#214983 - 29/04/2004 16:23 Bad Karma Software????
XjaesonXmoriaX
In December I purchased a Rio Karma. It has been working great until recently. When I try and open the Rio Music Manager, a pop-up appears and says that its has encountered a problem and whether it should send or dont send. I uninstalled my Rio software, then reinstalled it. It still happens. And i updated it also, and still the same thing. What should i do?
#214984 - 29/04/2004 16:27 Re: Bad Karma Software???? [Re: XjaesonXmoriaX]
Greetings.
Hm... That is a new one by me. I didn't even know that RMM had that feature built into it. Can you post the error message you see with any details? Also, who is it trying to send (the error details via email) to?
#214985 - 29/04/2004 16:28 Re: Bad Karma Software???? [Re: XjaesonXmoriaX]
It could be something about a bad MP3 file that it's scanning. Did you recently add any MP3 files to the folders that it's got in its library?
#214986 - 29/04/2004 17:44 Re: Bad Karma Software???? [Re: tfabris]
XjaesonXmoriaX
hmm...yeah i did...it might be, but how would i be able to tell which one? after the ERROR popup, nothing happens?
#214987 - 29/04/2004 17:46 Re: Bad Karma Software???? [Re: pgrzelak]
XjaesonXmoriaX
i have no idea pgrzelak. ..I'll check tho and get back to you
Edited by XjaesonXmoriaX (29/04/2004 18:00)
#214988 - 29/04/2004 18:07 Re: Bad Karma Software???? [Re: XjaesonXmoriaX]
Divide and conquer. Take all the ones you added recently, and move them to a different place on your hard disk, a place that the Rio software doesn't scan.
Then, if the Rio software works, move half of them back. If it still works, move half of what's left back. Etc. It should only take a few tries to locate the exact file that it's choking on (if, in fact that's the problem... I'm not saying it is for sure.).
When you find the file (if it is a problem with one file), it's likely something unusual about the file itself. For instance, something corrupted in the file or something odd in its ID3 tags. Once you find the file, it would be nice to post here what you find out about it because that would be helpful to the software people so that they could correct the problem in future release of the Rio software.
#214989 - 29/04/2004 18:09 Re: Bad Karma Software???? [Re: XjaesonXmoriaX]
Something else that might be choking it is a bad version of some MP3 encoder codec. Did you recently install any new Windows codecs or codec packs?
#214990 - 29/04/2004 18:14 Re: Bad Karma Software???? [Re: tfabris]
XjaesonXmoriaX
I didnt install ay codecs..Im sure...other than the mp3 theory you have, i dont know. I download a few mp3's daily. But i know it's not a codec.
#214991 - 29/04/2004 18:23 Re: Bad Karma Software???? [Re: XjaesonXmoriaX]
RobotCaleb
ummm...
before we go anywhere else, i want to make sure that this is not Windows telling that an error has occurred
please confirm
#214992 - 29/04/2004 18:37 Re: Bad Karma Software???? [Re: RobotCaleb]
XjaesonXmoriaX
it is Windows.... it says..."Rio Music Manager has encountered a problem and needs to close. We are sorry for the inconvenience." ans then "If you were in the middle of something, the information you were working on might be lost. Please tell Microsoft about this Problem. We have created an error report that you can send to us. We will treat this report as confidential and anonymous." and then..."the following files wil be included in this error report: C:\DOCUME~2\Owner\LOCALS~1\Temp\WER1281.tmp.dir00\appcompat.txt"
#214993 - 30/04/2004 01:38 Re: Bad Karma Software???? [Re: pgrzelak]
It doesn't. This is (as explained below) the Windows Error Reporting wizard thingummy.
#214994 - 30/04/2004 04:40 Re: Bad Karma Software???? [Re: XjaesonXmoriaX]
Is it possible to post a copy of that file to the BBS?
#214995 - 30/04/2004 12:54 Re: Bad Karma Software???? [Re: pgrzelak]
XjaesonXmoriaX
Post a copy of which file to BBS? The ERROR message?
#214996 - 30/04/2004 12:56 Re: Bad Karma Software???? [Re: XjaesonXmoriaX]
XjaesonXmoriaX
I took all of my mp3's out of my music folder which RMM scans, thinking that the cause was maybe a corrupted file, and the same thing still happens. The problem still remains.
#214997 - 30/04/2004 13:04 Re: Bad Karma Software???? [Re: XjaesonXmoriaX]
Okay, so it's not an MP3 file.
At this point, do the following:
- Deinstall Rio Music Manager, Rio Taxi, and Rio Internet Update using the add/remove programs feature in the Control Panel.
- Delete the Program Files\Rio folder from the hard disk.
- Clean out all of your temporary folders completely and clear your web browser cache.
- Use Ad-Aware and a virus scanner to make sure you have no spyware or viruses.
- Download the latest version of Rio Music Manager from the rioaudio.com web site and install it. See if it works.
#214998 - 30/04/2004 13:07 Re: Bad Karma Software???? [Re: tfabris]
XjaesonXmoriaX
ok, but how do i clear out the TEMP folder? where is that located?
#214999 - 30/04/2004 13:09 Re: Bad Karma Software???? [Re: XjaesonXmoriaX]
XjaesonXmoriaX
were can i find the web browser cache also....sorry.
#215000 - 30/04/2004 13:14 Re: Bad Karma Software???? [Re: XjaesonXmoriaX]
As above. C:\DOCUME~2\Owner\LOCALS~1\Temp
#215001 - 30/04/2004 14:01 Re: Bad Karma Software???? [Re: tfabris]
XjaesonXmoriaX
okay, I deinstalled Rio, deleted everything out of all my temporary and cache folders, scanned my computer with Nortan Anti-Virus (no viruses) and scanned it with Ad-Aware and deleted the spyware programs. I the downloaded the current Rio software from the website. And Still i get the same thing. Do you think that this could be because of conflicting files??
#215002 - 30/04/2004 14:10 Re: Bad Karma Software???? [Re: XjaesonXmoriaX]
Okay, that error message points to a text file on your hard disk. Can you post that file?
#215003 - 01/05/2004 02:09 Re: Bad Karma Software???? [Re: tfabris]
You should also delete the C:\Documents and Settings\username\Local Settings\Application Data\Rio\Rio Music Manager directory when removing Rio Music Manager completely.
#215004 - 01/05/2004 08:36 Re: Bad Karma Software???? [Re: Roger]
Oooo yeah, thanks for that tip. Perhaps it's a bad piece of data in there that's crashing him? Maybe all he needs to do is delete that and restart RMM?
#215005 - 02/05/2004 13:53 Re: Bad Karma Software???? [Re: Roger]
XjaesonXmoriaX
ok....i can't find the local settings or application data foldercan you give me the steps to getting there?
#215006 - 03/05/2004 02:52 Re: Bad Karma Software???? [Re: XjaesonXmoriaX]
The Local Settings folder is hidden: you'll need to turn on hidden folders, or type the path in directly.
