#22991 - 25/11/2000 02:21 Technically possible???
TommyE
Loc: NORWAY
This one, I think, is for some of the Empeg folks.
Wondering if it would be possible for the hardware to have two players running
at the same time, playing two different songs. One song output to the front RCA jacks, and the other song output to the rear RCA jacks. (Or even better, have different sources on the RCA pairs. eg. radio and empeg)
This would come in handy if someone wanted to listen to one playlist in their headsets, while other could listen thru the carspeakers.
TommyE
#22992 - 25/11/2000 02:22 Re: Technically possible??? [Re: TommyE]
TommyE
Loc: NORWAY
And for listening to DVD sound from the AUX input.
TommyE
#22993 - 25/11/2000 06:19 Re: Technically possible??? [Re: TommyE]
No, it's not possible. The DSP can only be fed stereo data, and it does the front/rear mix internally.
#22994 - 26/11/2000 01:08 Re: Technically possible??? [Re: rob]
jane
Loc: Copenhagen SW, Denmark
But it *is* technically possible for the hardware to play different songs on
left and right?
Marius
Escort Cab + MKII
#22995 - 26/11/2000 06:00 Re: Technically possible??? [Re: jane]
I wouldn't hold your breath for that "feature"!
#22996 - 26/11/2000 23:14 Re: Technically possible??? [Re: rob]
alear
Loc: Montana, USA, Bozeman
The empeg may not be able to do it alone but the empeg is still very versatile. Would this work? It is probably possible to run a decoded multichannel stream out the ethernet connection to small external hardware that would seperate and preamplify the stream since the empeg lacks the hardware for true multichannel sound. Would work for multichannel or multisource output.
Could be a AC3/DTS module for those that like the idea.
Alex Lear
Alex Lear
#22997 - 27/11/2000 02:40 Re: Technically possible??? [Re: alear]
anti
Loc: BaWue, Germany, Europe
If you'd implement that feature I know at least 6 DJs who would buy a "big one" immediatly.
I talked to them about using an empeg instead of their notebooks and most of them liked the idea, but don't want to buy two empegs and keep them in sync.
ciao
anti
btw:
If I buy ten, do I get one cheaper ? ;-)
MKII 08000073 12GB BLUE
-------------------- MKII 08000073 40GB BLUE
#22998 - 30/11/2000 04:16 Re: Technically possible??? [Re: TommyE]
Paul
While we are talking about strange and unusual things to to do with an Empeg.
Could someone with far more knowledge than myself get one to run with a modem and then log onto the net and then download music straight from napster as an example.
A feature with no real advantage but it would be cool not that i would even bother as my computer works fine.
I only ask as it came up in conversation with some friends and i thought it might be techniclly possible just
#22999 - 30/11/2000 11:48 Re: Technically possible??? [Re: Paul]
Yes, that would be technically possible. But it would be a fairly large task for doing it just on the empeg alone. It's much easier just to do the work with the PC and use Emplode to load the songs onto the Empeg.
I assume that you mean doing this by plugging an external v.90 modem directly into the Empeg's serial port, right? Because if you mean connecting to the internet via the ethernet port, then you're already talking about it being hooked up to a network with PCs on it already and there's no advantage to having the Empeg doing the downloading since it's so much easier to do on the PC.
If you mean controlling a modem through the serial port, then yeah, I'm sure you could write some sort of napster-type client to run on the Empeg and control a modem through the serial port. But it would be a lot of work for very little benefit.
#23000 - 30/11/2000 12:51 Re: Technically possible??? [Re: tfabris]
fvgestel
Loc: Netherlands
I actually had my nokia 7110 dialing out communication with the empeg over infrared; Maybe sometime in the future we will be able to give a voice command like : 'search fire' and it would dial out to search all MP3's that contain the word fire , display a list and it would download the selected items.
Which bring me to another question : When VR is in place, is there also an option for the empeg to talk back? Maybe I want to set up some quasi-arti-intelli system to show off to friends...
Frank van Gestel
Frank van Gestel
#23001 - 30/11/2000 14:59 Re: Technically possible??? [Re: tfabris]
muzza
Additionally, i don't see why you would want to. Napster people are notorious for not filling out the MP3 tags appropriately, I would guess that 80% at least would not know what they are.
Additionally, that would be your ONLY copy of the song. what happens if you want to upgrade the drives? the unit is stolen? the drives crash?
____________________
Murray 06000047
#23002 - 30/11/2000 16:02 Re: Technically possible??? [Re: fvgestel]
We have it in the back of our minds to coincide voice recognition with audible confirmation. Now I just have to track down Majel Barrett's agent..
#23003 - 30/11/2000 16:06 Re: Technically possible??? [Re: rob]
Now I just have to track down Majel Barrett's agent...
Me, personally, I'd rather have Ben Stein. "Bueller... Bueller... Bueller..."
Or if the guy who did HAL-9000 is still around, that'd be the ultimate. "I'm sorry, Dave, but that song sucks eggs."
#23004 - 01/12/2000 03:40 Re: Technically possible??? [Re: muzza]
Paul
1 I realise this has no practical benifits what so ever
2 I thought it would be a huge task
3 Napster is full of shite
4 I would be cool if you could do it anyway it would be up there with Talky Toaster cool but no use what so ever technology for the sake of it.
