#194817 - 07/02/2004 04:36
Re: Merry Christmas
[Re: image]
anybody tried alpha6 yet? inquiring minds wanna know...
#194818 - 07/02/2004 10:42
Re: Merry Christmas
[Re: jerryfreak2]
#194819 - 07/02/2004 10:51
Re: Merry Christmas
[Re: jerryfreak2]
Wow, didn't even see it up there before... I think this is the first mention of it. No release notes either...
rob??
#194820 - 07/02/2004 12:06
Re: Merry Christmas
[Re: tonyc]
Either way, my empeg is programming flash (kernel)... alpha 6 here we come
Oliver
#194821 - 07/02/2004 12:41
Re: Merry Christmas
[Re: genixia]
Loc: Los Angeles
Well, I was able to make changes to the DB and rebuild it with no problems, so it appears that problem may be solved. It was a bit of work to install, I had to manually rebuild the database twice. But after I got all that sorted out, it appears to be working ok.
#194822 - 07/02/2004 13:40
Re: Merry Christmas
[Re: ninti]
Stereo separation?
#194823 - 07/02/2004 13:54
Re: Merry Christmas
[Re: andym]
Sounds fixed to my ears... but I’m not positive.
Also, i can't seem to sink over Ethernet. Syncing with USB and Emplode 2.10 worked great. Rebuilt the DB, and I’m running pretty smoothly now.
Note: I upgraded from alpha 5.
Oliver
#194824 - 07/02/2004 15:53
Re: Merry Christmas
[Re: ninti]
Loc: Jesusland
Were you brave enough to put it on your main player? How many tracks did you have on it when you did the upgrade?
#194825 - 07/02/2004 16:07
Re: Merry Christmas
[Re: genixia]
Loc: Atlanta, Georgia
Why was I under the impression that there was a different or something significant between EVEN and ODD numbered releases? i.e. 3.00a3, 3.00a5, 2.00b11, 2.00b13, etc etc. Is my memory that fuzzy that I'm mixing this up with some other beta thing I'm doing and just a coinkidink that all the Empeg b/a releases were odd numbered?
If the DB rebuild problem is fixed, it's going on both of my players.
Me.
Mike 'Fox' Morrey
128BPM@124MPH. Love it!
2002 BRG Mini Cooper
#194826 - 07/02/2004 16:22
Re: Merry Christmas
[Re: oliver]
Stereo separation is fixed, syncing over ethernet works! Seems just as stable as a5 was. I'm really happy!
#194827 - 07/02/2004 16:41
Re: Merry Christmas
[Re: Jerz]
Loc: Jesusland
Ahhhhh... the spare player upgraded so easily that I crossed my fingers and am in the process of upgrading the player with 70gigs of tracks.
#194828 - 07/02/2004 16:47
Re: Merry Christmas
[Re: jerryfreak2]
JEmplode gives me this error on a freshly upgraded unit:
#194830 - 07/02/2004 16:53
Re: Merry Christmas
[Re: Daria]
Your player is weird!
After the JEmplode error message, I "touched" a playlist (to force a sync), and then told JEmplode to "sync" it. Rebooted the player after it finished, and all is well.. database has all 6000 or so tracks.
#194833 - 07/02/2004 17:09
Re: Merry Christmas
[Re: Daria]
Loc: Jesusland
12,000 songs? No, but my player is telling me 9thousand something tracks and around 70gigs. Alpha 6 seems to have upgraded the player fine keeping all of my previous playlists and everything. But then again I have a tendancy of speaking too soon (knocking on wood).
#194834 - 07/02/2004 17:13
Re: Merry Christmas
[Re: Daria]
Loc: San Carlos, CA
Maybe I'm running out of memory
Have you tried playing with the ReserveCache setting? Alpha3 wouldn't build a DB for me until I added a ReserveCache (64 I think). I think the kernel was running out of memory and killing off the player. You have more tunes than I do though, I think I am around 7000.
-Mike
#194837 - 07/02/2004 17:34
Re: Merry Christmas
[Re: oliver]
Loc: Jesusland
I'm not sure about in the car but it sounds damn good on my pc speakers.
Also... no problems syncing with ethernet upgrading from v2.00 final or alpha5.
201728-Chase 024.jpg (269 downloads)
#194841 - 07/02/2004 19:06
Re: alpha6 player bug found
[Re: Daria]
Good! I'm very happy to hear you've managed to get onto the v3 alphas!
Is your player a Mk2 (12MB), or Mk2a (16MB) ?
#194842 - 07/02/2004 19:11
Re: Merry Christmas
[Re: andym]
Mmm... INFO-Transient still has issues.
#194843 - 07/02/2004 19:21
Re: Merry Christmas
[Re: tonyc]
I put it up for Tony to test just before I left work and I forgot to erase it. Tony reported total failure, which seems to be due to too much cache allocated. This release may be no good for anything but 16MB players. Not that it is a release.
#194846 - 07/02/2004 19:56
Hijack v363
[Re: rob]
Mmm.. accidental or otherwise, this one is definitely a keeper! It's so nice to be able to use a well-functioning v3-alpha again!
I've just released Hijack v363, which includes a minor update to workaround the broken "prev visual" function from alpha6 (similar to prior v3 alphas).
