#223661 - 12/09/2003 10:04 trio 0.1.4.alpha4 and listen mode
rjv
Folks...
Anyone have any problems getting listen mode to show up on their Rios with trio 0.1.4 alpha4? I have two receivers - one in my bedroom and one in my living room - and for the life of me, I can't get the "Listen" mode to show up in the modes list in either the LCD display or the Web applet front-end - for either receiver. Closest I've come is getting it to start in Listen mode, but it is still unavailable to be picked from the list. Any ideas? I'm guessing I have something screwy with my trio.xml (it is posted below.)
Thanks for your help!
3853-trio.xml (295 downloads)
#223662 - 12/09/2003 12:18 Re: trio 0.1.4.alpha4 and listen mode [Re: rjv]
hipped1
The only problem I've encountered related to the fact that one of my Rios in ethernet connected, the rest are home phonline connected. Per the user manual:
Limitations
HPNA or multi-homed hosts: if your host PC has more than one network card (e.g. both hpna and ethernet cards), tRio can only synchronise playback between Receivers attached to the same card. Receivers on other cards will not appear in the Listen To dialog.
#223663 - 12/09/2003 16:00 Re: trio 0.1.4.alpha4 and listen mode [Re: rjv]
pauln
This is a known problem that was introduced in alpha4. PM me with your email address and I'll send you a fix.
Paul
Paul (the tRio guy)
