#215313 - 05/05/2004 10:43 LED life
SSR
Loc: Sao Paulo, Brazil
Hi folks,
I have a vague memory about LED's (assuming the Karma uses LED's...) lasting at least several years.
But can anyone confirm the likely life of the LED's used in the display (specifically the backlight) and the docking port?
Particularly the backlight LED(s) as ideally I would like to have the backlight on the entire time (a great feature, missing in my Nomad Jukebox 3).
TIA
http://www.stainlesssteelrat.net
#215314 - 05/05/2004 10:58 Re: LED life [Re: SSR]
The backlight in the Karma is something called OLED if I recall correctly. It turns off to save battery power, not because they're worried about it burning out.
#215315 - 05/05/2004 11:07 Re: LED life [Re: tfabris]
Under the settings menu there is an option to have the backlight remain on all the time. It will use power, though, if you are running on battery.
#215316 - 05/05/2004 11:21 Re: LED life [Re: tfabris]
The backlight is EL (electroluminesent), which will get gradually less bright over a period of many years. As others have pointed out, the battery consumption is a much bigger problem.
The LED's in the dock will last indefinitely - well a *long* time anyway. I've never known an LED to wear out.
#215317 - 05/05/2004 11:37 Re: LED life [Re: rob]
Darn, I always get EL and OL mixed up.
#215318 - 05/05/2004 23:27 Re: LED life [Re: rob]
daPyr0x
Unless, of course, you're like me and your dock light wears out after less than a month. Then you can just assume that you bought something shitty for an exhorbitant amount of money
#215319 - 05/05/2004 23:59 Re: LED life [Re: daPyr0x]
I would guess it was some component failure other than an LED though
