Page 2 of 2 < 1 2
#236945 - 14/10/2004 01:14 Re: Stock Aluminum Fascia [Re: JayF]
I'd buy metal buttons too, if they fit the tsock fascia. Chrome would be great.
Also, depending on price, I may buy some metal fascias as well.
#236946 - 11/11/2004 10:04 Re: Stock Aluminum Fascia [Re: JayF]
Glen_L
Loc: Elk Grove, CA
Bump...any good news yet?
No longer a stranger, finally a full-fledged member! \:D
#236947 - 13/11/2004 05:03 Re: Stock Aluminum Fascia [Re: Glen_L]
JayF
work is in progress. just getting caught up at work so I can get going on this.
also just got a newface on loan. ( thanks alvin ). So hopefully I'll be able to offer stock and newface versions.
once I get some samples made I will post pics.
#236948 - 13/11/2004 19:16 Re: Knobs for Aluminum fascia [Re: JayF]
Mach
Loc: Texas, USA
I'm not sure what you have planned for the knobs but these may be useful. I've got a set of the Kilo knobs from digikey that I'm going to experiment with over Christmas. I've also got a couple of the MGW knobs on order. They have several different styles. I'll post some side by side comparison photos for the Kilo knobs.
Note! The set screw in the kilo knobs are approximately 1/4" from the end of the knob. The NewFace is 1/8". To get the Kilo knob to work, I had to remove the lower lip on the knob (~1/8") otherwise the set screw doesn't make contact.
Source for MWG here.
Edited by Mach (13/11/2004 20:40)
#236949 - 13/11/2004 19:48 Re: Knobs for Aluminum fascia [Re: Mach]
Mach
Loc: Texas, USA
Comparison photo to original knob and NewFace knob.
#236950 - 13/11/2004 19:49 Re: Knobs for Aluminum fascia [Re: Mach]
Mach
Loc: Texas, USA
Kilo knob in the fascia.
Edited by Mach (13/11/2004 20:30)
#236951 - 18/11/2004 05:03 Re: Knobs for Aluminum fascia [Re: Mach]
peakmop
Loc: 384400 km from the Moon
Is it possible to drill some holes around perimeter of the knob and fill them with clear epoxy for the lighting kit?
#236952 - 18/11/2004 06:28 Re: Knobs for Aluminum fascia [Re: peakmop]
schofiel
Did this quite successfullly with good results using a 0.75mm drill at low speed.
#236953 - 18/11/2004 16:11 Re: Knobs for Aluminum fascia [Re: peakmop]
Mach
Loc: Texas, USA
As Rob mentioned, for both the original knob and the metal knob pictured above, yes. I like end glow fiber instead of epoxy though as it transmits light much better
Page 2 of 2 < 1 2
