#218070 - 09/06/2004 07:39 Internet Explorer Picture Problems
burdell1
Lately whenever I click on a photo that is on the web (I use Internet Explorer), instead of a filename name popping up (as a .jpg) it comes up 'Untitled' and is a bitmap, not a jpeg. It is very annoying. I have heard that it is a bug. however, the only way I found around it was to delete all the temporary internet files. It would be good for awhile, but then I would have to reset it again. Any ideas on a fix for this?
#218071 - 09/06/2004 07:45 Re: Internet Explorer Picture Problems [Re: burdell1]
Nope. I get exactly the same problem as well and it's usually because IE has gone a little odd and decided to leave several thousand old files in the cache. Clearing the downloaded program files folder also sometimes helps.
#218072 - 09/06/2004 07:57 Re: Internet Explorer Picture Problems [Re: tman]
I don't get that problem, and my IE cache has just shy of 12,000 files in it. Clearing out the cache from time to time can't hurt, though.
#218073 - 09/06/2004 08:03 Re: Internet Explorer Picture Problems [Re: burdell1]
Cybjorg
Loc: Winston Salem, NC
Clear your cache. It always works for me.
#218074 - 09/06/2004 08:03 Re: Internet Explorer Picture Problems [Re: Cybjorg]
burdell1
been there, done that....it is gettin worse now...I tried the fix that Microsoft recommends, but it didn't help
#218075 - 09/06/2004 08:46 Re: Internet Explorer Picture Problems [Re: burdell1]
Use Firefox?
#218076 - 09/06/2004 09:12 Re: Internet Explorer Picture Problems [Re: wfaulk]
Or, if Firefox doesn't quite do it for you (it almost was enough for me but not quite), then try MyIE2. I've seen the problem in IE you described but haven't had it happen since I started using MyIE2. It may be because MyIE2 doesn't have that bug, or it could be because I've got it programmed to clear my cache (but not my cookies) each time I exit it, so my cache never gets too messy for the bug to appear.
#218077 - 09/06/2004 09:36 Re: Internet Explorer Picture Problems [Re: Roger]
These files hang about even if I tell IE to clear it's cache. I've no idea why they're being forgotten by IE.
#218078 - 09/06/2004 19:11 Re: Internet Explorer Picture Problems [Re: wfaulk]
burdell1
i'd rather just use IE....there has to be some sort of fix for this....it hasn't happened before now.....
#218079 - 09/06/2004 22:55 Re: Internet Explorer Picture Problems [Re: burdell1]
Glen_L
Loc: Elk Grove, CA
Is this the same problem recently discussed on Ars Technica? Along with clearing the cache, they advise deleting any "unknown" or "damaged" programs in %systemroot%\Downloaded Program Files.
No longer a stranger, finally a full-fledged member! \:D
#218080 - 09/06/2004 23:38 Re: Internet Explorer Picture Problems [Re: Glen_L]
burdell1
I found that on the microsoft website, but it only helped temporarily...then it seems it does the same thing again, in a shorter amount of time.....any other ideas?
#218081 - 10/06/2004 00:48 Re: Internet Explorer Picture Problems [Re: burdell1]
Glen_L
Loc: Elk Grove, CA
Try reading through the discussion from the previous link. In particular, somebody mentioned CacheSentry will fix the problem although I didn't see it listed as a fixed bug on their page.
#218082 - 10/06/2004 06:40 Re: Internet Explorer Picture Problems [Re: Glen_L]
g_attrill
Loc: Hants, UK
When I used IE I installed CacheSentry to fix the untitled.bmp problem and it definately solved it.
Gareth
#218083 - 13/06/2004 08:38 Re: Internet Explorer Picture Problems [Re: g_attrill]
burdell1
there has to be another solution....Does this CacheSentry have to be running all the time for it to work?
#218084 - 13/06/2004 09:02 Re: Internet Explorer Picture Problems [Re: g_attrill]
When I installed CacheSentry, it completely b0rked Internet Explorer. I had to uninstall it, and poke around in the cache directory myself, before it would work again properly.
Just a warning.
#218085 - 03/07/2004 13:24 Re: Internet Explorer Picture Problems [Re: Roger]
burdell1
i tried decreasing the amount of file space dedicated to the cache, but that only helped for a little while. any other ideas besides getting a different web browser? it is really frustrating....
