#228462 - 26/07/2004 02:31 Drives Won't Spin Down... ever...
loren
I posted this problem before but it got mixed up in another thread about swapping boards between a MkII and a MkIIa, so let me start anew and summarize:
Victim: MkII empeg with 2 40 GB drives running v2.0Final and Hijack v383 with about 16.4GB free space
Problem: The drives stay spun up ALL THE TIME according to the drive activity icon... which in turn leads to overheating after about an hour or so use in car.
For a previous run down, check out this thread... but here's were i stand now.
Here's a screen grab of the icon that's always up (when it's not showing the W or reading icon) which is described in the FAQ as "Smaller icon with solid gray in center":
Boot log is as follows:
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v383 (root@ibbm) (gcc version 2.95.3 20010315 (release)) #2 Fri
Apr 16 11:15:10 EDT 2004
empeg-car player (hardware revision 7, serial number 90000896)
Command line: mem=12m
Memory: 10960k/12M available (980k code, 20k reserved, 324k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Found custom animation at offset 0x9877c
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005080).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hdb: IC25N040ATCS04-0, ATA DISK drive
hda: IC25N040ATCS04-0, ATA DISK drive
hda: IC25N040ATCS04-0, 38154MB w/1768kB Cache, CHS=4864/255/63
hdb: IC25N040ATCS04-0, 38154MB w/1768kB Cache, CHS=4864/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:12:03:80
Partition check:
Timezone: /usr/share/zoneinfo
empeg-pump v0.03 (19980601)
Mounting proc
Starting player
Timezone: /usr/share/zoneinfo/US/Pacific
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
Vcb: 0x4058a000
spindown_chunk_cache_runner.cpp: 294:Filling up space (-18)
and that repeats at about one line a second... forever.
Last time I investigated this, i was getting an error:
Could not find CS4231A (version=80)
in the boot log, but that seems to have disappeared.
Here's a RAM check:
0000 empeg-car board test version 0.04 <hugo@empeg.com>
0100 ram test starting
0110 testing ic 1 (0-3mb, low word)
0120 testing ic 2 (0-3mb, high word)
0130 testing ic 3 (4-7mb, low word)
0140 testing ic 4 (4-7mb, high word)
0150 testing ic 19 (8-11mb, low word)
0160 testing ic 32 (8-11mb, high word)
01f0 ram test done
0200 ide detect
0210 command issued
0220 drive id IC25N040ATCS04-0
02f0 ide ok
0300 dsp/i2c test
03f0 dsp/i2c ok
0400 temperature detect
0410 temperature is 38
04f0 temperature ok
0500 usb detect
0510 usb rev 1012
05f0 usb ok
0600 ethernet detect
0610 ethernet rev 334b
06f0 ethernet ok
0700 cs4231 detect
0710 cs4231 rev a0
07f0 cs4231 ok
00f0 tests complete
And here's my config.ini:
[hijack]
khttpd_root_index=/drive0/opt/khttpd/charcoalgray99/index.html
[output]
notify=1
[hush]
hushpercent=20
[display]
play_count=1
visual_names=1
caching=1
[volumecap]
enabled=0
[kenwood]
disabled=0
[ramp]
disabled=0
[menu]
quit=0
sort_playlist=0
[tuner]
region=us
[controls]
stalk_side=none
[Options]
Name=emp3g
[User Info]
Email=loren@******.com
Phone=415-***-****
Name=Loren Cox
[Network]
;@HOME DHCP=0
;@WORK DHCP=1
Gateway=192.168.1.1
Netmask=255.255.255.0
IPAddress=192.168.1.20
DHCP=0
[sense]
muteaction=1
mute=1
[power]
off_timeout=60000
[aux]
source=
title=
artist=
[synchronise]
seq_num=89
[wendy]
flag_amount=0
[custom]
wendy=
[searches]
amount=0
[VisualFavourites_AM]
count=0
[VisualFavourites_AUX]
count=0
[VisualFavourites_DSP]
count=0
[VisualFavourites_FM]
count=0
[shuffle]
deduplicate=0
I've reinstalled the firmware and hijack to no avail... as well as rebuilt the database by hand.
I'm stumped fellas... any ideas?
|| loren ||
#228463 - 26/07/2004 05:07 Re: Drives Won't Spin Down... ever... [Re: loren]
It looks like you've run out of RAM. How big is your /empeg/var/database file? How many tracks do you have?
#228464 - 26/07/2004 16:44 Re: Drives Won't Spin Down... ever... [Re: Roger]
loren
-r--r-- 1 0 0 3.0M Sep 22 11:12 database
Doesn't look too insane... does it?
As for tracks... um.. 17367 according to a down down down. But even when i'm playing one 12 track album, it's still always spun up. Paul reports having no such problems on his empeg with over 100gb of music... but i think that's on a MkIIa... maybe that extra 4 megs makes that much difference? I've got some RAM chips... maybe i'll have a go at adding RAM after all.
|| loren ||
#228465 - 26/07/2004 17:26 Re: Drives Won't Spin Down... ever... [Re: loren]
3.0M [snip] Doesn't look too insane... does it?
