#206464 - 23/02/2004 18:52 Mk2a is a bit sick
robricc
It all started last night. This Mk2a was in my Trooper working happily. I then uninstalled the audio in that car and fitted the Trooper with a CD-MP3 player. I put the empeg in its case and layed it on the floor in the back. I then drove about 150 miles. Upon plugging it back into my SVX, I noticed something was wrong.
This unit was running 3a7 and Hijack 374. The standby LED constantly pulses like it's in standby. However, it seems to not fully dim. It seems to pulse between 50% and 100% brightness. The VFD does not come up at all anymore. For a while, the empeg would function normally (aside from the VFD being dead). I was able to advance tracks, switch the tuner on, and all that. Then, I decided to put it into standby by holding down the top button. The music stopped, and I pulled the empeg out of the sled. From this point on, the empeg now did nothing but pulse. I cannot get it to wake up or make any sound. Even on boot the LED pulses constantly.
I just opened the face to inspect the VFD. It seems fine. Nipple is present and looks normal. No cracks in the glass either. 2.00 Final is on the unit now. That didn't help. So, here's my boot log. I don't know how to read this, but it looks pretty standard to me. So, any ideas on what to attempt now?
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.14-rmk5-np17-empeg52 (rob@aphex) (gcc version 2.95.3 20010315 (release)) #11 Tue Apr 1 18:49:59 BST 2003
empeg-car player (hardware revision 9, serial number 40103772)
Command line: mem=16m
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005000).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IC25T060ATCS05-0, ATA DISK drive
hda: IC25T060ATCS05-0, 57231MB w/1768kB Cache, CHS=7296/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0e:bc
Partition check:
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Mounting proc
No secondary hard disk
Starting player
Vcb: 0x4086d000
#206465 - 23/02/2004 19:00 Re: Mk2a is a bit sick [Re: robricc]
I would double-check all cable connections, especially the display cable. It may have jarred loose from the mainboard during the ride.
#206466 - 23/02/2004 19:05 Re: Mk2a is a bit sick [Re: pgrzelak]
robricc
OK, I'm about to take the drive out. I just took a pic of the nipple and thought I'd share.
#206467 - 23/02/2004 19:07 Re: Mk2a is a bit sick [Re: robricc]
It looks fine. But if the VFD was bad, it would not explain the control problems. Perhaps (if the header is on the main board properly) you might want to check the display surface mount fuses on the mainboard.
#206468 - 23/02/2004 19:17 Re: Mk2a is a bit sick [Re: pgrzelak]
robricc
Visual inspection of the cable and components on the main board and display board seems OK. I am going to find another display board...
#206469 - 23/02/2004 19:20 Re: Mk2a is a bit sick [Re: robricc]
Did you try pushing down on the display board header? This kind of thing has cropped up before, and the header was loose but looked attached.
#206470 - 23/02/2004 19:22 Re: Mk2a is a bit sick [Re: pgrzelak]
robricc
just did that. No go.
#206471 - 23/02/2004 19:27 Re: Mk2a is a bit sick [Re: robricc]
Hmmm... Worth a shot.
Is it possible to remote control the player through hijack or another VNC / web type interface?
#206472 - 23/02/2004 19:28 Re: Mk2a is a bit sick [Re: robricc]
robricc
The VFD is confirmed good. I just hooked the display board from the broken unit to one of the backups. It works.
So, it seems there is something wrong with the mainboard?
#206473 - 23/02/2004 20:04 Re: Mk2a is a bit sick [Re: robricc]
Greetings!
So it would seem, but I am not sure what else it could be off hand.
#206474 - 23/02/2004 20:07 Re: Mk2a is a bit sick [Re: pgrzelak]
robricc
Thanks for the help Paul, but I am going to transfer the drive from the dead empeg to a backup (flashing to 2.0 now). I will get this one looked at by someone (Rob S. maybe) in the future. It's not a big deal considering how many spares I have.
#206475 - 23/02/2004 21:23 Re: Mk2a is a bit sick [Re: robricc]
Blown fuse on the mainboard. One of the three SMT fuses adjacent to the displayboard connector, most likely the one of those three nearest the docking connector. Not visibly blown, requires an ohm-metre to verify.
I've got a ton of them on hand here, and can mail you one if you have soldering capability.
#206476 - 23/02/2004 21:29 Re: Mk2a is a bit sick [Re: mlord]
robricc
It would be great to get one. I wouldn't trust myselt to take a hot iron to an empeg, so someone else will have to do it. But, I think I may be able to find someone to do the job. Thanks!
#206477 - 24/02/2004 00:37 Re: Mk2a is a bit sick [Re: robricc]
Before you start assuming a hardware problem, will it take a squirt of the 2.0 developer image?
Edit: Just re-read the post. Had missed the line where you said 2.0 final went on successfully...
#206478 - 24/02/2004 05:47 Re: Mk2a is a bit sick [Re: tfabris]
Greetings!
Still kind of puzzled what could do this. I can see a fuse, but it seems to have been triggered more from vibration, riding in the case in back. That is why I was thinking display connector...
Well, transplanting the drives is a good way to get back online quickly, so good call. Is there any way you can check the fuses to verify them?
#206479 - 24/02/2004 12:50 Re: Mk2a is a bit sick [Re: pgrzelak]
robricc
I am sending the unit in question to Mark to get worked on.
When the empeg was being taken out of the trooper, we left it in the dash while disconnecting the amp from the battery. I am not sure what this could have done since the main battery lead was constantly connected. That's the best I can think of (other than some crazy vibration).
#206480 - 24/02/2004 16:07 Re: Mk2a is a bit sick [Re: robricc]
russmeister
Loc: South Carolina
Come on, be honest. This is really why you are selling the trooper, isn't it?
Russ
"The difference between a successful person and others is not a lack of strength, not a lack of knowledge, but rather a lack of will." Vince Lombardi
#206481 - 24/02/2004 19:45 Re: Mk2a is a bit sick [Re: russmeister]
robricc
