#224836 - 16/05/2004 19:01 Shoutcast streams for Central released...
geeknerd
http://sourceforge.net/projects/grandcentral/
It's called "grandcentral", but it's not quite grand yet. I've been using it for a few months, and it's stable. It's not pretty and it's a pain to set up new stations.
However, it does play shoutcast streams.
If you have some ideas for features feel free to drop them here or over on sourceforge.
I'm thinking about expanding it to do more, but I need to see what they have done with hijack first to see what I can snag from that so I don't have to repeat work. (Not that I did much of anything original for this, it was mostly snagged from other code.)
Instructions: Burn the iso to disk, pop it in, and pray.
Disclaimer: I had to take my rio apart once because I locked up the player... let others try if first if you aren't comfortable popping the cover and manually ejecting the CD.
#224837 - 16/05/2004 19:24 Re: Shoutcast streams for Central released... [Re: geeknerd]
geeknerd
Oh yeah, special thanks to the Rio guys for making your code relatively easy to understand.
Has anyone made modifications to the rio central source code? I made a few tweaks, and if someone is already maintaining it, I'd rather just give the source to them. If not, I'll post the source on sourceforge.
#224838 - 17/05/2004 00:35 Re: Shoutcast streams for Central released... [Re: geeknerd]
So I take it that hole under the cd door isn't a manual eject ?
#224839 - 17/05/2004 10:45 Re: Shoutcast streams for Central released... [Re: msaeger]
geeknerd
Nope, it's just a hole. I've been thinking of rigging up a lever so that I could use that hole to push the eject button. However, I only had to pop the cover once, and I'm 90% sure it was due to some wierd mounts I had setup, etc.
I don't know of anyone else who has setup a linux distribution on their central, so I doubt anyone else would need to open the cover to eject the disk.
#224840 - 18/05/2004 10:40 Re: Shoutcast streams for Central released... [Re: geeknerd]
Don't bother trying to rig up any way to press the CD drive's eject button. It doesn't work even if you press it.
I have had a long standing problem on my Central where certain front-panel buttons don't work at all (and despite a lot of help from Hugo with the schematics, I still cannot find the fault, it's not in the ribbon cables connecting the display to the motherboard), so I am unable to eject the disc though normal means as well. Opening the case and pressing the drive's built-in eject button has no effect. Details in this thread.
(Side note: You may ask, how do I ever get the thing to eject the disc at all? I do it by going into the main menu and saying multiple CD mode.)
#224841 - 18/05/2004 16:42 Re: Shoutcast streams for Central released... [Re: tfabris]
geeknerd
Hmmm. The cdrom button did work for me. However, I think it only works for a second or two after the unit gets power. That, or I pulled out the cdrom and put it in a usb external housing and hit the button. I don't remember exactly what trickery I used, but I do remember that it worked.
#224842 - 18/05/2004 23:10 Re: Shoutcast streams for Central released... [Re: geeknerd]
When I try to burn the iso with nero it complains there is an error and may create a bad disk. I tried it anyway but when I stick the disk into the central it does nothing.
#224843 - 18/05/2004 23:26 Re: Shoutcast streams for Central released... [Re: geeknerd]
Now I tried it with alcolol 120% and it appears to have installed so here's a stupid question. How do I set up a station ?
#224844 - 19/05/2004 06:45 Re: Shoutcast streams for Central released... [Re: msaeger]
geeknerd
1) Go to the "games" menu and make sure it's there.
2) Read the brief instructions (use the pad to navigate, play to click and standby to exit)
3) Make sure it works (play one of the stations)
Ok, if you get this far, here's the very ugly part:
The station url and names are kept in a file:
/empeg/games/GrandCentral/etc/stations
You have to manually edit that file (probably have to ftp it off unless the central comes standard with an editor).
#224845 - 19/05/2004 08:21 Re: Shoutcast streams for Central released... [Re: geeknerd]
Nope it's not under games. The install ran fine without an error.
#224846 - 19/05/2004 18:45 Re: Shoutcast streams for Central released... [Re: msaeger]
geeknerd
Interesting.
Mind going through a small list of stuff?
1. What version of the firmware are you running?
2. Could you check if /upgrader_out is present in the root directory? If so, could you post it or message it to me?
thx.
#224847 - 22/05/2004 09:19 Re: Shoutcast streams for Central released... [Re: geeknerd]
geeknerd
BTW, has anyone else had success / failure?