It looks about right for 17,000 tracks -- in other words, really big.
Yes. A 2.0final Mark 2 has about 5MB cache; a 2a about 9MB. Your player will thus only have about 2MB left once the database is loaded, which won't be enough to spin down.
For that size music collection, that's probably your best option, unfortunately.
#228466 - 26/07/2004 18:29 Re: Drives Won't Spin Down... ever... [Re: peter]
loren
Hrm... I think i'm going to do a board swap and see how much that extra built in RAM helps before i go messing up my board with my mediocre soldering skills. Maybe I'll crack it open this week and see if i think i can do the solder job myself or not. . .
Any Bay Area folks done the RAM upgrade that would attempt the work?
Thanks Peter.
|| loren ||
#228467 - 26/07/2004 18:54 Re: Drives Won't Spin Down... ever... [Re: loren]
peakmop
Loc: 384400 km from the Moon
Before you try to mess with the memory upgrade, you might want to wait until Patrick comes up with a new memory upgrade kit that is less messy than the stacking method, unless you want to put your extra RAM chips to a good use.
#228468 - 26/07/2004 20:39 Re: Drives Won't Spin Down... ever... [Re: peakmop]
loren
It's actually a cost issue. Can't afford the $200 for a neat solution. Esp. when i have some chips sitting here doing nothing. I'm sure it'll be way easier and neater... but i haven't that much free flowing cash at the moment just to make sure my drives spin down. I guess a board swap between my MkII and MkIIa backup is in order as a first step...
|| loren ||
#228469 - 26/07/2004 20:41 Re: Drives Won't Spin Down... ever... [Re: loren]
Greetings!
Even with the 16MB, my drives did not spin down much either. I just never noticed it before.
#228470 - 26/07/2004 22:03 Re: Drives Won't Spin Down... ever... [Re: pgrzelak]
mcomb
Loc: San Carlos, CA
Personally I think this whole drive spinning down thing is a myth. I've only got about 8000 songs on a mk2a and my drives rarely manage to spin down. Of course I'm running v3a7 and ext3 neither of which are likely to help the situation.
-Mike
#228471 - 26/07/2004 22:10 Re: Drives Won't Spin Down... ever... [Re: loren]
schofiel
Wait for Patrick's board.
#228472 - 26/07/2004 22:51 Re: Drives Won't Spin Down... ever... [Re: loren]
There's nothing wrong with the two-chip solution --> 32MB (Mk2a). By far the best bang for one's buck, that way!
But if this is your Mk2 player, then.. yup, it really wants Patricks new board. If you can wait until 2005, that is.
#228473 - 27/07/2004 01:32 Re: Drives Won't Spin Down... ever... [Re: mcomb]
I've got about 10,000 "songs" (includes audiobooks and a lot of classical music) and my drives are rarely spun up.
However, upon reflection... I spend quite a bit of time listening to audiobooks, many of which are recorded at 64 kbps which means that I can stuff a lot of minutes of audio into not a lot of cache.
#228474 - 27/07/2004 03:50 Re: Drives Won't Spin Down... ever... [Re: tanstaafl.]
mcomb
Loc: San Carlos, CA
Are you using v2 or v3? Version 3 seems to be a lot more of a memory hog for me. Actually, the weird thing is sometimes is works pretty well, the drives spin down for a minute or two and then spin up for a few seconds and spin down again. But, most of the time they just seem to stay spun up. I haven't figured out what makes the difference (I don't have any audiobooks and most of my mp3s are VBRs between 160 and 200kbps), but I still suspect there is a v3 bug that keeps the drives from getting spun down some of the time.
Anyway, its not that big of a deal for me. Hard drives are pretty robust these days and they always seem to fail on me about the time that I am running out of space anyway.
-Mike
#228475 - 27/07/2004 04:30 Re: Drives Won't Spin Down... ever... [Re: mcomb]
I've got about 6000 songs in my usual running order on my mk2a, with a little more than that in total, running v3a8, and it spins down correctly. I'm not running Hijack, in case it makes that much difference.
v3a7 has a bug where it doesn't spin down as often as it should.
#228476 - 03/08/2004 22:27 Re: Drives Won't Spin Down... ever... [Re: loren]
SE_Sport_Driver
Paul G. never gets this message? (I'm getting it now on my empeg Mk2 and database is smaller than his I'm sure.)
EDIT: Oops! Sorry Paul, just now noticed your post! :O
Edited by SE_Sport_Driver (03/08/2004 22:28)
#228477 - 04/08/2004 08:19 Re: Drives Won't Spin Down... ever... [Re: SE_Sport_Driver]
Not anymore (that I know of)...
