#214898 - 29/04/2004 01:28 Attaching a cooling fan to the case
Mach
Loc: Texas, USA
For those folks who have done the fan upgrade, how did you attach your fan to the case lid and what works best? I'm aware of:
Farnell rivets (This was my first choice but unfortunately they won't fit the mouser fan)
Super glue (Is there potential acetic acid fumes?)
Double stick tape (How long will it stick?)
Silicone gasket adhesive (Produces acetic acid fumes)
Anything else that can be used?
#214899 - 29/04/2004 05:36 Re: Attaching a cooling fan to the case [Re: Mach]
I used the farnell rivets on mine, I have lots spare if anyone wants some.
The fan is very very tight against the display board when you are taking the top off, so it may be worth doing a dry run before you do any super glueing, the Double sided sticky tape idea sounds good to start with.
Cris.
#214900 - 29/04/2004 07:27 Re: Attaching a cooling fan to the case [Re: Cris]
maczrool
Loc: Louisiana, USA
How did you get the rivets to fully engage into the fan? I've tried everything I can think of and they never stay in because they aren't engaged all the way. The fan is set so far into the lid that getting tools that reach that far is also rather problematic.
Stu
#214901 - 29/04/2004 09:30 Re: Attaching a cooling fan to the case [Re: maczrool]
Um, not sure if I understand the problem here Stu,
Are you using the same "rivits" as me??? the ones with a puch in piece in the middle???
If I get chance I'll take some photos of the fan mounted on the back of the top plate for you and post them here.
Cris.
#214902 - 29/04/2004 09:59 Re: Attaching a cooling fan to the case [Re: Cris]
maczrool
Loc: Louisiana, USA
I think I am. They are Farnell two piece plastic rivets. I know how they should be, but no matter how much force I apply to them, they won't push through all the way.
Thanks,
Stu
#214903 - 29/04/2004 10:45 Re: Attaching a cooling fan to the case [Re: maczrool]
Mach
Loc: Texas, USA
A little back story, Stu is currently upgrading Nanci (who was on loan to Filener Laser as a tester). I forwarded rivets and 2 fans to him (one mouser and one farnell). The rivets should be Farnell part 722-4321 but I didn't double check when I received them.
Instead of installing the 5V fan as recommend by PCA in the FAQ, we went with a 12V Mouser fan. There was some concern that a fan would generate noise if connected to the same 5V header as the digital out board. Unfortunately, the rivets do not appear to be compatible. I suggested using silicone gasket adhesive to glue the fan but Stu tells me that the silicone can cause problems with the electronics. This is how I affixed the fan in my other player so I'll need to find another solution for Jolene also.
#214904 - 29/04/2004 11:27 Re: Attaching a cooling fan to the case [Re: Mach]
I used RTV silicone and I have not had any problems. Photos and a detailed description of the project including which header I used for the power are here.
#214905 - 29/04/2004 15:48 Re: Attaching a cooling fan to the case [Re: tfabris]
Mach
Loc: Texas, USA
I did the same when I installed it and haven't had any problems either. I did find a non-corrosive silicone adhesive which looks good. Stu, do you see any problems with this adhesive?
GE 162 Silicone
Noncorrosive to copper and brass, this RTV silicone paste reaches full strength at room temp. Use to bond capacitors, resistors, and integrated circuits to printed circuit boards. Also use to insulate relays, exposed copper wires and terminals. Begins to harden in 4 hrs.; reaches full strength in 48 hrs. Temp. range is -75° to +400° F. UL recognized. Color is white. Meets MIL-A-46146B.
If not, I'll have a tube shipped to you.
#214906 - 30/04/2004 16:56 Re: Attaching a cooling fan to the case [Re: Mach]
thrasher
Do any of you guys need any fans.I have two the really small ones adda dc brushless #ad0412ms-G70 12v o.o8a
040103958 60g
#214907 - 30/04/2004 17:04 Re: Attaching a cooling fan to the case [Re: Mach]
Mach
Loc: Texas, USA
Just to follow-up, I ordered a tube of GE 162 Silicone from www.mcmaster.com. I'll post back after the results are in.
#214908 - 30/04/2004 17:20 Re: Attaching a cooling fan to the case [Re: thrasher]
Laura
Loc: Greenhills, Ohio
What else besides the fans would I need?
Laura
MKI #017/90
whatever
#214909 - 01/05/2004 00:35 Re: Attaching a cooling fan to the case [Re: Laura]
thrasher
I think you just need the fan and then hook it in to the empeg.But tony would no for sure.Tony are you out there.
040103958 60g
#214910 - 01/05/2004 08:31 Re: Attaching a cooling fan to the case [Re: thrasher]
Everything I know firsthand about installing fans is in the link I provided above, everything I know secondhand about installing fans is in the FAQ.
#214911 - 01/05/2004 11:35 Re: Attaching a cooling fan to the case [Re: maczrool]
Here is a pretty bad picture of the fan mounted on the underside of the top lid of my empeg...
Sorry it's a bit blurry, I haven't quite got the hang of this new camera yet. I've been looking all over for them damm Farnell Rivits but I can't find them anywhere!!! I had a bag of about 100 and only used 4, if I find them I'll post a picture.
Hope this helps.
Cris.
#214912 - 01/05/2004 12:47 Re: Attaching a cooling fan to the case [Re: thrasher]
Laura
How much do you want for the fans? I am interested.
Laura
MKI #017/90
whatever
#214913 - 01/05/2004 18:40 Re: Attaching a cooling fan to the case [Re: Laura]
thrasher
What state do you live in. if you no anything about windows xp and think you could call me and walk me thru getting my pc to find my empegs in emplode I could just ship them to you for free.Somthing to think about, lol.
040103958 60g
#214914 - 01/05/2004 18:55 Re: Attaching a cooling fan to the case [Re: Cris]
Mach
Loc: Texas, USA
This is a pic of the same fan that Stu is trying to install for me. Looks like the mouser fans have a deeper offset than the Farnell. Without seeing the rivets in play, I'm guessing this is why they won't seat.
#214915 - 01/05/2004 21:34 Re: Attaching a cooling fan to the case [Re: thrasher]
Laura
I live in Ohio and run 98SE myself. I know next to nothing about XP and am trying to learn a little about it so I wouldn't be of any help.
Laura
MKI #017/90
whatever
#214916 - 01/05/2004 21:54 Re: Attaching a cooling fan to the case [Re: Laura]
thrasher
lol,well it was worth the try.It's a bummer not being able to add any more music on my empeg.I can ship you both fan's for 20 bucks if you want them.There both brand new. I bought them for my empeg's when they were high in my dash.I had them moved lower by my ac fan so they do not get hot anymore.
040103958 60g
#214917 - 02/05/2004 16:56 Re: Attaching a cooling fan to the case [Re: thrasher]
Laura
How would you like the money sent?
I'm sure there are plenty of XP users on the board that could help you out.
Laura
MKI #017/90
whatever
