Page 1 of 3 1 2 3 >
#22676 - 19/11/2000 15:21 New displayserver 1.1
fvgestel
Loc: Netherlands
I have got a new version of displayserver
Due to some events (Sinterklaas is in the country) I am releasing a little later than promised.
It's got the following extra features :
- playlist browsing in your web-browser
- streaming of MP3-files through M3U files.
- authentication
- System status
- variable size bitmap for applet background
It's still rather buggy, so when you find something unusual, please let me know and I get into it.
Installation is done through a single install-script (install.sh.gz) which can be downloaded from http://empeg.dyndns.org/empeg/displayserver_with_ir.1.1
I saw the jempeg install-script, (which reminded me a lot of the old sun-package format) and decided to make something similar.
I added an autostart feature in the install script ( on userrequest ), but I haven't tested it thorougly. It renames the original /sbin/init executable to /sbin/init.before_displayserver and writes a shell script in init's place.
I haven't got a clean empeg, so maybe someone who isn't afraid of reinstalling an image could try it, others should not use this option till positive responses are received.
The kernel-patch was also rewritten as it was just pure luck the old hack did work (some stupid programming mistakes). For some strange reason the messed-up display after reboot also disappeared.
Anyway, try it and let me know what you think...
Frank van Gestel
Frank van Gestel
#22677 - 19/11/2000 15:28 Re: New displayserver 1.1 [Re: fvgestel]
ricin
Loc: US: CA
I can't seem to get to this site. None of the DNS servers can find it. Could you tell me an IP maybe?
________
Donato
MkII/Blue/40GB/080000565
ricin
MkII/080000565
MkIIa/010101253
ricin.io
#22678 - 19/11/2000 15:32 Re: New displayserver 1.1 [Re: ricin]
fvgestel
Loc: Netherlands
Sorry, I included my private domainname; I've edited the original post to point to http://empeg.dyndns.org/empeg/displayserver_with_ir.1.1/
Frank van Gestel
Frank van Gestel
#22679 - 19/11/2000 15:50 Re: New displayserver 1.1 [Re: fvgestel]
fvgestel
Loc: Netherlands
Anyone who want's to see a live demo, can go to http://empeg.dyndns.org:13470
Frank van Gestel
Frank van Gestel
#22680 - 19/11/2000 19:28 Re: New displayserver 1.1 [Re: fvgestel]
borislav
Loc: Sunnyvale, CA, USA
Username and password?
Thanks,
Borislav
#22681 - 19/11/2000 20:34 Re: New displayserver 1.1 [Re: fvgestel]
dionysus
Loc: San Francisco, CA
VERY nice - works nicely for me, except for 2 things -
First off, the init that it created was blank, although the backup was made as promissed...
Second, M3U (using winamp) comes back w/ 401 authorization is required - individual tracks work though; this is using the latest version of Winamp...
Anyone know of an mp3 player which will take authorization into account?
-mark
MK2: 36gb
Tivo: 90gb
CPU: 120gb
...I think drive manufacturers love me!
Edited by dionysus on 20/11/00 03:54 AM.
#22682 - 19/11/2000 21:07 Re: New displayserver 1.1 [Re: fvgestel]
dionysus
Another note - calling the display server directly by /usr/local/displayserver/displayserver doesn't work (it looks like it's working, but when it comes time to displaying the empeg screen, it shows a gray box..) going to the directory and calling ./displayserver works though - path problem?
-mark
MK2: 36gb
Tivo: 90gb
CPU: 120gb
#22683 - 19/11/2000 22:42 Re: New displayserver 1.1 [Re: borislav]
fvgestel
Loc: Netherlands
username: ttt
password: ttt
Frank van Gestel
Frank van Gestel
#22684 - 19/11/2000 22:46 Re: New displayserver 1.1 [Re: fvgestel]
Unfortunately the server now seems to be down..
#22685 - 20/11/2000 08:44 Re: New displayserver 1.1 [Re: fvgestel]
dionysus
....another suggestion; would be nice to reroute the arrow keys in the displayapplet to the buttons; and maybe even a double-sized option for us blind (...or working on 10.4" laptop screen) people...
-mark
MK2: 36gb
Tivo: 90gb
CPU: 120gb
#22686 - 20/11/2000 12:02 Re: New displayserver 1.1 [Re: dionysus]
fvgestel
Loc: Netherlands
The empty init should be fixed, the applet should also work normally now
That's true; you can shut off authentication by giving an argument to displayser
so instead of starting with
# ./displayserver
use
# ./displayserver noauth
In fact you can give it any argument you like it only checks for the parameter.
I'm currently implementing some configfile.
You can use mediaplayer, realplayer or sonique to use authentication.
The latest realplayer visuals are great...
