#199100 - 18/01/2004 20:47 Emplod Question
belezeebub
Its slighty annoying but when I try and upload via E-net I get errors if I grab more then a few 100 tracks at a time.
I am running a Fully patched XP pro (firewall and virus scanner are turned off) the Empeg is hooked to a D-link hub.
Works fine (but Slowly) via usb
I have about 62 Gig of files to upload well over 11000 tracks so 100 at a time kind of sucks, any thing I can do to tweek it.
Computer info
3.06P4 Ht
3Gigs of Ram
2.11 TB Raid Array
Gig Copper NicFast Ethernet card (used to connect to Empeg Hub)
Empeg Info
Mk2
Serial # 080000391
2 40Gig toshiba Drives (brand new)
Customer Software 2.00Beta 13
______________________________________ Do not meddle in the affairs of Network Administrators, for they are subtle and quick to anger. ______________________________________ Worlds Lamest Wb Site (mine) http://home.comcast.net/~jlipchitz/
#199101 - 18/01/2004 20:58 Re: Emplod Question [Re: belezeebub]
belezeebub
See attached
#199102 - 19/01/2004 11:35 Re: Emplod Question [Re: belezeebub]
If you press on the Warnings tab, does it give you any more detailed information?
By the way, I don't recommend that you turn off the firewall and virus scanning features of XP if you are connected to the internet. Leave them on and poke the hole for emplode as described in the FAQ here. It's possible that the reason you're getting ethernet errors is because you've been infected by a worm that's clogging your bandwidth. (This is just one of many possibilities, I'm not saying that's likely, I'm just saying that sort of thing can happen when you turn off the firewall and virus scan.)
#199103 - 19/01/2004 14:16 Re: Emplod Question [Re: tfabris]
belezeebub
When I said no firewall I was talking about that built into XP POS I don't trust software firewalls I use a I have a https://www.watchguard.com
Fireboxx 700
and the Empeg is on the trusted side of the network.
I'll upload some more files tonight (I am at lunch now) and I'll post the log and error
#199104 - 19/01/2004 14:45 Re: Emplod Question [Re: belezeebub]
Ah, yes, a hardware firewall is much better than the XP POS, I agree.
Does that watchguard firewall have its own built-in hub, and are you using that to connect the empeg? If so, try it on a separate hub as described here and see if that fixes it.
#199105 - 19/01/2004 19:27 Re: Emplod Question [Re: belezeebub]
mcomb
Loc: San Carlos, CA
Is there a reason you aren't running 2.0 final? I would upgrade first before going too far down the troubleshooting path.
-Mike
#199106 - 19/01/2004 22:42 Re: Emplod Question [Re: mcomb]
belezeebub
Mainly because that was the one I ran on my last empeg
I can switch and check.
#199107 - 19/01/2004 23:26 Re: Emplod Question [Re: belezeebub]
belezeebub
As Pormissed here is the Full Screenshot of the errors
#199108 - 20/01/2004 00:11 Re: Emplod Question [Re: belezeebub]
belezeebub
Ok Switched to version 2 customer release here is a SS of the errors
#199109 - 21/01/2004 01:05 Re: Emplod Question [Re: belezeebub]
belezeebub
Well at my wits end, tried to different hubs 2 different cables and 3 different versions of the empeg software I still get the same errors any suggestions ?
it really sucks having to upload 100 file or less at a time
Getting it on USB also now.
#199110 - 21/01/2004 01:09 Re: Emplod Question [Re: belezeebub]
Is there any other traffic on your LAN besides the empeg upload?
Can you confirm that you don't get ethernet errors in other situations? For example, transferring gigs of files to another computer?
#199111 - 21/01/2004 01:10 Re: Emplod Question [Re: tfabris]
Also, is the empeg itself being placed anywhere that temperature might be an issue? Like on top of the monitor, or with something covering its vent holes? Did you ever have hard disk trouble on this player?
#199112 - 21/01/2004 01:14 Re: Emplod Question [Re: tfabris]
belezeebub
NO other traffic issues in my logs and I transfer gigs and gigs from one system to the other with no issues, this is a new empeg, purchased here so not sure if it has other issues,
it it on my desk in my cold 60degree computer room.
#199113 - 21/01/2004 05:33 Re: Emplod Question [Re: belezeebub]
Do you have a direct crossover cable that you can test? I am wondering - the empeg can only support 10Mbps. If your hub is having trouble stepping down the speed, or performing an autonegotiation for your computer at 100Mbps, this might be part of the problem. Some manufacturers (I don't know about D-link) have a really hard time doing this well...
Try a direct crossover cable, and see what your LAN card and hub ports are set for speed / duplex / negotiation.
#199114 - 21/01/2004 12:26 Re: Emplod Question [Re: pgrzelak]
mcomb
Loc: San Carlos, CA
It may also be helpful to see the serial output from your player during a sync. Can you hook up a serial cable and use a terminal program to capture the log during a sync (see faq for more details if needed).
-Mike
#199115 - 21/01/2004 13:29 Re: Emplod Question [Re: mcomb]
belezeebub
Tried the Other connection on the IDE cable Same issue
If it helps after this error (See attached) the player keep spinning the "SYNC LOGO" till I power cycle it and start over.
#199116 - 21/01/2004 13:52 Re: Emplod Question [Re: belezeebub]
belezeebub
Even more Odd USB is not working anymore (see attached)
#199117 - 22/01/2004 23:14 Re: Emplod Question [Re: belezeebub]
belezeebub
OK you were right I used a cross over cable and it worked slow but it worked took about 22 hours to upload 57G of mp3's but its gtg
#199118 - 23/01/2004 05:30 Re: Emplod Question [Re: belezeebub]
22 hours for 57 GB? That is probably about right, if I remember correctly. Glad it worked out! Are you able to use USB now?
#199119 - 23/01/2004 05:57 Re: Emplod Question [Re: pgrzelak]
22 hours for 57GB works out to be about 5.8Mbps or 755KB/s. That's roughly what I get as well.
