#203959 - 11/02/2004 17:59 No Hard Disk Found - Contact Support - New Chip
mvigneau
Loc: Manchester, NH
Well,
I replaced the CS4231A-KQ Chip again. It is still giving me the NHDFCS error. Here is the log.
or forever hold their peace...it seems not. Let fly the Penguins o
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v361 (root@ibbm) (gcc version 2.95
.3 20010315 (release)) #2 Sun Jan 25 22:34:59 EST 2004
empeg-car player (hardware revision 9, serial number 10101551)
Command line: mem=16m
Memory: 15016k/16M available (980k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 636f6972 'rioc'
Found custom animation at offset 0x9b790
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
Could not find CS4231A (version=80)
empeg state support initialised 0089/88c1 (save to d0004a00).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
smc chip id/revision 0x0049
smc_init couldn't find card
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...el panic: VFS: Unable to mount root fs on 03:05
I don't know what to do? Do you have any suggestions? Is there somewhere I could send it to get fixed?
#203960 - 11/02/2004 18:07 Re: No Hard Disk Found - Contact Support - New Chi [Re: mvigneau]
It's still saying "Could not find CS4231A (version=80) "...
#203961 - 11/02/2004 18:54 Re: No Hard Disk Found - Contact Support - New Chi [Re: tfabris]
mvigneau
Loc: Manchester, NH
I know...I don't get it. Maybe the chip I purchased is incompatible or something??? But i have tried 2 chips and the same result (albeit they are from the same shipment).
#203962 - 11/02/2004 20:08 Re: No Hard Disk Found - Contact Support - New Chi [Re: mvigneau]
maczrool
Loc: Louisiana, USA
I suggest you try a chip from the Empeg lot. Yours are much newer.
Stu
#203963 - 11/02/2004 20:53 Re: No Hard Disk Found - Contact Support - New Chi [Re: maczrool]
mvigneau
Loc: Manchester, NH
How do I get one of those?
#203964 - 11/02/2004 21:52 Re: No Hard Disk Found - Contact Support - New Chi [Re: mvigneau]
maczrool
Loc: Louisiana, USA
We have them. Remember? PM me.
Stu
#203965 - 12/02/2004 20:41 Re: No Hard Disk Found - Contact Support - New Chi [Re: maczrool]
mvigneau
Loc: Manchester, NH
You guys are the greatest. I just hope that this chip works.
#203966 - 12/02/2004 20:49 Re: No Hard Disk Found - Contact Support - New Chi [Re: mvigneau]
I'm betting your chip is just fine at this point, and something else is wrong.. like a signal or power source feeding into the chip.
Just my guess though. Hope it all works out in the end.
#203967 - 12/02/2004 20:59 Re: No Hard Disk Found - Contact Support - New Chi [Re: mlord]
mvigneau
Loc: Manchester, NH
If it is one of those is there anything to fix it?
#203968 - 12/02/2004 21:25 Re: No Hard Disk Found - Contact Support - New Chi [Re: mlord]
maczrool
Loc: Louisiana, USA
We'll know pretty soon if it's a chip issue or not, assuming the soldering is sound. You can thank Hugo and Rob V. as well since they sent us the chips.
Stu
#203969 - 12/02/2004 21:29 Re: No Hard Disk Found - Contact Support - New Chi [Re: maczrool]
mvigneau
Loc: Manchester, NH
Thanks guys...all the help is appreciated. If it wasn't for you guys, the board, Empegs and everything would go down the toilet.
I will take a picture of the chip after it is done. I don't know how nice the picture will be with my cheap digital camera but I will try.
#203970 - 26/02/2004 18:47 Re: No Hard Disk Found - Contact Support - New Chi [Re: mvigneau]
mvigneau
Loc: Manchester, NH
Well, I received maczrool's chip and replaced it. Still getting the NHDFCS. It looks like the chip may be good and something else may be wrong as MLord eluded to.
Here is the output just for kicks:
e000 v1.04
Copying kernel...
l.
empeg state support initialised 0089/88c1 (save to d0004a80).
#203971 - 15/03/2004 23:23 Re: No Hard Disk Found - Contact Support - New Chi [Re: mvigneau]
For anyone keeping score (or using SEARCH), this issue eventually got resolved. The ethernet chip had D5 (Data line 5) stuck low for some reason. I disconnected it, and the rest of the player came back to life.
Details in this thread
EDIT: I suppose it even makes sense, as the player had been reporting Could not find CS4231A (version=80) , whereas the true version of that chip was a0, which is 80 when you force D5=low (0).
Edited by mlord (15/03/2004 23:29)
#203972 - 15/03/2004 23:33 Re: No Hard Disk Found - Contact Support - New Chi [Re: mlord]
genixia
I'm guessing that the ethernet chip was the victim of a lightening strike. ie, static. The question is whether this was the original problem (and hence how/when did it happen) or whether it happened during the first chip change. That would be bizarre - having two problems with exactly the same symptom occur sequentially like that.
We'll never know!
