#21800 - 03/11/2000 13:23
one last upgrade question biggest gig drive
what is the largest gig slave drive I can add to my mk2?
#21801 - 03/11/2000 14:53
Re: one last upgrade question biggest gig drive
[Re: silvercas]
what is the largest gig slave drive I can add to my mk2?If you are planning on buying a warrantied drive from Empeg, then whatever they've got up at the Empeg Store is the largest you can get. If you are willing to void your warranty, then it can can be pretty much any 2.5" laptop drive you can get your hands on. Whatever the biggest one is. See the FAQ section of the BBS on the exact specifications for the disk drive. ___________ Tony Fabris
#21802 - 03/11/2000 15:07
I believe the 30 Gig IBM's are the leaders at the moment... || loren.cox || 080000446
#21803 - 03/11/2000 21:30
Loc: Sunnyvale, CA, USA
A friend of mine told me that there may be incompatibilities between laptop drives from different manufacturers. He mentioned "grounding problems" but nothing more specific than that. Has anybody had any issues with a laptop drive not working with the empeg (apart from dimensions) or know what the exact problem might be?
Borislav
#21804 - 04/11/2000 20:12
[Re: borislav]
Everything we've tried has worked so far. There are sometimes problems with mixing ATA drives, although I doubt it has anything to do with grounding, so if you want to be safe I'd advise going with a Toshiba or IBM Travelstar drive.
The largest right now is 30Gb from IBM, but they are rumoured to be coming out with a 40Gb unit at some point.
#21805 - 05/11/2000 15:28
[Re: rob]
Loc: Canberra, Australia
Rob,
With Sonic Blue's purchasing department now on the case, do you see the larger size hard drives as being any easier to have in stock?
I'd like to get the largest single-hard-drive unit I can.
Save the whales. Feed the hungry. Free the mallocs.
#21806 - 06/11/2000 03:43
[Re: rob]
When making dual-drive players out of whatever winchesters were lying around the office, I have had a couple of problems. I first found a Toshiba drive which simply didn't cope with being a slave to an IBM: it just didn't appear. I don't know whether it was a type of Tosh we ever shipped though.
The other problem, once I'd found a second IBM drive, is that the empeg assumes that once one drive has spun up, the other isn't far behind. This is perfectly valid for shipped dual-drive players as they all have two identical drives, but if you upgrade with a drive that spins up radically quicker or slower than your existing one, the slower one could get timed out and ignored.
#21807 - 06/11/2000 04:43
[Re: peter]
can ROB or some1 @ empeg tell us what model and drive there using to upgrade. I'd also be interested in the speed of the drive
Alan
#21808 - 06/11/2000 10:38
[Re: rob]
Loc: Penarth, UK
32gig IBM drives appear to be shipping in quantity. Believe they are 19.5mm but not had time to try and cram a couple into my empeg yet.
- -- Rod, UK Mk2 18gig Red S/No.341
- -- Rod, UK
#21809 - 06/11/2000 12:46
[Re: mardibloke]
From memory, I think the 32Gb IBM drives are the high spin-rate - the 30Gb model would probably be a better bet for the car player.
#21810 - 06/11/2000 13:05
[Re: rob]
Loc: Penarth, UK
Could you expand on pros and cons of high spin rate ?
- -- Rod, UK
#21811 - 06/11/2000 15:18
[Re: mardibloke]
High spin rate offers little benefit to the car player, which doesn't have a particularly high speed IDE bus (and which caches ahead large amounts of data anyway). On the down side the faster drives have lower shock tolerances, run hotter and cost more.
#21812 - 06/11/2000 16:04
[Re: rob]
Loc: Penarth, UK
Thanks, its finically best for me to either go for the 18 or 32gig drives, so its just the shock and heat I need to be concerned about. I could not find any evidance in the specs that the 32 will run hot, however the shock figures are a minor worry. More interestingly the 32gig drive weights a little more and I wonder how the drive bay mountings would perform in the empeg ? List of available drives, and links to full specs at http://www.storage.ibm.com/techsup/hddtech/table.htm
- -- Rod, UK
#21813 - 06/11/2000 16:50
[Re: mardibloke]
Okay, dumb question... why go for the 32 over the 30? Is it that you can't get your hands on a 30 gig? Aren't the 32 gigs more expensive? Just curious as i'm planning on adding one of these puppies myself... || loren.cox || 080000446
#21814 - 06/11/2000 23:38
[Re: loren]
Am I wrong about this or did the laptop drives all become more expensive? Can anyone tell me some cheap online stores otherwise?
Has the "coming closer christmas" something to do with the price and will it maybe fall after christmas? I've also heard something about 40GB drives but haven't seen any price for it at this time.
