Page 3 of 3 < 1 2 3
#228332 - 07/09/2004 14:47 Re: SYLT Lyrics Plugin 1.2.1 [Re: tfabris]
I think he's using ID3lib for his tag parsing, so the bug would probably be in there. Is ID3lib open source, or is it just a black box binary?
It's open-source, but it's carp. We ditched it for emplode way way way back.
Edit: Although, having said that, it did cope with ordinary TIT2 tags.
Edited by Roger (07/09/2004 14:50)
#228333 - 08/09/2004 15:11 Re: SYLT Lyrics Plugin 1.2.1 [Re: Roger]
RobotCaleb
:P
#228334 - 09/09/2004 01:07 Re: SYLT Lyrics Plugin 1.2.1 [Re: wfaulk]
elperepat
Loc: Qc, Canada
Hi!
I'm sorry for the long delay without reply: real life is getting back on me. I'm doing roofing on my house, trying to make the chimney watertight, etc...
It's possible that I don't call vbid3lib the right way, or maybe I don't interpret the result returned correctly, or maybe id3lib is wrong. I tend to say that before, but I was wrong, so I assume it must be me ;-) I'm asking again: Anybody got an alternative for me?? I'm not that much attached to id3lib... The only "drawback" is that it must be availble from VB6.
I'm planning to work back on the plugin in a week or two. I'll check that out. Don't despair! ;-)
Patrick
#228335 - 11/09/2004 13:11 Re: SYLT Lyrics Plugin 1.2.1 [Re: elperepat]
SonicSnoop
Loc: Triangle, VA
Is there any way to edit the songs tags with out loosing the lyrics? I want to go back thru my mp3s and remove everything in the comment fields and set the genres to what I think they should be, but dont want too loose all the work I have done to em. I know with winamp I loose the lyrics.
#228336 - 11/09/2004 15:38 Re: SYLT Lyrics Plugin 1.2.1 [Re: SonicSnoop]
RobotCaleb
yeah. dont use winamp to edit your tags. its got that nasty problem.
#228337 - 11/09/2004 15:47 Re: SYLT Lyrics Plugin 1.2.1 [Re: SonicSnoop]
Try MP3 Tag Studio and see if it works. You might have to set one of its options in order to preserve the existing ID3V2 tag frames.
#228338 - 23/09/2004 14:48 Re: SYLT Lyrics Plugin 1.1 [Re: elperepat]
Of course, now I will have to get my PC with emplode etc on it connected to the outside world, because I can't upload these blimming .lrc files otherwise.
Ah well....
#228339 - 05/10/2004 09:51 Re: SYLT Lyrics Plugin 1.1 [Re: elperepat]
SE_Sport_Driver
Is there any way to get the plugin to not launch everytime I run Winamp? I've poked around but don't see a setting other than uninstalling.
#228340 - 05/10/2004 15:37 Re: SYLT Lyrics Plugin 1.1 [Re: SE_Sport_Driver]
elperepat
Loc: Qc, Canada
No... and it's a good point.
It'll be in the next version...
Thanks for the idea!
Patrick
#228341 - 05/10/2004 16:47 Re: SYLT Lyrics Plugin 1.2.1 [Re: tfabris]
webroach
Loc: Colorado
You really should check out MP3 Book Helper . It let me tag hundreds of CDs in very little time. It supports regular expressions for renaming, extraction of tags from the filename, etc. VERY cool program. And free.
And I know nobody else here probably nas much need for it, but for me, the fact that it FULLY supports unicode tagging is a HUGE win. Russian, Japanese, it doesn't care. It just builds the tag.
Also does lyrics tagging for ID3v2 and OGG.
Dave
#228342 - 17/10/2004 00:46 Re: SYLT Lyrics Plugin 1.3.0 [Re: elperepat]
elperepat
Loc: Qc, Canada
Now available
Here are the latest changes
-Fix bug with corrections to lrcDB (TonyF)
-Check for new version: Once a week, popup only once for each version. Manual check via help menu
-Changed "Hide Scrollbar" to "Hide scrollbar if lyrics are synced" (NicoB1981's request)
-Added support for USLT frame in id3v2 (NicoB1981's request)
-Added new Option "Allow saving even if not in Edit Mode" for Dial-Up users (RJ-45's Request)
-Changed a few shortcut keys to more standard ones (Save, Edit, Add, Subtract)
-Fixed AllTheLyrics not working anymore
-Fixed bug to greatly improve Leo's Lyrics
-Added Insert timestamp Timing on Mouse Down (Wfaulk's request)
-Fixed "Remove Timestamp" not working on last line
-Added support for EvilLyrics (Waterman981's request)
-Added option "Start with Winamp" (SE_Sport_Driver's request)
As always, keep the bugs reports and suggestions coming :-)
Patrick
#228343 - 17/10/2004 00:55 Re: SYLT Lyrics Plugin 1.3.0 [Re: elperepat]
Too cool. Thanks very much for all the work you do on this great program.
#228344 - 17/10/2004 00:57 Re: SYLT Lyrics Plugin 1.3.0 [Re: tfabris]
elperepat
Loc: Qc, Canada
As long as I'll use it and see the point to improve it, I'll do!!
Patrick
Page 3 of 3 < 1 2 3
