#20154 - 12/10/2000 05:47 grabbing the empeg screen
mschrag
Loc: Richmond, VA
Why is it that grabscreen returns a 2048 byte array (and appears to be 4 bits per pixel) if the empeg is only 2 bits per pixel? Did I fall asleep in class and miss something :) ?
Mike
#20155 - 12/10/2000 06:02 Re: grabbing the empeg screen [Re: mschrag]
fvgestel
Loc: Netherlands
You're right, it doesn't make sense. per byte there are only 4 bits used.
00 00 00 00
rp lp
lp=left pixel
rp=right pixel
As I recall, it is possible to use 4 bits/pixel, but this would make the screen blurry/difficult to read. I wrote a java applet which also receives the screenbuffer 20 times per second; I will update it this week to only send/receive 1024 bytes as this would significantly reduce network-bandwith
Frank van Gestel
Frank van Gestel
#20156 - 12/10/2000 07:13 Re: grabbing the empeg screen [Re: mschrag]
The hardware is 4bpp, however there are only 4 useful colours in that space. The display is run through a palette by the hardware too. Actually, the hardware screen buffer is a very frightening layout (read the comment at the start of arch/arm/special/empeg_display.c).
We may well use another grey in future, as there's another useful one we've found...
#20157 - 12/10/2000 09:41 Re: grabbing the empeg screen [Re: mschrag]
Another thing...
When looking at binary logo files with an editor, this format makes it really easy to see the pixel layout. Each nibble is either a 0, 1, 2, or 3, each number representing the corresponding color. It also makes writing bitmashing and pixel-pushing algorithms very easy (as I discovered last night while working on my logo editor).
#20158 - 12/10/2000 09:54 Re: grabbing the empeg screen [Re: tfabris]
mschrag
Loc: Richmond, VA
I definitely agree it makes life easier ... My first version of the Java renderer did 2 bit bitmanip, and it produced pretty funny looking output.
