#192859 - 10/12/2003 19:33 Where to purchase a upgrade HD for my empe Mk2?
RussPath03
I would like to upgrade my new Rio to a bigger HD. Any recommendations on where and brand and size to get for the best price? Thanks guys.
MK IIa 20GB Smoke
#192860 - 11/12/2003 05:29 Re: Where to purchase a upgrade HD for my empe Mk2? [Re: RussPath03]
Well, you can never have too much disk space... Capacities up to 80GB have been tested. The only thing you have to watch for is the 80GB drives specifically are "pushing the envelope" with the memory available on the empeg (especially the Mark1 and Mark2s). You see this especially with the drive builder software and when you do file system checks. But they do work.
The empeg does not need a high speed drive. The cheaper 4500RPM drives are just fine. In fact, better because they generate less heat.
Meanwhile, make sure you check out the drive upgrade FAQ for step by step, detailed instructions on how to do the upgrade.
As for price (re-reading your original post, and seeing that I misread...), I always use the old Googlegear, now ZipZoomFly.com. I have been extremely happy with their service and with their prices. Pricewatch and C|Net also give good pricing guidelines on what is out there.
Edited by pgrzelak (11/12/2003 05:32)
#192861 - 11/12/2003 09:20 Re: Where to purchase a upgrade HD for my empe Mk2 [Re: pgrzelak]
I was under the impression that it was 160GB (that is, two 80GB drives) that ``pushed the envelope''. So one 80GB drive is probably fine. Is that correct? (Edit: It's not. See posts below.)
I also like New Egg for online purchasing. They have good prices and good shipping costs (amongst the best I've seen regularly) and their web site is not too attractive, but has the best features of any online retailer I've ever seen by far.
Edited by wfaulk (11/12/2003 09:44)
#192862 - 11/12/2003 09:33 Re: Where to purchase a upgrade HD for my empe Mk2 [Re: wfaulk]
Not necessarily. The memory problems can be seen while running the builder or doing an fsck. Both of these tasks are single drive oriented. Even with 1 80GB drive, you might still see these problems. Especially if you are not using a 16MB Mark2A.
The problems that I have seen in "pushing the envelope" with 160GB are more related to the size of the scratch partition, number of FIDs and database size.
#192863 - 11/12/2003 09:44 Re: Where to purchase a upgrade HD for my empe Mk2 [Re: pgrzelak]
Oops -- you're right. I should avoid saying things I'm not sure about.
#192864 - 27/02/2006 16:06 Re: Where to purchase a upgrade HD for my empe Mk2 [Re: pgrzelak]
Gleep
Loc: Iowa
Would it be possible to use 2 of these 120gb drives?
Click here for drive info
Or is it likely to cause more trouble than it's worth?
#192865 - 27/02/2006 16:25 Re: Where to purchase a upgrade HD for my empe Mk2 [Re: Gleep]
Actually, you should be able to use two of the 160s, if you choose to. Once they are built, they should not give you too much trouble. Building them is the harder part, but if you do it manually, it should not be a problem either.
#192866 - 27/02/2006 21:34 Re: Where to purchase a upgrade HD for my empe Mk2 [Re: pgrzelak]
Gleep
Loc: Iowa
By built, do you mean formatted and an initial load of mp3's and ogg's, or do you mean it will require manual intervention everytime I add additional music?
I would love to use the 160's but the price is still too scary for me.
#192867 - 28/02/2006 00:36 Re: Where to purchase a upgrade HD for my empe Mk2 [Re: Gleep]
"Built" = formatting the hard drive to the proprietary system used by the empeg. It is a one-time only thing.
The failure of the build utility on the larger hard drives seems to be a mystery, possibly having to do with the phase of the moon or something. I have so far built and installed three different 80 GB drives and had not the slightest difficulty with any of them. Yet other people have run into problems with the same size drives.
#192868 - 28/02/2006 02:03 Re: Where to purchase a upgrade HD for my empe Mk2 [Re: tanstaafl.]
s/proprietary/specific/
#192869 - 28/02/2006 21:01 Re: Where to purchase a upgrade HD for my empe Mk2 [Re: tanstaafl.]
Gleep
Loc: Iowa
Well I ordered 3 of the 120gb drives. So 1 empeg will get two 120s and the other will get one 120gb and one 80gb! Hopefully they will arrive in time for the weekend.
So now I guess it's time to brush up on the FAQ entries on formatting the new drives and copying the data from the existing drives!
#192870 - 01/03/2006 00:09 Re: Where to purchase a upgrade HD for my empe Mk2 [Re: Gleep]
Only about a quarter of a terrabyte? Are you sure that will be enough?
#192871 - 01/03/2006 02:55 Re: Where to purchase a upgrade HD for my empe Mk2 [Re: tanstaafl.]
Gleep
Loc: Iowa
I'm sure it won't but hopefully it will be enough for a while. I have 34CDs of Ruby: The Adventures of a Galactic Gumshoe and Clive Cussler's Dark Watch to finish ripping and loading for a start.
#192872 - 02/03/2006 00:17 Re: Where to purchase a upgrade HD for my empe Mk2 [Re: Gleep]
On a slightly more serious note, rip/encode your audiobooks at a significantly lower bitrate than you do your music. VBR with a 128 kb/sec max will give quite acceptable listening quality, and will take up far less room... I have over 50 GB of spoken word audio on my player, and no way would it all fit if it were recorded at music quality.
#192873 - 26/04/2006 13:41 Re: Where to purchase a upgrade HD for my empe Mk2 [Re: Gleep]
TankheaD
Loc: MaryLand , USA
Good to see another ZBS fan! I've been a Jack Flanders fan for years (and years!)
TankheaD
Rio MkIIa (plus PCATS tuner) - 120Gb - green with lighted Greenlights smoke buttons!
JL 300/4 (Polk Audio fr & rr) - JL 250/1 (Polk Momo 8" sw)
