#217053 - 25/05/2004 16:54 mk2a with 32MB panics hijack
pim
I just had my mk2a upgraded to 32 MB. I loaded hijack v391 before upgrading.
After turning it on, it passed the memory test, but unfortunately the kernel
panic's soon afterwards. It always panics or oopses at the same spot.
I tried v390, v391 and v392 without luck. Hugo's bootloader did not have
effect either. Reverting back to v380, which I used before makes the
problems (and the extra memory) go away.
Here's a dump of a v392 oops using Hugo's e000.rom.
So, is this a hardware or a software problem?
Maybe we need a more thorough memory test?
Thanks,
Pim
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v392 (root@localhost.localdomain) (gcc version 2.95.3 20010315 (release)) #2 Mon May 24 15:31:28 PDT 2004
Checking for extra DRAM:
c1000000: passed.
c1100000: passed.
c1200000: passed.
c1300000: passed.
c1400000: passed.
c1500000: passed.
c1600000: passed.
c1700000: passed.
c1800000: passed.
c1900000: passed.
c1a00000: passed.
c1b00000: passed.
c1c00000: passed.
c1d00000: passed.
c1e00000: passed.
c1f00000: passed.
c2000000: wrote ffffffff, read 00000000
empeg-car player (hardware revision 9, serial number 40104351)
Command line: mem=16m
Memory: 31240k/32M available (980k code, 20k reserved, 524k data, 4k init)
Dentry hash table entries: 4096 (order 3, 32k)
Buffer cache hash table entries: 32768 (order 5, 128k)
Page cache hash table entries: 8192 (order 3, 32k)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
TCP: Hash tables configured (ehash 32768 bhash 32768)
Starting kswapd v 1.5
Signature is 206f6972 'rio '
Tuner: loopback=0, ID=-1
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004180).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hdb: IC25N080ATMR04-0, ATA DISK drive
hda: IC25T060ATCS05-0, ATA DISK drive
hda: IC25T060ATCS05-0, 57231MB w/1768kB Cache, CHS=7296/255/63
hdb: IC25N080ATMR04-0, 76319MB w/7884kB Cache, CHS=9729/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:10:ff
Partition check:
hdb: hdb1 hdb4
RAMDISK: Loading 320 blocks [1 disk] into ram disk... <1>Unable to handle kernel NULL pointer dereference at virtual address 00000020
memmap = C0004000, pgd = c0004000
*pgd = c012f801, *pmd = c012f801, *pte = c000000b, *ppte = c000000a
Internal error: Oops: 0
CPU: 0
pc : [<c002a9a4>] lr : [<00000020>]
sp : c0003828 ip : c1f98fa0 fp : c0003844
r10: 00000000 r9 : c0103f38 r8 : c0003868
r7 : 00000005 r6 : 00000000 r5 : c0103fd8 r4 : c0181740
r3 : 00000000 r2 : e58bc018 r1 : 00000005 r0 : c0181740
Flags: nZCv IRQs off FIQs on Mode SVC_32 Segment kernel
Control: C000517D Table: C000517D DAC: 0000001D
Process swapper (pid: 1, stackpage=c0003000)
Stack:
c0003800: 00000020 c002a9a4
c0003820: 60000093 ffffffff 00000000 c0103fd8 00000000 00000400 c0003860 c0003848
c0003840: c0033f14 c002a940 c1f98f20 00000800 00000000 c0003898 c0003864 c0033fdc
c0003860: c0033ea8 c1f90000 c0002000 00000000 00000000 c1f90000 00000400 00000100
c0003880: c0103f98 c0103f38 00000048 c00038b8 c000389c c003493c c0033f9c 00000400
c00038a0: 00000000 00000001 00000100 c00038cc c00038bc c003370c c00348d4 00000400
c00038c0: c00038fc c00038d0 c00338d8 c0033708 c00038fc 00001000 00000001 00000000
c00038e0: 00000000 00000400 00000000 00000048 c0003b58 c0003900 c003760c c00337b8
c0003900: 00000001 00000100 00001000 00000000 00000000 00000000 00000000 00000400
c0003920: c0003c68 00000400 c0191800 c0003c54 00093fa7 0800b2a1 ba03a7ff 6a949b67
c0003940: 4100008c 0246dd49 885805ff 8645bf6f a10398ea 060070d8 8e5c873f 6a11d3de
c0003960: 00401843 40121458 8431ebed af07aa77 9300eedb 1a20329c ba52bed7 ac15f7df
c0003980: 04114800 a050f8b3 2e7567d7 240028d3 8000f24b a0647f7f ae53bdff 5a601fae
c00039a0: 40180e90 cf57fae7 2b15ff7c 008926c8 00123d3a bae7fef1 2b5169d7 041230c4
c00039c0: 084495af 5255fc1b ac4f8fad 100430bd a0000013 c0003a30 c010d9ac c0003a00
c00039e0: c00039ec c000f580 00000000 0000001a 00000340 00000001 c0003a20 c0003a08
c0003a00: c00d51a8 c00bae30 00000000 00000000 c012c210 c011f244 00000000 c0121d68
c0003a20: c01120f0 c011f244 00000000 c0121d68 c0003a58 c0003a40 c00bb19c c001560c
c0003a40: c011f1d0 00000000 00000000 c0003a68 c0003a5c c00bbce0 c00bb0cc c0003a78
c0003a60: c0003a6c c00cf2e4 c00bbcd8 c0003a90 c0003a7c c0015d54 c00cf2e0 00000001
c0003a80: c0121dcc c0003aac c0003a94 c001e820 c01946e0 00000003 00000060 00000000
c0003aa0: c0003ad8 c0003ab0 c000ab68 c000a9d0 fa050000 c0003b24 00000001 c00e427c
c0003ac0: 20000013 ffffffff c0003c54 c0003b58 c0003adc c0009e60 c000aa6c c01918a4
c0003ae0: d00bd8a4 00000000 0affffec c00f4513 c011273b c0109018 00000002 00000000
