#220023 - 12/05/2001 00:41 HPNA under Linux?
phaigh
I was thinking about my setup at home that I'll have when I get a Receiver.
I'm intending to run the server on Linux - can I support the HPNA adapter under Linux as well?
This may be a significant sticking point - I might end up having to go wireless ethernet in the end.
Paul.
RioReceiver - Still Waiting for one in the UK.
Paul Haigh, Reg. 4120 (mk1) 6GB, Blue, 00254 (mk2) 12GB, Red, 00357
#220024 - 12/05/2001 08:17 Re: HPNA under Linux? [Re: phaigh]
Linux HPNA drivers exist (we obviously had the source to get them working with the receiver) but they've never been released.
You could try asking broadcom, but it would be a binary-only release in module form. I don't think our contract allows us to give it out, unfortunately. The source is pretty proprietary as a lot of the sub-IP retransmission & link management functions are implemented in the driver and not the silicon.
#220025 - 12/05/2001 10:10 Re: HPNA under Linux? [Re: altman]
phaigh
Pity,
Binary only doesn't particularly bother me, as long as it works.
I'll try speaking to BroadCom (who make the cards I guess) and see what I get (a blank response most likely).
Pity, since the wireless ethernet is costly!
Paul.
#220026 - 13/05/2001 06:44 Re: HPNA under Linux? [Re: phaigh]
mardibloke
Loc: Penarth, UK
IMHO Wireless Ethernet for home, is now affordable and decent enough speed for most applications.
Rod, UK Mk2 64gig Red S/No.341 Empeg 2 x DELL Reciever
Rod, UK
#220027 - 23/08/2001 05:48 Re: HPNA under Linux? [Re: mardibloke]
jason
Has anyone gotten this working? I just bought two rio receivers (at bestbuy in
Newington, NH) yesterday, and would like to set one up in my bedroom (which
doesn't currently have any ethernet run to it). I do have wireless in the house,
but this solution will probably be much cheaper than buying another wireless
bridge.
In addition, an even nastier thought: does HPNA work with phone-line-over-AC
extenders that modulate the phone signal over your house power lines?
#220028 - 23/08/2001 09:47 Re: HPNA under Linux? [Re: jason]
You could just run the Receiver Manager software on a Windows server with an HPNA card, and then HPNA should work fine. Are you saying that Linux is a requirement for you?
I wouldn't count on the phone-line-over AC working with HPNA. I'm pretty sure you need the physical connection for HPNA to work. The AC stuff only works for low-frequency, low-bandwidth signals I'm guessing.
_________
#220029 - 23/08/2001 09:55 Re: HPNA under Linux? [Re: tfabris]
jason
Yes, linux is a requirement. I'm sorry if I wasn't clear on that...
Hopefully someone has done it, and has a quick how-to. If not, I'll start digging myself, and let y'all know if I succeed.
Regarding the phone-line-over-AC, my assuption is that is wouldn't work. But, I figured I'd ask anyways. I don't have the hardware to test, myself. I suspect there may be some kind of warning in the HPNA documentation...
-j
#220030 - 24/08/2001 06:03 Re: HPNA under Linux? [Re: jason]
I've heard that linksys have released linux drivers that will drive (almost any, I suspect) PCI hpna2.0 card. Try ftp.linksys.com. The card is the HP200, I seem to remember that for no adequately explained reason, the linux driver was hidden in a dos .exe self-extractor...
No source, but better than nothing.
#220031 - 24/08/2001 06:27 Re: HPNA under Linux? [Re: altman]
jason
Thanks, Hugo. I found the same info from some google searching.
For the benefit of others: You can find the driver at ftp://ftp.linksys.com/beta/linux_full_binary_2_33.exe
which uses a dos/win unpacker that makes you agree to a standard license before it unpacks two modules and a readme. The contents of the latter:
Linux Release 2_33
Linux network device driver for the Broadcom BCM42XX PCI
InsideLine 10Mbps Home Phoneline Networking chip.
This release includes:
- support for HPNA 2.0 Certification Testing
- MODVERSIONS support for Linux 2.2 and 2.4 Kernels. These
modules have been compiled and tested with MODVERSIONS defined
on a RedHat 6.2 system with include files from the RedHat
2.2.14-5.0 kernel. The driver for the 2.4 kernel uses the
2.4.0-test10 kernel distribution from ftp.kernel.org.
Note: The kernels should be compiled with nonSMP
This distribution includes two il.o executables:
- \Kernel_2.2.14-5.0\il.o ---> 62545 bytes (nonSMP)
- \Kernel_2.4.0-Test10\il.o ---> 70695 bytes (nonSMP)
I should get a chance to try this out in a week or so. I'll let others know if I succeed.
(Let's just hope I have a free PCI slot in my only non-SMP machine...)
-j
