#234117 - 20/09/2004 17:26 Empeg standing face up bad?
SonicSnoop
Loc: Triangle, VA
I have noticed somewhere that having the empeg player on face up is bad, I was wondering if someone could confirm/explain why this is so? A installation I am coming up with using batteries would best have the empeg that way but I dont want to do it if it is bad. Thanks!
#234118 - 20/09/2004 17:32 Re: Empeg standing face up bad? [Re: SonicSnoop]
The answer is in the usual place.
In fact, I think I'm going to update that FAQ entry a tad, based on memory of a recent thread here on the board.
#234119 - 20/09/2004 17:34 Re: Empeg standing face up bad? [Re: SonicSnoop]
Mostly has to do with how the hard disk shock absorption system was designed to work. If you'll be getting a lot of bumps when it is mounted that way, it may be an issue. Otherwise, it should work fine.
EDIT: yeah...what he said
#234120 - 20/09/2004 17:36 Re: Empeg standing face up bad? [Re: SonicSnoop]
mdavey
Loc: Wellingborough, UK
It puts strain on the spindle in the harddisk(s) in a way that for which they weren't designed.
The Empeg tray is at a slight angle to compensate for the slight angle it would be mounted in a car dash.
Here is a more complete answer:
FAQ entry
Edit: blimey - I'll be taking "quick typist" off my C.V now
Edited by mdavey (20/09/2004 17:42)
Michael
Ex-owner of stolen empeg #030102741
#234121 - 20/09/2004 17:45 Re: Empeg standing face up bad? [Re: mdavey]
All that said, I'm one of the people mentioned in the FAQ as running outside the recommended limits. Roughly 3.5 years now running at roughly 45 degrees with no problems.
Gallery
#234122 - 20/09/2004 22:46 Re: Empeg standing face up bad? [Re: JBjorgen]
I also used to run the empeg out-of-spec (tilted slightly face-down) and did so for many years (4 or so?) with no problems.
#234123 - 21/09/2004 12:45 Re: Empeg standing face up bad? [Re: wfaulk]
SonicSnoop
Loc: Triangle, VA
What I plan on doing is finding a bag/case of some kind that I can mount the empeg and batteries in and with a sled for wiring it all up so I can listen to it on the go. Most of the time it could be laid down flat but being carried it would be face up. Ill just make sure not to play it much if at all with it face up.
#234124 - 21/09/2004 14:13 Re: Empeg standing face up bad? [Re: SonicSnoop]
Um... Wouldn't it be easier to just get a Karma?
#234125 - 21/09/2004 14:13 Re: Empeg standing face up bad? [Re: SonicSnoop]
When you do this, make sure it's got room to breathe. Too much heat can kill a hard disk.
#234126 - 21/09/2004 14:14 Re: Empeg standing face up bad? [Re: jmwking]
Yeah, agreed.
#234127 - 21/09/2004 15:29 Re: Empeg standing face up bad? [Re: tfabris]
SonicSnoop
Loc: Triangle, VA
I planed on cutting out holes and mounting fans.
Im just doing it to do it. I really dont need it portable, just thought it would be fun to try. everyone seems to have lil projects going and since i cant program for it i just thought id do this
#234128 - 21/09/2004 15:31 Re: Empeg standing face up bad? [Re: SonicSnoop]
Ah, a very noble cause indeed. You have our full support.