c0003b00: 00000002 c011273e c0003b48 c0003b18 c0019830 c001560c 00000000 00000002
c0003b20: 00000040 00000400 00000400 c0003cc0 00000048 00000048 c0191800 c0003cac
c0003b40: 00000000 00000140 c0003c54 c0003f84 c0003b5c c00a1100 c00374a4 00000140
c0003b60: 00000005 00000000 00000000 000001fa 5c2d2f7c 00000000 00000000 c0003d04
c0003b80: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003ba0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003bc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003be0: 00000000 00000000 00000000 c0003e30 00000000 00000000 00000000 00000000
c0003c00: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003c20: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003c40: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 c0003b74
c0003c60: c0108798 00000003 00012000 00000000 00000000 00000000 00000001 00000000
c0003c80: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003ca0: 00000000 00000000 00000000 00000000 00000000 c0003be4 c010875c 00000001
c0003cc0: 00012400 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003ce0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003d00: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003d20: 00000000 00000000 00000000 01000000 00000000 00000000 00000000 00000000
c0003d40: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003d60: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003d80: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003da0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003dc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003de0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003e00: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003e20: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003e40: 00000000 00000000 00000000 00000000 00000000 00000000 01fa0000 00000000
c0003e60: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003e80: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003ea0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003ec0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003ee0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003f00: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003f20: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003f40: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
c0003f60: 00000002 00000080 c012aea0 c0122540 4401a11b c0008580 c0003f94 c0003f88
c0003f80: c00a12e4 c00a0d48 c0003fb4 c0003f98 c00468ec c00a12d4 00000001 c0100768
c0003fa0: c012188c c0108754 c0003fdc c0003fb8 c0009ac0 c00467b4 00000000 c0009b88
c0003fc0: c012b80c c0100760 c0100764 c0100988 c0003ffc c0003fe0 c0009b98 c00099b4
c0003fe0: c0009b88 c012b80c c0100760 c0100764 c00fffd8 c0004000 c000b6cc c0009b94
Backtrace:
Function entered at [<c002a934>] from [<c0033f14>]
r7 = 00000400 r6 = 00000000 r5 = C0103FD8 r4 = 00000000
Function entered at [<c0033e9c>] from [<c0033fdc>]
r6 = 00000000 r5 = 00000800 r4 = C1F98F20
Function entered at [<c0033f90>] from [<c003493c>]
r10 = 00000048 r9 = C0103F38 r8 = C0103F98 r7 = 00000100
r6 = 00000400 r5 = C1F90000 r4 = 00000000
Function entered at [<c00348c8>] from [<c003370c>]
r7 = 00000100 r6 = 00000001 r5 = 00000000 r4 = 00000400
Function entered at [<c00336fc>] from [<c00338d8>]
r4 = 00000400
Function entered at [<c00337ac>] from [<c003760c>]
r10 = 00000048 r9 = 00000000 r8 = 00000400 r7 = 00000000
r6 = 00000000 r5 = 00000001 r4 = 00001000
Function entered at [<c0037498>] from [<c00a1100>]
r10 = C0003C54 r9 = 00000140 r8 = 00000000 r7 = C0003CAC
r6 = C0191800 r5 = 00000048 r4 = 00000048
Function entered at [<c00a0d3c>] from [<c00a12e4>]
r10 = C0008580 r9 = 4401A11B r8 = C0122540 r7 = C012AEA0
r6 = 00000080 r5 = 00000002 r4 = 00000000
Function entered at [<c00a12c8>] from [<c00468ec>]
Function entered at [<c00467a8>] from [<c0009ac0>]
r7 = C0108754 r6 = C012188C r5 = C0100768 r4 = 00000001
Function entered at [<c00099a8>] from [<c0009b98>]
r8 = C0100988 r7 = C0100764 r6 = C0100760 r5 = C012B80C
r4 = C0009B88
Function entered at [<c0009b88>] from [<c000b6cc>]
r7 = C0100764 r6 = C0100760 r5 = C012B80C r4 = C0009B88
Function entered at [<c00096c4>] from [<c00098a4>]
Function entered at [<c00096dc>] from [<c0008080>]
r7 = C0121D60 r6 = C0121CB4 r5 = C012C240 r4 = C012C240
Code: e3530000 1a00001a (e58ec000) e5943008 e063500e
#217054 - 25/05/2004 17:35 Re: mk2a with 32MB panics hijack [Re: pim]
pim
Some extra testing:
Using Hugo's e000.rom, hijack v386 and v387 don't crash, but don't detect
the extra memory either. v388 does detect 32MB, but crashes.
