricc
The US is quite a bit bigger than England. Drive about 45 miles and if you want to hear some local flavor, you're going to have to seek. Of course, it's very rare I listen to the radio as well. It's sometimes good to see what's going on though.
Another suggestion would be that when you open v2.0 back up (which was a freak occurrence anyway), fix the effing tuner issue!
#240564 - 08/11/2004 13:27 Re: tuner compatible software [Re: jarob10]
I use 3.00Alpha7 + Hijack, which I use to fix tuner issues. Works great.
