#223015 - 18/04/2003 21:53 Yay I got it and have questions
The first question I have so far is can I edit the disk info before I record it onto the central. Like now I put the disk in it records it onto the central then I have to use emplode to go and edit the info. Is there someway I can do this on the central ?
#223016 - 18/04/2003 22:43 Re: Yay I got it and have questions [Re: msaeger]
Here is another question
Is there a to make it so when I put the unit in standby the display is shut off by default so I don't have to press two buttons.
#223017 - 19/04/2003 10:36 Re: Yay I got it and have questions [Re: msaeger]
Yes. You can do this either with the remote control, or with a USB keyboard.
#223018 - 19/04/2003 10:38 Re: Yay I got it and have questions [Re: msaeger]
I'm not sure what you mean. When I press the "power" button on my central or on my central's remote control, the display changes to a clock and the backlight turns off. I only need to press one button, not two.
Please tell me which two buttons you're pressing, and please more clearly define "display is shut off". It's possible that you might be describing a known bug and you need to get the online software update. Not sure.
#223019 - 20/04/2003 00:02 Re: Yay I got it and have questions [Re: tfabris]
I figured out how to edit it after the tracks are on the central but is there a way to change the info before it starts recording the CD.
On the HP de100c I have it lets me edit the info then start recording the disk on the HSX109 it immediatly starts to record when the disk is inserted.
#223020 - 20/04/2003 00:11 Re: Yay I got it and have questions [Re: tfabris]
Mine has the buttons labeled "standby" not power
Mine goes to the clock when I press "standby" there is also a button on the remote that says "display" that shuts off the display totally. I would prefer it to just totally shut off the screen when I press "standby" and not have the clock.
#223021 - 20/04/2003 00:15 Re: Yay I got it and have questions [Re: msaeger]
Now here is a real problem.
My unit keeps rebooting when recording a cd.
I have is set to do multiple cd's and it will just restart while it is recording.
I had it check for software updates and it has the latest. (1.02 build 19 )
I have done about 30 disks and it has restarted 6 times.
#223022 - 20/04/2003 00:24 Re: Yay I got it and have questions [Re: msaeger]
What emplode version should I be using.
I tried to use the 2.0 final version that I was using on my empeg but it would crash every time I tried to edit the info for a group of tracks.
edit:
I tried the 2.0 beta 13 version and it seems to work better.
Edited by msaeger (20/04/2003 03:13)
#223023 - 21/04/2003 09:02 Re: Yay I got it and have questions [Re: msaeger]
The "info" is the Gracenote CDDB, so if you know how to edit that database file...
#223024 - 21/04/2003 09:04 Re: Yay I got it and have questions [Re: msaeger]
Ah. I see. I never turn off the clock.
#223025 - 21/04/2003 09:06 Re: Yay I got it and have questions [Re: msaeger]
This is a bug in the factory software. It is corrected in the next software update.
Cambridge guys: Is that one officially online yet?
#223026 - 21/04/2003 09:08 Re: Yay I got it and have questions [Re: msaeger]
Any 2.0 version shoudl be OK. I haven't had any trouble with 2.0 final. Can you reproduce an exact series of clicks that will cause the problem?
#223027 - 21/04/2003 14:42 Re: Yay I got it and have questions [Re: tfabris]
I will try it again after I get all the disks ripped.
Still compressing.
#223028 - 24/04/2003 13:23 Re: Yay I got it and have questions [Re: tfabris]
QA insist we screwed portable download reliability so the release has never been authorised. Personally I believe download is no more flakey than it was before.
#223029 - 25/04/2003 10:33 Re: Yay I got it and have questions [Re: rob]
Darn darn darn. I would hazard a guess that there are more folks who would benefit from the update (say, those who bought Dell-branded receivers and need it to run those, or those who record multiple CDs which is probably EVERYBODY) than those who would encounter problems with the portable-download feature.
Is there a way to unofficially release it as an FTP download?
#223030 - 25/04/2003 10:44 Re: Yay I got it and have questions [Re: tfabris]
Jerz
Loc: Jesusland
...hmmm...tough choice for me since I have a rebadged unit as well as a Rio 800. The download feature makes life a lot easier when doing yardwork since I can download and listen to whatever I want without blaring the stereo throughout the neighborhood.
I wouldn't mind however testing this upgrade and if it doesn't work out to my liking then I can simply downgrade my unit to the old version (couldn't I?)
#223031 - 25/04/2003 15:52 Re: Yay I got it and have questions [Re: Jerz]
Provided you already have the old version on a CD, yes. There is no provision for downgrading in the online-update system, it can only upgrade.
#223032 - 25/04/2003 16:49 Re: Yay I got it and have questions [Re: tfabris]
Jerz
Loc: Jesusland
...uhhh....I know I've got that around here somewhere. It may be at the office, but it is definately in a place where I can find it.
#223033 - 25/04/2003 20:14 Re: Yay I got it and have questions [Re: tfabris]
With the cd included with the unit can I just reinstall the player software without wiping the hdd and losing the music ?
#223034 - 25/04/2003 23:28 Re: Yay I got it and have questions [Re: msaeger]
Yes. It is similar to the car player in this respect.
When you insert the CD it asks you if you want to either upgrade the software or "restore to as new". The latter option is the one that erases the music too, quite similar to the builder image on the car.
#223035 - 26/04/2003 03:02 Re: Yay I got it and have questions [Re: tfabris]
Cool then I can fix it without loosing everything if I screw it up messing around.
#223036 - 26/04/2003 10:21 Re: Yay I got it and have questions [Re: msaeger]
I'm not sure about that... I don't remember whether the standard upgrade needs undamaged software files to function right. The "Restore to as new" will always work, but I don't know if the standard upgardes have been fail-safed like the car player.
