#211756 - 01/04/2004 04:53 Version 3 Alpha / Beta ?
LTJBukem
Hi All,
It's been a long time since i've been to the board, so i think it need catch up with what is happening with V3 of the software.
I'm running V2.00 final at the moment. Very nice thank you !!
Shoud I upgrade to V3 ?
Questions:
- What features do i gain ?
- Any downsides / problems i should be aware of ?
- Can i use emplode v2.00. I read somewhere it wasn't working ?
- Where do i get it ?
LTJ
#211757 - 01/04/2004 11:07 Re: Version 3 Alpha / Beta ? [Re: LTJBukem]
Should I upgrade to V3 ?
Not if you want it to be really stable.
Playback of Ogg and Flac files.
Cross fade.
Pitch bend.
Database rebuilds do not work properly, so adding music to the player is an exercise in frustration.
The emplode 2.10 that's meant to go with alpha3 has some problems and doesn't synch properly. So I think you're supposed to use 2.00.
#211758 - 02/04/2004 03:07 Re: Version 3 Alpha / Beta ? [Re: tfabris]
In terms of the player crashing while running, seeking, skipping etc, 3.0a7 is very good. I haven't had a crash in a long time. However as Tony says, if you are looking for 100% stable then 2.00final is the option.
3.0a7 rebuilds the DB OK. 3.0a5 was the problem child there.
2.10 certainly has a number of issues. I remeber having some other problem with 2.00 so I use Jemplode instead.
#211759 - 02/04/2004 16:02 Re: Version 3 Alpha / Beta ? [Re: Shonky]
brendanhoar
My only complaint with 3.0a7 so far is the "start up the car and the empeg is not just pulsing-blue asleep but actually pulsing-blue catatonic, so a pull out, push in cycle is required" problem frequently...
...oh and the "push empeg into mlord dock, it starts up, goes to sleep *and then plays music while in this initial asleep mode*." problem.
Neither of which is annoying.
-brendan
#211760 - 02/04/2004 16:12 Re: Version 3 Alpha / Beta ? [Re: brendanhoar]
Mine has never ever done that with any version of software.
#211761 - 02/04/2004 16:13 Re: Version 3 Alpha / Beta ? [Re: brendanhoar]
mcomb
Loc: San Carlos, CA
So am I the only one for whom 3a7 restarts about every 30 minutes when in visual mode? I have my visuals set to change on track change so I am assuming that some of the visuals crash 3a7, but I haven't bothered to figure out which ones.
-Mike
#211762 - 02/04/2004 16:15 Re: Version 3 Alpha / Beta ? [Re: mcomb]
I don't really use visuals that much - I tend to look at the road mostly while driving . The only ones I really use are the InfoText ones and they seem fine. I do remember now that a particular visual caused a crash.
#211763 - 03/04/2004 03:32 Re: Version 3 Alpha / Beta ? [Re: mcomb]
Daria
IIRC it's one of the scope visuals; One of the blue people mentioned it.
#211764 - 03/04/2004 03:40 Re: Version 3 Alpha / Beta ? [Re: Daria]
Major_Sarcasm
Loc: Isle of Wight, UK
For some reason I found that intollerably funny and snorted coffee all over my keyboard. I think I remembered something from an old episode of The Man From Atlantis with Patrick Duffy.
Anyone else remember that, or is it just me...
Steve
#211765 - 03/04/2004 13:27 Re: Version 3 Alpha / Beta ? [Re: Major_Sarcasm]
Daria
I'm certainly not the first to refer to them as the blue people.
#211766 - 03/04/2004 21:41 Re: Version 3 Alpha / Beta ? [Re: Daria]
genixia
Can you identify the suspect in this line-up?
#211767 - 03/04/2004 21:48 Re: Version 3 Alpha / Beta ? [Re: genixia]
Daria
No. Well, it wasn't #6.
But I don't remember who it was.
#211768 - 03/04/2004 23:32 Re: Version 3 Alpha / Beta ? [Re: Shonky]
adavidw
Loc: Utah, USA
<snip>
We're talking about crash of the player, right?
-Aaron
#211769 - 04/04/2004 00:28 Re: Version 3 Alpha / Beta ? [Re: adavidw]
Yes a crash of the player, not the car
Although I did clip a gutter on the first day of having my empeg installed because I wasn't paying enough attention to the road.
#211770 - 04/04/2004 07:50 Re: Version 3 Alpha / Beta ? [Re: genixia]
Most likely number four
#211771 - 04/04/2004 10:07 Re: Version 3 Alpha / Beta ? [Re: mlord]
Terminator
Loc: Dallas, TX
1?
#211772 - 04/04/2004 10:15 Re: Version 3 Alpha / Beta ? [Re: Terminator]
Yup, could be one I suppose
