#227075 - 14/07/2004 19:33 Bugs in v3alpha8
The "Lavatory Floor" visual crashes the player in an infinite loop until "player -i" is entered at the serial port. BIG problem. The release notes suggest that this is a known issue, but also that this visual wasn't supposed to be present in alpha8 -- it is present.
Also, on Mk2a with 32MB, the long buffering from disk at the start of each track causes the UI to become completely non-responsive until the buffering from disk has completed. Some voluntary scheduling points in the code could fix this -- I may hack it into the syscalls within Hijack if need be.
Edited by mlord (14/07/2004 20:24)
#227076 - 14/07/2004 20:25 Re: Bugs in v3alpha8 [Re: mlord]
Hijack v397 is now released, and incorporates a workaround to prevent the infinite crash loop that otherwise results from selecting the Lavatory Floor visual.
#227077 - 14/07/2004 21:35 Re: Bugs in v3alpha8 [Re: mlord]
The AnnaVU and other spectrometer type visuals all seem "muted" in v3alpha8 -- much less dynamic movement than in v3alpha7 and earlier releases.
#227078 - 15/07/2004 11:55 Re: Bugs in v3alpha8 [Re: mlord]
Yeah, that seems to be my fault -- I was sure I'd disabled it, but CVS tells me differently.
Still, that's why these hastily-prepared releases (the datestamps on the CD are genuine) get a limited rollout to start with. I've already fixed the thing about the Receiver Edition not dealing with static IP addresses.
#227079 - 15/07/2004 12:36 Re: Bugs in v3alpha8 [Re: peter]
mschrag
Loc: Richmond, VA
Receiver Edition
I believe you just filled in one of our Bingo card slots in the release notes.
#227080 - 15/07/2004 12:51 Re: Bugs in v3alpha8 [Re: mlord]
robricc
On my 56kbps MP3s which are about 1 hour long a piece, they don't resume anywhere near where I left off when shutting the car. I think they seem to resume about 10 minutes behind or where the track starts.
#227081 - 15/07/2004 13:01 Re: Bugs in v3alpha8 [Re: peter]
Daria
If I'm willing to bend over, the onus is on me...
#227082 - 15/07/2004 13:16 Re: Bugs in v3alpha8 [Re: mlord]
The AutoEQ does not maintain a flat curve when run with NO MICROPHONE connected. This may or may not be a bug, but it kinda makes it difficult for me to tell if my MIC jack is actually hooked up or not.
Also, I'm not sure, but I belive the "PrevVisual" buttoncode from v2.00 is STILL missing from v3alpha8. Whenever somebody has a second or two, it would be very nice to have it back in there again!
#227083 - 15/07/2004 13:30 Re: Bugs in v3alpha8 [Re: mlord]
Yes, there's now been a fair amount of development on car v2 since it was branched from the trunk, including Previous Visual, making the play counter optional in Track Info, and a huge amount of RDS code which I don't personally understand. We indeed really ought to merge all that stuff into v3 sometime.
#227084 - 15/07/2004 15:41 Re: Bugs in v3alpha8 [Re: peter]
alex25
Loc: Switzerland
In Antwort auf:
Is it possible that the karma 2 includes a RDS tuner?
#227085 - 15/07/2004 15:52 Re: Bugs in v3alpha8 [Re: peter]
Including a whole bunch of bug fixes made to 2.0 since the time of the branch split. I'm really looking forward to having all the old pre-2.0 bugs re-fixed in 3.0 so I can start using it as my daily driver. Any chance of that happening sometime?
#227086 - 15/07/2004 17:42 Re: Bugs in v3alpha8 [Re: tfabris]
Well, yes and no. Almost everything was merged a long time ago, it's just the few last fixes for 2.00final and 2.01 which haven't been. Are there any particular bugs you're talking about? I didn't think you got RDS in the US...
#227087 - 15/07/2004 17:43 Re: Bugs in v3alpha8 [Re: peter]
In the past year, RDS has even shown up here in my part of Canada! But currently just the RDS display part, not the TA or AF functions.
#227088 - 15/07/2004 17:46 Re: Bugs in v3alpha8 [Re: tfabris]
Daria
Send me a copy of 3a8 and I'll tell you what's still broken
#227089 - 15/07/2004 17:50 Re: Bugs in v3alpha8 [Re: peter]
We get so little RDS that it's not a factor, correct. I was talking about non-RDS stuff. Things like... Player is unresponsive when it is reading from the disk, certain visuals crash the player if left up and running, the menu font is misalingned with the menu borders, that sort of thing. My memory is extremely fuzzy on what bugs I noticed in 3a7 that were leftovers from 2.x betas, but a peek through the old bugbase (if it's still there) would probably refresh my memory. Also a lot of us reported leftover 2.x bugs in the bugs forum here on the BBS during the alphas, someone should look through those probably and see if there's still there in the latest alphas.
