#211666 - 31/03/2004 09:20 Tuner Kit <-> Antenna Interaction
gbsallery
Hi,
Finally got round to assembling my tuner kit (thanks Patrick!). Amazingly, it worked first time, but I have the following niggle: the power antenna mast is up all the time the player is on. I know there's been some discussion about adding 10k pull-down resistors to the antenna output line; I've now tried this and it produces no difference in the state of the antenna.
So, does anybody know: what part of the software is responsible for controlling the antenna line, and is it currently working for PCATS tuner kits?
Any dollops of insight would be welcomed...
Gavin
#211667 - 31/03/2004 09:54 Re: Tuner Kit <-> Antenna Interaction [Re: gbsallery]
The FAQ entry is here. I'm guessing that you've done one of two things:
- You may have connected your power antenna's activation lead to something other than the antenna lead on the tuner module. For instance, you may have connected it to the amp remote wire instead.
- You may have the RDS Traffic Announce feature turned on in the software.
And the recommended resistor, by the way, is 1k, not 10k, I don't know if that makes a difference.
#211668 - 31/03/2004 10:03 Re: Tuner Kit <-> Antenna Interaction [Re: tfabris]
gbsallery
Hmmm, thanks Tony. However, I'm pretty sure the antenna is on the right wire, as it's the one that comes out of the tuner module (not the empeg harness), and anyway my amplifier is hooked up to that other line :-)
I'm assuming that when the "TA" indicator is off on the radio info screen, then RDS Traffic Announce is off? This is the current setting, and it makes no difference. I wonder if I should have used that smaller resistor...
#211669 - 31/03/2004 20:54 Re: Tuner Kit <-> Antenna Interaction [Re: gbsallery]
foxtrot_xray
Loc: Atlanta, Georgia
niggle [...] dollops
I love the way everyone talks over there. Really.
Can't help, other than to consider that PERHAPS, just maybe your antenna is expecting to be connected to ground to make it raise, then cut off to make it lower... i.e. Ground common..
Although I doubt it, I *HAVE* seen it. Just required a relay between the antenna and the driving wire..
I guess a check would be to see if the antenna goes down when it's disconnected from the tuner. If it does, then soemthing may have gotten shorted in the tuner box..
Me.
#211670 - 23/08/2004 06:21 Re: Tuner Kit <-> Antenna Interaction [Re: gbsallery]
bjoern
Loc: Regensburg, Germany
I'm having the same issue with my PCATS tuner. The antenna is connected to the power antenna lead from the tuner and TA is off. If disconnected, the antenna goes down.
32MB, serial: 10101626
#211671 - 23/08/2004 14:20 Re: Tuner Kit <-> Antenna Interaction [Re: bjoern]
JrFaust
Loc: New Richmond, WI
Just to point this out you two may know this but there are two blue wires that come out of the PCats tuner. One is constant power, and the other is the antenna power. If you're still having issues you could use a relay that is activated by the remote wire.
Drive fast, Play it loud!!!
20GB Original Blue Lens MKIIa Rio SN 030102760, Blue Buttons.
20GB Original Green Lens MKIIa Rio SN 040103268 Grey Buttons.
#211672 - 24/08/2004 06:21 Re: Tuner Kit <-> Antenna Interaction [Re: JrFaust]
bjoern
Yes, one blue wire goes into the tuner and one comes out. The one that goes in provides power to the tuner, the one that goes out should provide 12V only if the tuner is switched on. However, for me, that wire has also constant 12V (or the antenna wouldn't be up). Since I have two blue wires with constant 12V, what wire should I use to switch the relay with?
#211673 - 24/08/2004 16:05 Re: Tuner Kit <-> Antenna Interaction [Re: bjoern]
Those having trouble with the antenna not going down... You've read this right?
#211674 - 25/08/2004 09:27 Re: Tuner Kit <-> Antenna Interaction [Re: tfabris]
bjoern
Of course! The FAQ is the first thing I look at if I have a problem, then the BBS search function. This is how I found this thread. The problem is, that the antenna goes up and down with the player, irrespective of tuner on or off. I'm 99.9% sure TA is off (as there's only a "TA ON" menu item and no "TA OFF" menu item and there's no TA on the radio display anywhere), but I'll triple check.
I'm also running 2.0, and Hijack 394, so firmware should not be the issue either. That's why I posted in this thread, to find out if maybe more people with the PCATS tuner had the problem and it may be related to something that's different in this vs. the original tuner.
#211675 - 25/08/2004 16:10 Re: Tuner Kit <-> Antenna Interaction [Re: bjoern]
So did you try the 1k resistor or not?
#211676 - 25/08/2004 16:19 Re: Tuner Kit <-> Antenna Interaction [Re: tfabris]
From his first post:
Emphasis mine.
Of course, if he put a 10k resistor in there, it might still not work. 10k ohms is like, what, rubber?
Edited by wfaulk (25/08/2004 16:20)
#211677 - 25/08/2004 16:38 Re: Tuner Kit <-> Antenna Interaction [Re: wfaulk]
The first post in the thread was not by the same person. The user names are different.
#211678 - 25/08/2004 16:44 Re: Tuner Kit <-> Antenna Interaction [Re: tfabris]
Oh. Duh.
#211679 - 26/08/2004 06:44 Re: Tuner Kit <-> Antenna Interaction [Re: tfabris]
bjoern
I didn't. From the description, it seemed to me that the behavior of the antenna should be more erratic (like going up at the right time, but not going down correctly or vice versa). Mine is consistently up when the player is on and only goes down once I switch it off. Since the description didn't match my symptoms, I figured that couldn't be the problem and didn't try it. It sounded like the voltage, once applied wouldn't go down enough. Silly me, I didn't consider the possibility, that the antenna relais actually could draw voltage from the tuner, even if it never was switched on.
I have a Miata. Maybe someone knows if their antennae have this problem? Anyway, if that's the last thing I can try, I'll go back and dig into the dash and add that resistor, definitely.
Thanks for your help, guys!
#211680 - 26/08/2004 19:53 Re: Tuner Kit <-> Antenna Interaction [Re: bjoern]
The description at that FAQ link indicates that your reported behavior is in fact one of the possible symptoms. So try the resistor, it's easy enough to do.
