Page 2 of 2 < 1 2
#22959 - 04/12/2000 00:36 Re: need FAQ on getting mp3 from empeg back to compt. [Re: PaulWay]
fvgestel
Loc: Netherlands
Can you tell me where to get this WinDriver/USB from?
http://www.jungo.com/wdusb.html
Frank van Gestel
Frank van Gestel
#22960 - 04/12/2000 21:13 Re: need FAQ on getting mp3 from empeg back to compt. [Re: fvgestel]
borislav
Loc: Sunnyvale, CA, USA
Unfortunately the player app also listens on USB. Is there a way to disable USB in the player app?
Hey, I would like to know that too. My current plan was to figure out if there's some command you can send to the player that forces it to quit (similar to the way emptool can restart it). Haven't got around to looking into this yet, though. Let me know if you find something.
Borislav
#22961 - 05/12/2000 03:29 Re: need FAQ on getting mp3 from empeg back to compt. [Re: fvgestel]
mac
Loc: Cambridge, UK
Running player -u- used to work - I haven't tried it recently.
Mike Crowe
I may not be speaking on behalf of empeg above :-)
Mike Crowe
#22962 - 05/12/2000 04:13 Re: need FAQ on getting mp3 from empeg back to compt. [Re: borislav]
There is a command to cause a quit - it's identical to the command on the serial port (the same protocol runs over serial, USB, tcp).
#22963 - 06/12/2000 10:11 Re: need FAQ on getting mp3 from empeg back to compt. [Re: mac]
fvgestel
Loc: Netherlands
It does..., with the last minus-sign attached...
I also discovered a -i option
what does this one do?
empeg:/empeg/bin# ./player -h
Using non-standard cache size 148 (adjustment 32)
player [options]
Options:
-u Enable USB server.
-i Ignore emergency persist data.
Frank van Gestel
Frank van Gestel
#22964 - 24/12/2000 14:41 Works! [Re: fvgestel]
94cobra
Kudos!!! to you fvgestel. The displayserver works like a champ to transfer files back. I like this because I get rid of the original file on my hard drive. And for me sometimes I want to get one back for listening or modifying(without having to re-ripp or in some cases download.) Can't thank you you enough.
Proud Owner of MK2 080000558 - 18gb Blue
Sonic Blue 03 Cobra Vert Owner!!!
#22965 - 26/02/2001 15:52 Re: need FAQ on getting mp3 from empeg back to compt. [Re: fvgestel]
Cougar
I don't know how to act with the terminal programm. Can someone please help me? I can connect through serial to my EMPEG. But i can't press 'Q' (well i can, but nothing happens). Can i get a Dummie-Lesson-Of-How-To-Use-A-Terminalprogram-To-Install-The-Displayserver?
Maui997
#22966 - 26/02/2001 16:17 Re: need FAQ on getting mp3 from empeg back to compt. [Re: Cougar]
Check out this FAQ entry.
Remember that sometimes you have to cycle the power on the Empeg (pull and re-insert the plug) after starting hyperterminal.
#22967 - 27/02/2001 14:39 Re: need FAQ on getting mp3 from empeg back to compt. [Re: tfabris]
Cougar
Thanks alot. Know Displayserver works. YESSSSS!!!!! :))
Cougar
Page 2 of 2 < 1 2