TeeMcBee Got my Mk2! # 080000143
TeeMcBee [orange]Mk2, # 080000143, 40+30 GB, Tuner, Peugeot stalk hookup</font color=orange>
#21815 - 07/11/2000 01:46
[Re: loren]
Loc: Penarth, UK
I would certainly guess the 30gig is cheaper for most people.
- -- Rod, UK
#21816 - 07/11/2000 02:43
[Re: teemcbee]
Loc: Netherlands
I thought they were rather cheap : http://www.intra.nl/whsthtp.htmlFrank van Gestel
Frank van Gestel
#21817 - 07/11/2000 03:40
[Re: fvgestel]
Thanx - But they seem to be quite expensive. As I remember they have been a bit lower about 2 or 3 weeks ago. Or am I totally wrong?
#21818 - 07/11/2000 04:19
[Re: peter]
I thought that Mike had fixed this by modifying the timeouts? One of the few remaining Mk1 owners... #00015
#21819 - 07/11/2000 04:42
[Re: schofiel]
the toshiba 18 gig 2.5 drives here in US seem to be around 200. check out www.pricewatch.com
#21820 - 11/03/2001 12:43
[Re: rob]
I'm considering adding a 2nd drive to my Empeg, and the IBM 20GB model (DJSA220) is looking nice at $137 US. However in the specs, they use two different interfaces, ATA-4 and ATA-5. I'm not familiar with laptop IDE interface specs, so my question is will the Empeg support this drive? If it's supported, I'm all over it.
-Tony MkII #554
#21821 - 12/03/2001 02:11
[Re: tonyc]
Yes, this drive works fine, it's the one we use in the 20GB empeg.
ATA is backwards compatible.
#21822 - 12/03/2001 06:43
[Re: altman]
Splendid. I'm ordering one today.
For those looking for an upgrade, $137 is the best price I've seen lately for an Empeg drive. The 30GB and 32GB models (even competitive mfgr's like Fujitsu) seem to still be close to $400, so 20GB for $137 (plus shipping) looks great to me.
http://www.edgemicro.com/ for anyone else who's running out of space. -Tony MkII #554
#21823 - 12/03/2001 10:52
[Re: tonyc]
here's a 30 gig IBM for $309 plus shipping. ARgh... they are more tempting by the day... Must... have....... more.....storage.....
|| loren.cox || 080000446 ||
#21824 - 12/03/2001 11:06
[Re: loren]
Heh.. Yeah more storage is KEY. I never thought 18GB would fill so fast.
I avoided the 30GB because the price per GB just isn't good enough ($10/GB for 30, $7.50/GB for 20.) Plus I think 38GB will keep me satisfied long enough for prices to come down further. The 32GB models are out of the question since they're not as shock-tolerant as noted in an earlier post.
-Tony MkII #554
#21825 - 12/03/2001 12:57
[Re: tonyc]
Hahaha... $10/gig being expensive is just odd. You are correct of course... it's just the rapid decrease in storage prices makes that seem like such a wrong statement! =] $100 a gig wasn't so long ago.
#21826 - 12/03/2001 13:10
[Re: loren]
It seems just recently I paid $300 for a desktop 1.6gb drive to replace the 540 meg one I had for a while.
#21827 - 12/03/2001 13:21
[Re: loren]
Hehe... Yes, calling $10/GB "expensive" does sound ridiculous, especially when I look at the WD Caviar 31600 sitting idle on my computer desk, and remember the $200+ I once paid for it. Now I've ordered a drive with 15 times more capacity for far less money, and it just happens to be a laptop drive. But back then I didn't have all this music that had to be in my car! :)
Of course, thinking back to my days of swapping 5.25" 360k disks to get between screens of The Colonel's Bequest makes the mere mention of the word "gigabyte" ridiculous. When I first heard the word at about age 11 or 12, I imagined a room full of hard drives in some big corporation, somehow linked together to equal an ENTIRE GIGABYTE. Now I'll be carring close to 50 GB around in my car stereo.
Progress is SWEET. :)
-Tony
MkII #554
#21828 - 12/03/2001 13:48
[Re: tonyc]
We have a big room here full of harddrives somewhere around many terabytes. Last I herd, they wanted it up to one petrabyte, and they may have already done it. And it's all for show. All part of being in the complex with Storage Networking Industry Associates I suppose.
#21829 - 12/03/2001 19:40
[Re: drakino]
Ahhh, you youngsters. The first computer I ever worked with was a Datpoint mini computer, with an absolutely massive storage capacity of five whole megabytes. (That's hard drive, not RAM -- the RAM was probably in the vicinity of 16K or so.)
That five megabyte hard drive (one fixed and one removable platter, 2.5 MB each) was the size of a two-drawer filing cabinet, cost over $8,000 (in 1976, when $8,000 would buy you a new Mercedes Benz) and was so unreliable that the service man averaged 1.6 visits per month to repair it.
Man, I miss the good old days. Not!
