#216132 - 12/05/2004 22:59 ati 9800 all in one
thrasher
Hi, anyone no if I can hook my empeg to the audio inputs and play music on my computer.
040103958 60g
#216133 - 12/05/2004 23:06 Re: ati 9800 all in one [Re: thrasher]
Does it have audio inputs ? All of the all in wonder cards I have used do not have audio in you connect that to your sound card.
#216134 - 12/05/2004 23:08 Re: ati 9800 all in one [Re: msaeger]
thrasher
yes it has a external plug with audio l and r and video and s-video.
040103958 60g
#216135 - 12/05/2004 23:39 Re: ati 9800 all in one [Re: thrasher]
According to the instructions for the AIW9800 you still connect it to the line in on your sound card. You connect the breakout box to the A/V in on the videocard then there is another cable that connects to A/V out on the videocard. That cable has a jack that you connect to the line in on a soundcard.
#216136 - 13/05/2004 07:15 Re: ati 9800 all in one [Re: thrasher]
DeadFire
I have my empeg connected to the Line In on my sound card using one of these. However, my sound card happens to be a digital 6 channel integrated into the motherboard, and the sound is much improved when I stream my mp3s from it to Winamp. The audio remains in digital form all the way to the speakers, rather than being converted to analog and then back to digital again. This can be done with Mark Lord's multiuseful Hijack. You'll find a link to it at the top of any page on this BBS.
#216137 - 13/05/2004 10:08 Re: ati 9800 all in one [Re: msaeger]
thrasher
I am not quiet sure I understand what you mean.I pluged in the ati input adapter to the A/V in on the ati card then I pluged the empeg into the the adapter.Will it work like that.
040103958 60g
#216138 - 13/05/2004 10:41 Re: ati 9800 all in one [Re: thrasher]
If your ATI video recording software has what's called a "monitor out", allowing you to hear and see the output of whatever it's trying to record on its AV inputs, then yes that should work. You'll probably have to stare at a blank video playback window at the same time, but oh well.
I think what everyone is wondering is why you don't just use your sound card's line input?
#216139 - 13/05/2004 11:08 Re: ati 9800 all in one [Re: tfabris]
Will those video-card audio inputs not show up in the Audio Control Panel as audio inputs? I'd think they would, but, then, I'm always surprised at the things ATI driver developers do.
#216140 - 13/05/2004 11:49 Re: ati 9800 all in one [Re: tfabris]
thrasher
The reasone I am having a problem.Because I do not no what I am doing.lol Thr only reasone I bought a cumputer was for my empeg and most every thing I have learned has come from everyone on this forum.I am great when it comes to working on engines and doing construction work but I am at a loss when it comes to cumputers.I have the guy who instaled my ati card coming over to help.
040103958 60g
#216141 - 13/05/2004 11:58 Re: ati 9800 all in one [Re: thrasher]
Okay, then it's clear you're going about it all wrong.
You shouldn't need anyone to help, just plug the empeg into your sound card's line input, not the video card's A/V inputs. As was said before, this is done with this cable.
If you don't know where your sound card's line input is, you should look at the manual that came with your computer. Sometimes the sound card is built in to the computer and it isn't a separate card. In that case, the line input will be one of the 1/8" plugs near the keyboard and USB inputs on the back of the computer. It will probably have a symbol that looks like this:
Odds are, your speakers are plugged in very near to it. The speakers are probably plugged into an output which has a symbol looking like this:
Once you have it plugged it in, you turn up the empeg to 0db volume, and use the sound applet in windows (it will be a little speaker icon in your task bar) to adjust the volume of the "line in".
#216142 - 13/05/2004 12:21 Re: ati 9800 all in one [Re: tfabris]
...and if your PC/soundcard is fairly new (i.e. since the PC99 spec), the Audio Line-In socket should be light blue in colour.
