#235296 - 27/09/2004 20:44 Boot up problem
frodo_lives
Loc: Fl
on my bootup, my display keeps saying back and forth, "loading music data base" then switches to "loading playlist". what do i do??
Mk2-60Gig 89 Honda EF-9 JSpec
#235297 - 27/09/2004 20:55 Re: Boot up problem [Re: frodo_lives]
My guess is that the player application is crashing and restarting - possibly due to a corrupt music file or database. First, (assuming you have a developer kernel installed) quit to the command prompt. Then run the player application with "player -i" to clear the current playlist. That might fix your problem. If not, there is more that can be tried, starting with rebuilding the databases manually...
#235298 - 27/09/2004 20:57 Re: Boot up problem [Re: pgrzelak]
frodo_lives
Loc: Fl
can you please explain in step by step terms how i do all this? sorry, but not very tech savvy with my empeg. wanting to learn tho.
#235299 - 27/09/2004 20:58 Re: Boot up problem [Re: frodo_lives]
SE_Sport_Driver
And if you don't have the developer version of version 2.00final, install it!
Link to 2.00 Developer
#235300 - 27/09/2004 21:01 Re: Boot up problem [Re: SE_Sport_Driver]
I did a little editing to the original message. There are now links to the FAQ entries for these topics. Follow this one first. It is written in a way that is fairly easy to understand, but if you have questions post them.
#235301 - 15/10/2004 17:24 Re: Boot up problem [Re: pgrzelak]
frodo_lives
Loc: Fl
i have tried to prompt Hyperterminal, and nothing. The COM port is turned on. And when i try to make sure and upgrade the developer version bc i am not sure its installed, upon bootup, its not recognized, and the screen still bounces back and forth to "Loading Music Databases" to "Loading Playlist". whats wrong?
#235302 - 15/10/2004 18:27 Re: Boot up problem [Re: frodo_lives]
You *must* fix things so that hyperterminal works. If you don't, then nothing else is going to work and we can't help you any further.
It could be something as simple as a bad cable. So please go through every troubleshooting step carefully to get hyperterminal working. Then get back to us.
