#198401 - 28/01/2004 15:36
Re: No Hard Disk Found - Contact Support
Loc: Manchester, NH
AHHHH!!! It all makes sense now!!! I was a little confused, but luckily you guys are patient and MOST HELPFUL!!!
You guys are the greatest!!!
#198402 - 28/01/2004 16:08
[Re: mvigneau]
Strange... A version of C7 means that it's not a CS4231 or CS4231A. What does it say exactly on the top of the chip?
#198403 - 28/01/2004 16:47
[Re: tman]
Loc: Manchester, NH
It says CS4231A-KQ
CTAZFP9819
#198404 - 28/01/2004 17:10
[Re: mvigneau]
That's really odd to say the least. A CS4231A should have read as revision A0. If they upgraded the chip then they'd change the chip model number. In theory they should anyway, some companies have been remarkably lacking in this.
Gotta ask, you sure you soldered it in properly?
#198405 - 28/01/2004 17:16
[Re: mvigneau]
Loc: Louisiana, USA
If you want to try again, we have a bunch of CS4231A-KQs apparently left over from Empeg production. The player should be happy with those.
Stu
#198406 - 28/01/2004 17:27
[Re: maczrool]
Loc: Manchester, NH
If MLord's fix works, then I don't see a need to change the chip; unless you do?
#198407 - 28/01/2004 17:28
[Re: mvigneau]
It might be the last HiJack update you get for a while.
#198408 - 28/01/2004 17:30
[Re: mvigneau]
If MLord's fix works, then I don't see a need to change the chip; unless you do? Yeah, so what's the deal with Mlord's fix? Did you get a proper download of the file so that it no longer exception faults when you install it? How are you downloading it?
#198409 - 28/01/2004 17:33
[Re: SE_Sport_Driver]
Loc: Manchester, NH
As long as I can listen to music and stuff... I will be happy.
Maybe I should get one of those chips and then replace it at a later date. I guess the other chips I bought are basically useless.
#198410 - 28/01/2004 17:35
[Re: mvigneau]
Loc: Louisiana, USA
No problems here, I was just implying that if you didn't have any success with the modified Hijack kernel you could try a different lot of chips.
Stu
#198411 - 28/01/2004 17:35
Loc: Manchester, NH
I tried downloading it again, but it still didn't work. Do you recommend anything to help with that?
#198412 - 28/01/2004 17:40
[Re: maczrool]
Loc: Manchester, NH
Sounds good...I will have to wait for Mark Lord.
#198413 - 28/01/2004 17:51
Loc: Manchester, NH
I tried GetRight download manager but it didn't help. Maybe the file is corrupted and needs to be reuploaded or something?
#198414 - 28/01/2004 17:55
[Re: mvigneau]
Mmm... I seem to have goofed typing (finger splint gets in the way).
Okay, grab the kernel from here now:
http://rtr.ca/hijack.v361+.zImage (486688 bytes)
#198415 - 28/01/2004 18:12
Loc: Manchester, NH
That worked but the RIO is still stalling at the boot logo.
Here is the output from HyperTerminal:
TCP: Hash tables configured (ehash 16384
If there is anyone present who wants to upgrade the flash, let them speak now,tocols for Linux-2.2 (Dag Brattli)
ircomm_tty: vi
e000 v1.04iver for I
Copying kernel...ed May 26 00:49:1
Calling linux kernel...
Uncompressing Linux.....................................v 1.5
ttyS02 at 0xf8030000 (irq = 16) is a S
NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp.636f6972 'rioc'
Scheduling custom logo.
empeg-car player (hardware revision 9, serial number 10101551)
empeg dsp audio initialised
Command line: mem=16mtialised
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 636f6972 'rioc'
Found custom animation at offset 0x9b790
Tuner: loopback=0, ID=-1
empeg display initialised.
empeg dsp mixer initialised
empeg dsp initialised
Could not find CS4231A (version=c7)
empeg audio-in initialised, CS4231A revision c7
empeg usb initialised, PDIUSBD12 id dfdf
#198416 - 28/01/2004 18:19
[Re: mvigneau]
Mmm... okay, so it's not just a version difference.
