#236723 - 06/10/2004 17:05 Advanced Search in Emplode Question
LTJBukem
Hi,
I'm trying to find the correct syntax for to retrieve all the files i've uploaded in the last month let's say.
I know I can do recently added in the Random Selection on the front panel, but I tend to stream from my Empeg as much as I use the front panel (probably more)
Also any other useful advanced searches that can be done, I would really appreciate pointing in the right direction.
LTJ
#236724 - 06/10/2004 17:14 Re: Advanced Search in Emplode Question [Re: LTJBukem]
And this didn't help? I'll look through that and see if I can find a proper syntax for you...
#236725 - 06/10/2004 17:20 Re: Advanced Search in Emplode Question [Re: tfabris]
Ah, OK, what we need is an easy little PHP script I can embed into that FAQ entry to convert real times and dates into a unix time_t number to plug into the advanced search....
#236726 - 06/10/2004 17:28 Re: Advanced Search in Emplode Question [Re: tfabris]
Okay, found some example code. Working on it.
#236727 - 06/10/2004 17:51 Re: Advanced Search in Emplode Question [Re: tfabris]
Okay, it's in that FAQ entry now. (There is a link to a time converter script right next to where it lists "ctime").
Just get a number from that script, and then plug that in.
For instance, to find all songs added to the player since my birthday of this year, I would search on:
ctime>1081058400
#236728 - 06/10/2004 19:07 Re: Advanced Search in Emplode Question [Re: LTJBukem]
LTJBukem
Thanks Tony,
All clear now ...
ctime > 1096606800 equals anything created after 01 October 2004.
Obviously really
Many Many Thanks
LTJ
#236729 - 06/10/2004 20:02 Re: Advanced Search in Emplode Question [Re: LTJBukem]
mschrag
Loc: Richmond, VA
For jEmplode, see the Functions section of http://www.jempeg.org/QueriesAndTagNames.html ... Little easier syntax to work with
#236730 - 07/10/2004 04:14 Re: Advanced Search in Emplode Question [Re: tfabris]
Loc: Los Angeles, CA
happy belated birthday, btw
#236731 - 07/10/2004 05:36 Re: Advanced Search in Emplode Question [Re: image]
Heh, thanks, it was months ago.