Frank van Gestel
Frank van Gestel
#22687 - 20/11/2000 12:10 Re: New displayserver 1.1 [Re: rob]
fvgestel
Loc: Netherlands
I have to spend a lot of time with my empeg this week, mainly in the car.
Alas, the empeg is back online:
username : ttt
password : ttt
Frank van Gestel
Frank van Gestel
#22688 - 20/11/2000 12:15 Re: New displayserver 1.1 [Re: fvgestel]
debauch
Loc: West Midlands, England
Thought people may be interested to know how I, a numpty regarding these things, got on installing this.
- Apply new kernel
- Rename install.sh to install.sh.mpg and upload.
- Look at the CSV to get the FID of the upload, turn that into hex.
- Realise that I don't have the developer image installed, install it.
- Get to the bash prompt and use 'rwm' command to mount /empeg rw.
- Create dir /empeg/var/temp and copy install.sh into it. Set the permissions and execute ./install.sh
- Watch it fall over horribly because / wasn't mounted rw.
- Spend ages working out how to mount / rw.
- Run install.sh again. Choose to have display server started on boot.
- Reboot. Get stuck at init# prompt (there were some version numbers there, but I don't remember them)
- Realise that nothing's mounted, realise that I don't have a clue what to do.
- Reinstall developer image, wait ages because database needs rebuilding after I moved install.sh out.
- Reinstall kernel
- Mount everything rw
- Run install.sh. Choose not to have it start on boot.
- Test. Everything seems fine (view playlists, play songs), but...
- Browser gets stuck at "Opening page http://192.168.1.7/empeg.html" when I try and open either "empegApplet in new window" or "empegApplet in current window".
- That's it. Any ideas?
If anybody wants to see how far I've gone, have a look on http://client74-220.hispeed.ch:13470/. I'll leave it up for a couple of hours.
Nick.
18Gb blue - s/n 080000299 (original queue position 8724)
OK. As a late addition, displayserver's been running for a few minutes and I've got a few of these come over the serial port:
displayserver: memory violation at pc=0x40073894, lr=0x020036b0 (bad address=0x0
0000000, code 2)
pc : [<40073894>] lr : [<020036b0>]
sp : bffff508 ip : 40073890 fp : bffffd88
r10: 400ff128 r9 : 02003404 r8 : 02003e28
r7 : 02000abc r6 : 4000c2a8 r5 : 00000001 r4 : bffffdc4
r3 : 00000000 r2 : 00000400 r1 : 00000000 r0 : 00000000
Flags: nzCv IRQs on FIQs on Mode USER_32 Segment user
Control: D01A917D Table: D01A917D DAC: 00000015
Function entered at [<02003404>] from [<40037040>]
r4 = BFFFFDC4
Function entered at [<40036ee4>] from [<02000e98>]
r10 = 4001D858 r9 = 00000000 r8 = 00000000 r7 = 00000000
r6 = 02000E74 r5 = 00000000 r4 = 4001E5EC
Any ideas?
Edited by debauch on 20/11/00 08:29 PM.
-- 18GB red s/n 080000299
#22689 - 20/11/2000 12:53 Re: New displayserver 1.1 [Re: debauch]
fvgestel
Loc: Netherlands
dis you start it up with ./displayserver ?
the correct way would be :
# cd <install-dir>
# ./displayserver
where <install-dir> is the directory you unpacked the install.sh file
the crash at the end is probably caused by the applet not shutting down the connection it opened to retrieve fascia.jpg
Frank van Gestel
Frank van Gestel
#22690 - 20/11/2000 13:06 Re: New displayserver 1.1 [Re: fvgestel]
debauch
# cd
# ./displayserver
I had started it with "/usr/local/displayserver/displayserver", but even changing to the directory first yields the same results.
Nick.
#22691 - 20/11/2000 13:18 Re: New displayserver 1.1 [Re: debauch]
fvgestel
Loc: Netherlands
I can use it remotely though...
Frank van Gestel
Frank van Gestel
#22692 - 20/11/2000 13:53 Re: New displayserver 1.1 [Re: debauch]
fvgestel
Loc: Netherlands
you can also find out the file by typing the following commands in the shell :
# cd /drive0/fids
# ls -lrt *0
the file you last uploaded should be at the bottom of the list
It should check at startup now that everyting is mounted readwrite.
If it isn't it is done automatically. At the end of the script everything is mounted ro again
the init stuff should now be working; I've tested it with my own empeg.
Frank van Gestel
Frank van Gestel
#22693 - 20/11/2000 14:18 Re: New displayserver 1.1 [Re: fvgestel]
debauch
AH. No. Problem solved.
Why is there never a Tony around when one needs a good dope slap?
I'd disabled Java in IE way way back and had forgotten all about it. It was only when it started working with Netscape that I wondered what the hell I'd done!
Cheers.
Nick.
