#217535 - 01/06/2004 21:40 Missing Playlist?
SE_Sport_Driver
This has been happening to me in my root playlist for ages now... since 2.00 betas I believe. I was just never bugged enough to do anything about it. I've tried creating new playlists and reorganizing it to fix it... Nothing seems to work... Anyone else have this?
#217536 - 01/06/2004 21:53 Re: Missing Playlist? [Re: SE_Sport_Driver]
SE_Sport_Driver
Just opened up Jemplode and a thought came to me...
Is "Unattached Items" #5?
#217537 - 01/06/2004 22:34 Re: Missing Playlist? [Re: SE_Sport_Driver]
Daria
i thought it was #2.
#217538 - 01/06/2004 22:35 Re: Missing Playlist? [Re: Daria]
Daria
Nope
not 2
#217539 - 02/06/2004 05:27 Re: Missing Playlist? [Re: SE_Sport_Driver]
adavidw
Loc: Utah, USA
It's really whatever position you want it to be. It's invisible in Emplode, but visible in jEmplode, but even in Emplode it takes one of the position slots. You should be able to use the arrows to move your "To File" playlist up into the number 5 spot, which would leave unattached in the 6 spot, and get your numbers in order at least.
-Aaron
#217540 - 02/06/2004 05:32 Re: Missing Playlist? [Re: adavidw]
SE_Sport_Driver
For some reason, in Emplode, I can't move playlists around with the arrow buttons in the root playlist. They are greyed out. All other playlists can be sorted manually.
#217541 - 02/06/2004 06:03 Re: Missing Playlist? [Re: SE_Sport_Driver]
Er, precisely because the "Unattached Items" playlist is hidden. Unfortunately, Tony (I think) found a bug in the move up/down buttons where emplode would crash when moving playlists in the root. It was caused by an off-by-one error directly caused by the presence of a hidden playlist.
We didn't have time to fix it before whichever release was due out next, so I simply turned the functionality off in the root playlist.
My bad.
#217542 - 02/06/2004 06:06 Re: Missing Playlist? [Re: SE_Sport_Driver]
adavidw
Loc: Utah, USA
I remember that now. I remember having to put numbers in the artist field of the playlists in my root so that I could sort them that way as a workaround.
Perhaps jemplode will let you reorder?
-Aaron
#217543 - 02/06/2004 06:06 Re: Missing Playlist? [Re: Roger]
My bad.
By the way: the Set Playlist Order menu option still works in the root playlist.
If you'd prefer to have your playlists in a custom order, one possible workaround is to rename your root playlists as, e.g, "00 Genres", "01 Artists", "02 Special Playlists", "03 Soundtracks", etc., and then use the Set Playlist Order function. Then change the names back.
You might still have a gap in the numbering where the "Unattached Items" playlist would be, but it's a minor irritation (IMO).
Alternatively, use JEmplode.
#217544 - 02/06/2004 06:15 Re: Missing Playlist? [Re: Roger]
adavidw
Loc: Utah, USA
Or just stick the numbers in the "artist" field (or some other unused one) and leave them there.
-Aaron
#217545 - 02/06/2004 18:47 Re: Missing Playlist? [Re: Roger]
SE_Sport_Driver
Thanks Roger! That fixed it. Like I said, it never really bothered me that much. Posted it more as a curiousity.
#217546 - 08/06/2004 05:29 Re: Missing Playlist? [Re: adavidw]
sundayjumper
Loc: West Berkshire
I fill out the "artist" field with the directory names I have on the PC, e.g. "Bowie, David", and put the name I want to appear on the Empeg as the playlist name, e.g. "David Bowie". Then just sort by artist to get them in the right order.
Steve.
Mk2a 10+40Gb Darkstorm Neon Red Nakamichi CD45z, Genesis Five Channel, Genesis A16s, JL 8W6 x3
