#215132 - 02/05/2004 07:10 Tuner Module not working
NasalGoat
Loc: Toronto, ON, Canada
I've assembled the pcats tuner module I got and it doesn't work.
The empeg sees it, allows me to tune stations, and the antenna signal strengh bar goes up and down, but I get nothing but a hum from the audio.
Anyone have any ideas? I checked the solder joints and connections, everything looks okay to me.
#215133 - 02/05/2004 07:54 Re: Tuner Module not working [Re: NasalGoat]
Hi Jeremy (yes, I got your email today!).
First thing to check is the harness wiring. There were some threads around here earlier about some harnesses having a couple of wires reversed or something -- try a BBS search, and perhaps someone with a memory will post a link here for ya.
#215134 - 02/05/2004 07:56 Re: Tuner Module not working [Re: NasalGoat]
Next thing to check is the antenna connection. This is usually the culprit, since it is quite tricky to solder it correctly without shorting it to ground. Take a very close look at it, and check for non-zero resistance between the antenna wire and surrounding coaxial ground shield.
Ignore the "signal strength" on the player -- it almost always reports near-max reception, even when just listening to static.