How about you and Stu compare chip labeling -- what exactly is written on the top of the chip you installed? Stu, does that match yours?
The kernel does this: version = (version & 0xe7)
so the "c7" could really be "d7", for whatever that's worth.
But with it affecting the hard drive controller still.. Can you locate the power pins for the chip and measure the operating voltage on them?
#198417 - 28/01/2004 18:24
The middle two bits are marked as reserved and aren't part of the normal identification.
It's not a good sign that it still can't boot up. A possibility is that the CS4231A driver is hanging for some reason and that's what's causing it to fail?
#198418 - 28/01/2004 19:01
Loc: Louisiana, USA
This is what is written on the top of some of the chips(different lot numbers are in here) in the bunch:
Crystal
CS4231A-KQ
CTAEDP0007
The bottom of the same bunch of chips reads:
Taiwan
T000717
My guess is that these chips are much newer than mvigneau's chip.
Stu
#198419 - 28/01/2004 19:12
Loc: Manchester, NH
Ok...I feel like the dumbest man on the forum!!!
I plugged the IDE Cable into only have of the pins. Well, I have fixed that and it is fully seated now. But, I am getting the No hard disk found...contact support error again. I have flashed it with Hijack 361 (not the customized one) because it was giving that error.
It is still giving that error even after the reflash.
Here is the hyperterminal output:
e000 v1.04
Copying kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v361 (root@ibbm) (gcc version 2.95
.3 20010315 (release)) #2 Sun Jan 25 22:34:59 EST 2004
Memory: 15016k/16M available (980k code, 20k reserved, 364k data, 4k init)
Could not find CS4231A (version=80)
empeg state support initialised 0089/88c1 (save to d0004800).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
smc chip id/revision 0x0049
smc_init couldn't find card
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...
#198420 - 28/01/2004 22:23
[Re: mvigneau]
(1) Re-try the customized Hijack for us. It won't work, but we gotta know!!
Check the fuses. When the hard drive cable is misplugged, or the display cable misplugged (forgot which), sometime it blows fuses near the display cable header. But usually music still plays, just the display ends up buggered. So that's not likely the case here. The fuses are the three identical looking two-pin items mounted around the display header; two on the rear left (nearer the docking connector), and one on the front left. Measure them with an ohm meter, and they should all read zero ohms.
But still looks like a bad sound chip, or maybe just mis-soldered. Check the +5v and GND pins on the sound chip that was replaced.
#198421 - 29/01/2004 06:39
Loc: Manchester, NH
Do you know what pins those are?
Also, does anybody have a picture of how the chip is oriented on the board. Such as where pin 1 goes because we marked it but maybe it was placed wrong.
#198422 - 29/01/2004 08:16
[Re: mvigneau]
Photo of chip in positiion is attached. To find +5V and GND, you'll have to do a search for the chip's pinout online.
#198423 - 29/01/2004 12:19
Loc: Manchester, NH
My chip is oriented the same way as in the picture.
There are 4 voltage points on the Chip. I tested VD1 and VD2 and used the case as ground and got 5VDC. I tested VD3 and VD4 and wasn't seeing 5VDC.
I have included the pinout diagram for the chip.
I have also tested the 3 fuses. With the power off, I was getting 0 Ohm and with the power on, I was getting 0 ohm.
#198424 - 29/01/2004 12:24
[Re: mvigneau]
Loc: Louisiana, USA
So do you have the datasheet for that chip? We've got it if you need a copy.
Stu
#198425 - 29/01/2004 14:01
[Re: maczrool]
Loc: Manchester, NH
I am using the one I found while doing a Google Search.
#198426 - 30/01/2004 08:08
Re: NEW CABLE installed now it wont power up
[Re: bsieloff]
Loc: New Jersey
True! With the extreem cold here in NJ i have been getting the dreaded NHDF-CS...pull the player out of the sled, slam it bak in..and it works!!!!
#198427 - 30/01/2004 16:39
Loc: Manchester, NH
I retried the custom Hijack and am getting the same thing "No Hard Disk Found...Contact Support". I am also seeing the same output in Hyperterminal as the non-customized Hijack.