#22694 - 20/11/2000 14:33 Re: New displayserver 1.1 [Re: debauch]
I'm around, I sometimes just choose to allow folks to self-administer.
#22695 - 20/11/2000 15:12 Re: New displayserver 1.1 [Re: fvgestel]
dionysus
Hmm.. I think there might be a problem with long playlists.. I have an "unsorted" directory which has 200-300 songs in it - trying to get a list from that playlist displays about half the list, then hangs..
-mark
MK2: 36gb
Tivo: 90gb
CPU: 120gb
#22696 - 20/11/2000 15:21 Re: New displayserver 1.1 [Re: fvgestel]
dionysus
Hmm.. I can't get sonique to work w/ auth, and realplayer ASKS for a username/pasword, but still has problems... glad to see there's a noauth option though...
-mark
MK2: 36gb
Tivo: 90gb
CPU: 120gb
#22697 - 20/11/2000 15:26 displayserver 1.1 - dualdrive bug... [Re: fvgestel]
dionysus
OK - found a bug - if a file and it' description get split up between two different drives, then the program fails to download that file... i.e.
File 13640 is in /drive1/fids/13640, while
file 13641 is in /drive0/fids/13641 - your app fails in this case, although the debug screen doesn't show an error (and in fact shows the file going through...) maybe check if the file exists, and if it doesn't check the other drive?
-mark
MK2: 36gb
Tivo: 90gb
CPU: 120gb
#22698 - 22/11/2000 16:07 Re: displayserver 1.1 - dualdrive bug... [Re: dionysus]
fvgestel
Loc: Netherlands
I thought I programmed it this way :
check if file exists in /drive1/fids
if so , change directory to /drive1/fids
if not change to /drive0/fids
read file <fidnumber>
It seemed I was changing directories correctly, but was reading an absolute filename ("/drive0/fids/<fidnumber>")
It is fixed now
The process list in system-info has also been updated; it now shows the correct terminal name and vsize and rss now report in Kb.
I've attached the new executable and source to this post; install.sh has been updated...
Frank van Gestel
1-22002-displayserver.zip (44 downloads)
Frank van Gestel
#22699 - 22/11/2000 20:14 Re: displayserver 1.1 - dualdrive bug... [Re: fvgestel]
dionysus
Hey Frank,
Just to confirm, it seems to work now... (now if we could only get it to "stream" what it's actually playing...)
-mark
MK2: 36gb
Tivo: 90gb
CPU: 120gb
#22700 - 24/11/2000 11:58 Re: displayserver 1.1 [Re: fvgestel]
Smoker_Man
Loc: Calgary, CANADA
This is one kick butt util!!
Good job Frank!
I have one question, how do I apply the kernel patch? I am a linux simpleton, so a few directions would be appreciated!
Thaks for a great product!
2x160Gb MkII Lighted Buttons 080000449
#22701 - 24/11/2000 12:14 Re: displayserver 1.1 [Re: Smoker_Man]
dionysus
hey; search for Tony's (tfabris) logoeditor - it has a feature that let's you apply a kernal..
-mark
...proud to have owned an Empeg since 00287
#22702 - 24/11/2000 12:16 Re: displayserver 1.1 [Re: dionysus]
Is that what he was asking? I though he was asking how to apply a code patch to the kernel source code based on a .diff file, which is a completely different question.
#22703 - 24/11/2000 12:23 Re: displayserver 1.1 [Re: tfabris]
dionysus
...I think what he *meant* to ask is how to upload the included kernal file that come w/ the displayapplet..:)
-mark
#22704 - 24/11/2000 13:13 Re: displayserver 1.1 [Re: dionysus]
Smoker_Man
wow, I guess I should clarify!
How do I patch the kernel with the patch that comes with the display applet?
The kernel.patch file ??
#22705 - 24/11/2000 14:04 Re: displayserver 1.1 [Re: Smoker_Man]
Smoker_Man
The applet works well, other than my previous post, but I am getting a few errors, or what I think are errors:
My reading skills allow me to deduce that my problem is the same as debauch's, however my linux skills (none) allow me to scratch my head and (hopefully) believe nothing is amiss.
STREAM1
displayserver: memory violation at pc=0x40073894, lr=0x020036a4 (bad address=0x0
0000000, code 2)
pc : [<40073894>] lr : [<020036a4>]
sp : bffff528 ip : 40073890 fp : bffffda8
r10: 400ff128 r9 : 020033f8 r8 : 02003dcc
r7 : 02000abc r6 : 4000c2a8 r5 : 00000002 r4 : bffffde4
Control: C807D17D Table: C807D17D DAC: 00000015
Function entered at [<020033f8>] from [<40037040>]
r4 = BFFFFDE4
STREAM1
Mk2, using developer image 1.01
Page 1 of 3 1 2 3 >
