#225880 - 06/07/2004 14:59 Why can't I complete a sync?????
edsmiata
Loc: New Jersey
I am using 2.0 final-Windows XP Home and USB...but I still can't complete a sync without having to either run it again or reconnect the USB cable....It eventually gets done but I fear something is amiss...I get various error codes, but I cannot figure out what they mean..
Any help?
Thanks,
Ed
#225881 - 06/07/2004 15:02 Re: Why can't I complete a sync????? [Re: edsmiata]
Greetings!
What kind of error codes and messages do you see?
#225882 - 06/07/2004 15:06 Re: Why can't I complete a sync????? [Re: pgrzelak]
edsmiata
Loc: New Jersey
Paul...all types! I will try to upload some songs tonight and make a log of the error codes.
What I find intresting is the fact that I am eventually able to get through the sync and all songs and playlists are where they should be. So what would cause this to happen?
#225883 - 06/07/2004 15:34 Re: Why can't I complete a sync????? [Re: edsmiata]
Unknown. There are a few different things that could be happening. That's why the log files and error codes will help.
#225884 - 06/07/2004 16:10 Re: Why can't I complete a sync????? [Re: edsmiata]
Did you check this FAQ entry?
#225885 - 06/07/2004 16:29 Re: Why can't I complete a sync????? [Re: tfabris]
edsmiata
Loc: New Jersey
Hmmmm..I did not know that...I just upgraded the software in the HU and Emplode....I will get on it tonight and see what happens...Thanks!!!
#225886 - 06/07/2004 16:33 Re: Why can't I complete a sync????? [Re: tfabris]
edsmiata
Loc: New Jersey
Now that I am reading the RElease Notes I can safely say I did nothing at all to install the driver ....
#225887 - 06/07/2004 17:20 Re: Why can't I complete a sync????? [Re: edsmiata]
Not a good thing.
#225888 - 21/07/2004 09:25 Re: Why can't I complete a sync????? [Re: pgrzelak]
edsmiata
Loc: New Jersey
OK, so now that I have had the chance to check on my driver I am in fact using the RIOHD.SYS driver, which it seems for XP is not a good thing.
Looking at the release notes for updating the driver, it tells you to ....Choose to install the driver from a specific location and point it at wherever you've unzipped the emplode installer....
The emplode utilities are downloaded onto my C drive, but when I find the folder the OK button is grayed out. So then how would I go about updating the driver if the Wizard will not let me select the folder that the driver is located in???!!??!
thanks,
Ed
#225889 - 21/07/2004 09:26 Re: Why can't I complete a sync????? [Re: pgrzelak]
edsmiata
Loc: New Jersey
...also, it seems that it will only let me update drivers that are located in my Windows folder..FWIW
#225890 - 22/07/2004 12:37 Re: Why can't I complete a sync????? [Re: tfabris]
edsmiata
Loc: New Jersey
...anybody....anybody...Beuler...anybody??
#225891 - 22/07/2004 16:49 Re: Why can't I complete a sync????? [Re: edsmiata]
Emplode 2.0 must be fully unzipped, and there should be an .INF file in the folder where you unzipped it along with rioxdrvsys. You must dig through the Windows wizard dialog boxes in the device manager until you find a button that says "HAVE DISK" and press it. Then feed it that INF file.
At least I think that's how it's supposed to go.
#225892 - 22/07/2004 16:51 Re: Why can't I complete a sync????? [Re: tfabris]
#225893 - 22/07/2004 17:06 Re: Why can't I complete a sync????? [Re: pgrzelak]
He already read the release notes I'm sure. I think he was trying to follow them, but probably got lost by the fact that he never pressed the "HAVE DISK" button. Either that or he was trying to get the driver from the "program files/rio/emplode" folder instead of from wherever he unzipped the 2.0 distro.
#225894 - 22/07/2004 17:11 Re: Why can't I complete a sync????? [Re: tfabris]
edsmiata
Loc: New Jersey
You are correct! I hit the Browse button instead...will give it a go tonight
#225895 - 22/07/2004 19:41 Re: Why can't I complete a sync????? [Re: edsmiata]
There is a browse button AFTER the "Have Disk" button I think. But you have to at least get to the point where you hit the Have Disk button.
Since I don't have XP running in front of me, I can't give you the exact button presses. If someone else has the exact button presses, perhaps they can post them here?
#225896 - 23/07/2004 00:05 Re: Why can't I complete a sync????? [Re: tfabris]
edsmiata
Loc: New Jersey
I am impressed!!! Just went through the whole process and it worked! In fact...also fount the config.ini file!!!
#225897 - 23/07/2004 08:29 Re: Why can't I complete a sync????? [Re: edsmiata]
Excellent! Is everything stable at this point?
#225898 - 23/07/2004 10:33 Re: Why can't I complete a sync????? [Re: pgrzelak]
edsmiata
Loc: New Jersey
Yes, remarkably so.....now i just have to get the unit to Eutronics for some touch up soldering and im good to go!