Pim
#217055 - 27/05/2004 10:51 Why does the empeg boot process require a ramdisk? [Re: pim]
pim
This part of the bootlog made me wonder:
Why does the boot process require a ramdisk? At this point, the harddrives
are already detected, so why not just mount the root filesystem immediately?
And where is the data store that is loaded into the ramdisk?
Pim
#217056 - 27/05/2004 13:02 Re: Why does the empeg boot process require a ramdisk? [Re: pim]
In flash. I don't remember the address, though.
#217057 - 27/05/2004 14:47 Re: Why does the empeg boot process require a ramd [Re: pim]
The initrd (ramdisk) contents are in flash at 0b0000, and are reprogrammed by any s/w upgrade. I'm not sure what the initrd is used for, since the linuxrc executable therein is a binary (rather than the usual simple command script).
But regardless -- your memory is bad. The Hijack DRAM test is not exhaustive, nor failsafe, since achieving those goals would significantly slow down boot times. But odds are very good that the data pins are fine, and the problem you have is with the address lines. Touch all of those up with the iron and try again.
#217058 - 27/05/2004 14:57 Re: Why does the empeg boot process require a ramd [Re: mlord]
Question (knowing I am asking for trouble):
Could a version of the kernel be put together for people installing / testing memory upgrades that would give an exhaustive memory test, just to verify the installation. This was somewhat fortunate, given that it panicked early. However, if a different spot in memory was corrupt and it was not seen until later on, it could be much more difficult to identify. Especially if it did not cause a panic.
#217059 - 27/05/2004 15:43 Re: Why does the empeg boot process require a ramd [Re: pgrzelak]
Testing DRAM is very complex, and difficult to get right. Each mem write has to be verified to go to one and only one location. It has to check for stuck bits, crossed lines, shorted lines, and failed refresh. And also has to deal with the CPU caches (simply marking the sections as "non-cachable" doesn't seem to be enough..).
Even the code I have there now was difficult to get working, and I'm still not sure if it has successfully defeated the various caching mechanisms completely.
So, in short, I could produce a special memtest kernel if someone else provides the working code. Otherwise, it's a tough nut to crack.
#217060 - 27/05/2004 16:05 Re: Why does the empeg boot process require a ramd [Re: mlord]
How does the existing memory test (ctrl-T at boot) do it? If it can see the added memory space, a special kernel would not be needed.
#217061 - 27/05/2004 16:50 Re: Why does the empeg boot process require a ramd [Re: mlord]
skibum
Loc: Swindon, UK
probably just a stupid idea (I'm full of them), but can't the 'special' version just loop around writing/reading patterns too all the detected memory forever and just print errors when it doesn't read back what it wrote. If you write the whole 16/32mb before reading it back, won't the cache have been flushed, as there is no way it can cache that much.
Anyway just a thought.
#217062 - 28/05/2004 00:53 Re: Why does the empeg boot process require a ramd [Re: mlord]
genixia
What is our immediate purpose? To test the RAM itself or the installation? Are all the address lines tested with a 0x00,0x55,0xaa,0xff pattern like the data lines are, or do only the high address lines get hit as sparse locations are tested?
I'd argue that the nature of the upgrade merits hitting all of the address lines, but that a full memory test is not necessary for the Mk2/Mk2a (assuming that the chips were handled properly.)
The Mk1 is an interesting case. We know from Hugo that the Mk1 chips have a known high failure rate, and we also know that the upgrade itself is easier and less prone to problems.
Anyway, http://www.esacademy.com/faq/docs/memtest/index.htm has useful strategies for testing data lines, address lines and a full device test. They even have sample code that could be adapeted.
#217063 - 01/06/2004 16:49 Re: mk2a with 32MB panics hijack - solved [Re: pim]
pim
Pin A3 needed some extra solder. Everything's fine now.
Thanks,
Pim