Edit: I remember one specific one. Somewhere along 2.0 you made "Plays: x" optional, and it was still permanently in there in the alphas last I checked. Of course, I've still not yet seen the Amersfoort 2004 alphas, so it might have changed in those.
Edit: This thread has a few 3a7 bugs that we might want to check again to see if they're still there in the 2004 alphas.
Edit: Another one I *seem* to remember existing in 3a7 that was fixed in 2.0, was the thing with the codec/bitrate sometimes not showing up on the track info screen because the number of lines on that screen was variable.
#227090 - 15/07/2004 18:16 Re: Bugs in v3alpha8 [Re: tfabris]
Yes, I mentioned that above. That list I posted above was from the code diff, so anything else wrong with v3 either wasn't fixed in v2 or (more commonly I suspect) wasn't applicable to v2. (Well. We also added a screen for setting the time in AM/PM as opposed to 24h, fixed a bug where inserting or appending into a playlist always unpaused the player if paused, and changed the confirmation message for "Hate Artist" to be less confusing. But those seemed too minor to mention.)
The caching code, for instance, got completely rewritten; if there was a bug in early v2 that had the same symptoms as the current v3 unresponsive-during-caching bug, then it's just a coincidence.
Edit: I'm not saying there're no bugs in v3 alpha 8, of course, I'm just saying that a v2-to-trunk merge is only going to fix one or two of them.
#227091 - 15/07/2004 18:19 Re: Bugs in v3alpha8 [Re: peter]
OK cool.
#227092 - 15/07/2004 18:23 Re: Bugs in v3alpha8 [Re: peter]
genixia
That was one of my requests, and now you come to mention it, has been bugging my subconcious again recently.
#227093 - 16/07/2004 12:00 Re: Bugs in v3alpha8 [Re: peter]
I have a fix for this now, yet another ugly hijack hack!
Look for v398 shortly.
#227094 - 16/07/2004 12:07 Re: Bugs in v3alpha8 [Re: peter]
On a related note..
v3alpha8 is rather slow at startup (compared with v2.01), expecially during its initial read of the database and playlist files.
This looks easy to fix: the player currently reads database and playlist a sector at a time (512 bytes), which is rather inefficient. Simply switching to a larger buffer size (eg. 4096) should greatly improve the startup time.
#227095 - 16/07/2004 12:17 Re: Bugs in v3alpha8 [Re: mlord]
Daria
emacs the binary!
#227096 - 16/07/2004 12:33 Re: Bugs in v3alpha8 [Re: mlord]
pim
Oh, yes, I would love a fix for that. With 20.000 or so tunes, it takes me three or
four blocks before any sound is heard.
I assume this needs to be changed in the player, no hijack hacks possible there.
Pim
#227097 - 16/07/2004 12:42 open sourcing RDS tuner code [Re: alex25]
pim
I've always wondered whether the tuner software is shared at all
with other products. If not, how about open sourcing the tuner code?
With RDS circumstances so different across the world, the
official development team will never be able to address all issues.
The hardest part, I guess, for this would be to implement the
tuner code into a shared library, like was done for the WMA code.
Pim
#227098 - 16/07/2004 15:30 Re: Bugs in v3alpha8 [Re: mlord]
My 16MB Mk2a here repeatedly crashes at about the same spot on a certain track. Setting ReserveCache=12 fixes it.
Crashlog attached.
226381-crash.txt (1120 downloads)
#227099 - 16/07/2004 15:35 Re: Bugs in v3alpha8 [Re: mlord]
Ooops.. spoke too soon. It crashed again just after posting.
Second crashlog attached.
No crashes at all on my 32MB Mk2a, with ReserveCache=64.
EDIT: MMmmm.. not so sure about this crash -- the autochange visual was 0x18, one before "Lavatory Floor" -- perhaps it was crashing just as the visual was trying to change to the LF crasher..
So, I stopped the player, and loaded a modified Hijack which automatically deselects 0x18 (as well as 0x19), and now it's not crashing (yet).
226387-crash2.txt (1128 downloads)
Edited by mlord (16/07/2004 15:47)
#227100 - 24/07/2004 20:40 Re: Bugs in v3alpha8 [Re: mlord]
Another bug today:
Total tight-loop lockup of v3a8 while attempting to play a specific tune (available if needed). No messages, just load average of 7.82, stuck in a real-time priority thread somewhere. Recovery impossible without "player -i".
#227101 - 24/07/2004 23:39 Re: Bugs in v3alpha8 [Re: mlord]
Hijack wish, can we get a way to do "player -i" on the road?
#227102 - 25/07/2004 00:02 Re: Bugs in v3alpha8 [Re: mlord]
Daria
How did this behave? Unresponsive UI?
#227103 - 25/07/2004 13:47 Re: Bugs in v3alpha8 [Re: drakino]
Absolutely brilliant idea.
#227104 - 25/07/2004 15:54 Re: Bugs in v3alpha8 [Re: drakino]
It's called the ;@MENU_EXEC macro, which is currently half-implemented. Someday I'll tackle the more difficult half.
